    Issues after prime
    Beta Firmware
    6.3k
      Can you enter your motor values and settings into this EMF calculator and see if maybe we're in the range where back emf becomes an issue.
      https://www.reprapfirmware.org/emf.html
      Heartleander81undefined 2 Replies Last reply Reply Quote 0
      • Heartleander81undefined
        Heartleander81 @Phaedrux
        @phaedrux Ok.
            Heartleander81
            Oh I have Look on the wrong stepper. X and Y can 2.1A
              dc42 administrators @Heartleander81
              @heartleander81 said in Issues after prime:
              when I delete the first retract G1 E-0.600 F1200 the error is gone. But this is created by the slicer and I cannot prevent this.
              That sounds similar to the reports from two other users: an axis move right after an extruder move on a tool boards shows the problem. I don't want you to remove the retractions, I want you to help me pin down the problem. by developing the simplest possible test case that causes the problem.
              Did you try the test file I posted earlier?
              Heartleander81undefined 1 Reply Last reply Reply Quote 0
                Heartleander81 @dc42
                @dc42 oh. No not. When my child sleep I can test it. In 15-30 min I give a feedback
                should I use the g-code in the same way or turn the temperature on again and turn off cold extrusion?
                dc42undefined 2 Replies Last reply Reply Quote 0
                  @heartleander81 thanks. What I am looking for is the simplest possible test case. The ingredients that appear to cause it are:
                  • A tool change;
                  • A short extruder-only movement (typically a retraction), where the extruder is connected to a tool board;
                  • Then under some conditions, the following axis movement happens incorrectly.
                  The length of the extruder-only movement affects whether the problem occurs or not. I don't know whether the tool change is a necessary condition for the problem to happen, or if it is, whether the contents of the tool change files are relevant.
                    You can try it with heating first if you like. If the problem occurs, try simplifying the file as much as possible until you find a very simple test case. As part of this simplification, you could copy the contents of startGcode into the test file instead of calling it with M98.
                    Related thread: https://forum.duet3d.com/topic/24553/rrf-3-3-does-not-respect-max-accel-in-first-moves-after-tc
                      @dc42 ok. I have time 😉
                        With your code the same issuse.
                        When i comment out the line 28 ( G1 E-0.600 F1200 )
                        Run the Printer with no Problem. I have a Video when you whant
                        G90
                        M83
                        M302 P1 ;;dc
                        T-1 ;;dc
                        M106 S0
                        G4 S1 ;;dc
                        ;;M140 S50
                        ;;M190 S50
                        ;;M104 S240 T0
                        ;;M109 S240 T0
                        T0
                        M150 R255 B235 U255 P128 S60 ;LED weiß
                        G32
                        ;G29 S1 P"heightmap.csv"   ;SB
                        M83
                        G1 X5 Y5 Z30 F6000.0
                        G1 E50 F500
                        G1 E30 F200
                        G1 Y20 F2000
                        G1 Y50 Z0.2 F3000
                        G1 Y90 E20 F300
                        G1 Y120 F1200
                        G92 E0.0
                        ; process CR3D 0.4
                        ; layer 1, Z = 0.200
                        T0
                        ;G1 E-0.6000 F1200   ;SB
                        ; feature skirt
                        ; tool H0.200 W0.440
                        G1 Z0.200 F600
                        G1 X118.950 Y122.494 F12600
                        ;G1 X19.489 Y53.567 F12600
                        ;G1 E0.6000 F1200
                        ;G1 X280.511 Y53.567 E8.9768 F1800
                        ; layer end
                        T0
                        ;;dc M98 P"endGcode"
                          Heartleander81
                          LINE 14 and 28 is comment out. You See on the end ;SB
                          That is the Code who run without issuse
                            @heartleander81 thanks! If you reinstate line 28 and comment out the M150 lines and also the G32 line, does the problem remain?
                              @dc42 have I do. The issuse is back
                                You said that the following axis suddenly causes problems after the extrusion? Then I think of a "misprint" that I made with the toolboard. The paragraph should not be but a plan. See the following picture
                                  Heartleander81
                                  ok i misunderstood something. I will gradually comment out and test each line from top to bottom.
                                    Heartleander81 @Heartleander81
                                    With line 14 have I the issuse and without is all ok
                                    G90
                                    M83
                                    M302 P1 ;;dc
                                    T-1 ;;dc
                                    M106 S0
                                    G4 S1 ;;dc
                                    ;;M140 S50
                                    ;;M190 S50
                                    ;;M104 S240 T0
                                    ;;M109 S240 T0
                                    T0
                                    M83
                                    ;G1 Y50 Z0.2 F3000 after comment out this line looks out run without issuse
                                    G1 Y90 E20 F300
                                    G1 Y120 F1200
                                    G92 E0.0
                                    ; process CR3D 0.4
                                    T0
                                    ; feature skirt
                                    G1 Z0.200 F600
                                    ;G1 E0.6000 F1200
                                    ; layer end
                                    T0
                                      @heartleander81 thanks again. What about lines 17 and 20: if they are commented out and line 14 reinstated, does the problem occur?
                                        After I comment out Line 20 its all good
                                          @heartleander81 thanks again!
                                            Heartleander81
                                            I was able to issolate / fix the error by going to Z0.3 in line 14 with the long code.
                                            I also tested things at the same time. Maybe that will help you
