Firmware 1.19+1 bug fix
I've just upgraded from 1.18 to the whole 1.19 package + this bug fix.
I can't find a way to delete/rename/etc files from the web gui (macros, sys, …) There's a check box in front of the files, but there're no associated action.
(I've observed this with firefox & chromium) -
(I've observed this with firefox & chromium)Right click the file name and a drop down appears
Thanks -
Hi
Scara begins to really work well!
a big thank-you -
Thanks for the feedback, and for choosing the Duet despite the initial incomplete SCARA support.
Applied the patch.
Still have difficult time connecting via wifi. Router is reset to channel 6, no joy.I have a dedicated laptop parked 3 ft away, Whats recommended method to have a wired connection., USB cable ?
@jarery, is it not connected ting at all, or connecting but timing out, or something else?
same problem, it get connected but in a few seconds connection timeout, connection reset, etc. if i do ping continually some are lost. That not happend on 1.18. Something with wifi is not as good as previous version.
It does connect, but times out a lot.
I created a macro that turns the wifi module off/on just to help in reconnecting.Once connected it stays connected for the most part, until I begin a print. Then it usually times out after a 10-20 min into a print.
Getting it to reconnect after the print is just a hit/miss process of restarting the wifi, hitting connect repeatedly, rebooting, etc. I log into my routers page and see the IP assigned, it just has a hard time opening in a web page (safari).
I have a main router in the room behind, about 10' away, and a second router as an access point half a house away. Both use same name/ssid and pass.
When it is connected, if you run M122 what RSSI does it report?
Heres the network section
Network state is running
WiFi firmware version 1.19
WiFi MAC address 5c:cf:7f:a4:a1:64
WiFi Vcc 3.12, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 39168
WiFi IP address 192.168.2.53
WiFi signal strength -35dBm
HTTP sessions: 2 of 8
Socket states: 2 0 0 0 0 0 0 0
Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) -
You have a very strong signal! I don't think I have seen a RSSI as high as -35 before.
You appear to have 2 active http sessions, which I think means you have connected from 2 different IP addresses. Is that correct?
at times I've connected from a second laptop yes. But that is not always the case.
Much of the time I am only connected via the one laptop.
