    BLTouch Won't deploy
    2.2k
    • eegroegundefined
      eegroeg @Phaedrux
      @phaedrux Ah well now it is back to no response again... I can confirm nothing is in macros I am using IO_7 🙂
      My Printer
      Send code...
      Status
      Idle
      Mode: FFF
      Tool Position
      X
      0.0
      Y
      0.0
      Z
      0.00
      Extruder Drives
      Drive 0
      0.0
      Speeds
      Requested Speed
      0 mm/s
      Top Speed
      0 mm/s
      Sensors
      Vin
      23.9 V
      V12
      12.1 V
      MCU Temperature
      33.6 °C
       Tools
       Extra
       Control Heaters
      Tool	Heater	Current	Active	Standby
      Tool 0
      T0 - Load Filament	Heater 1
      off	21.8 °C
      0
      0
      Temperature Chart
      System Directory
      0:/sys/config.g
      ; generated by RepRapFirmware Configuration Tool v3.3.0 on Sun Aug 15 2021 14:13:39 GMT+0100 (British Summer Time)
      G90                                                   ; send absolute coordinates...
      M83                                                   ; ...but relative extruder moves
      M550 P"My Printer"                                    ; set printer name
      M552 P0.0.0.0 S1                                      ; enable network and acquire dynamic address via DHCP
      M586 P0 S1                                            ; enable HTTP
      M586 P1 S0                                            ; disable FTP
      M586 P2 S0                                            ; disable Telnet
      M569 P0.0 S1                                          ; physical drive 0.0 goes forwards
      M569 P0.1 S1                                          ; physical drive 0.1 goes forwards
      M569 P0.2 S1                                          ; physical drive 0.2 goes forwards
      M569 P0.4 S1                                          ; physical drive 0.4 goes forwards
      M584 X0.0 Y0.1 Z0.2:0.3 E0.4                          ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                               ; configure microstepping with interpolation
      M92 X160.00 Y160.00 Z5120.00 E420.00                  ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00                   ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00               ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00                   ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30                          ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                               ; Set idle timeout
      M208 X0 Y0 Z0 S1                                      ; set axis minima
      M208 X500 Y500 Z750 S0                                ; set axis maxima
      M574 X1 S1 P"io0.in"                                  ; configure active-high endstop for low end on X via pin io0.in
      M574 Y1 S1 P"io1.in"                                  ; configure active-high endstop for low end on Y via pin io1.in
      M574 Z1 S2 P"io7.in"                                  ; configure Z-probe endstop for low end on Z
      M950 S0 C"io7.out"                                    ; create servo pin 0 for BLTouch
      M558 P9 H4 F120 T6000                      			  ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X37.5 Y10 Z2.5                               ; set Z probe trigger value, offset and trigger height
      M557 X15:215 Y15:215 S20                              ; define mesh grid
      ;M308 S0 P"temp0" Y"thermistor" T100000 B4138          ; configure sensor 0 as thermistor on pin temp0
      ;M950 H0 C"out0" T0                                    ; create bed heater output on out0 and map it to sensor 0
      ;M307 H0 B1 S1.00                                      ; enable bang-bang mode for the bed heater and set PWM limit
      ;M140 H0                                               ; map heated bed to heater 0
      ;M143 H0 S120                                          ; set temperature limit for heater 0 to 120C
      M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1                                    ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 B0 S1.00                                      ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                          ; set temperature limit for heater 1 to 280C
      M950 F0 C"out4" Q500                                  ; create fan 0 on pin out4 and set its frequency
      M106 P0 S0 H-1                                        ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"out5" Q500                                  ; create fan 1 on pin out5 and set its frequency
      M106 P1 S1 H1 T45                                     ; set fan 1 value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                                   ; define tool 0
      G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
      G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"    ; set voltage thresholds and actions to run on power loss
      ; deployprobe.g
      ; called to deploy a physical Z probe
      M280 P0 S10 ; deploy BLTouch
      ; retractprobe.g
      ; called to retract a physical Z probe
      M280 P0 S90 ; retract BLTouch
      George
      eegroegundefined 1 Reply Last reply Reply Quote 0
      • eegroegundefined
        eegroeg @eegroeg
        @Phaedrux I also am struggling to update it, when I upload the ZIP then run the M115 command after reboot I get...
        	M115
        FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.2.2 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2021-02-11
        George
        eegroegundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
        • eegroegundefined
          eegroeg @eegroeg
          @eegroeg I can confirm BLTouch is now Probing with M280 P0 S10/M280 P0 S90
          George
            @eegroeg said in BLTouch Won't deploy:
            Your command isn't correct. You're missing the pin name. You need:
            M558 P9 C"^io7.in" H4 F120 T6000
            Change that and send M98 P"config.g" again.
              Phaedrux Moderator @eegroeg
              	M115
              Where are you uploading it to? Should be the system tab.
              • eegroegundefined
                eegroeg
                @phaedrux That's great now M401 and M402 work! Thank you 🙂
                George
                • eegroegundefined
                  eegroeg @Phaedrux
                  @phaedrux Yeah I am in system tab and hit "upload system files then select the zip files which uploads them but when rebooting and running M115 no change.
                  George
                    Are you uploading the zip file as is? Don't extract it first.
                    • eegroegundefined
                      eegroeg
                      @phaedrux Yeah I upload the zip as it is from my downloads and it uploads a load of items then restarts and M115 gives me the same output that it is still on M115
                      George
                        Try sending m997 in the console
                        • eegroegundefined
                          eegroeg
                          @phaedrux said in BLTouch Won't deploy:
                          m997
                          That's done it. Thank you for all your help BLTouch is working now and printer is updated 🙂
                          George
                            Can you post the results of M122?
                            Can you check the version of DWC as well?
                            • eegroegundefined
                              eegroeg
                              M122
                              Sorry for the delay please see my M122 results below. I am on DWC version 3.3.0
                              	M122
                              RepRapFirmware for Duet 3 MB6HC version 3.3 (2021-06-15 21:45:47) running on Duet 3 MB6HC v1.01 or later (standalone mode)
                              Board ID: 08DJM-9P63L-DJMSS-6J9FD-3S86R-TBD39
                              Used output buffers: 3 of 40 (13 max)
                              Static ram: 150904
                              Dynamic ram: 91676 of which 0 recycled
                              Never used RAM 111612, free system stack 206 words
                              Tasks: NETWORK(ready,30.3%,212) ETHERNET(notifyWait,0.2%,117) HEAT(notifyWait,0.0%,331) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,333) TMC(notifyWait,7.5%,93) MAIN(running,61.5%,1092) IDLE(ready,0.4%,29), total 100.0%
                              Owned mutexes:
                              Last reset 00:00:28 ago, cause: power up
                              Last software reset at 2021-08-31 21:43, reason: User, GCodes spinning, available RAM 108404, slot 0
                              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
                              Error status: 0x00
                              Step timer max interval 140
                              MCU temperature: min 19.1, current 27.7, max 27.9
                              Supply voltage: min 23.9, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                              12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
                              Driver 0: position 0, standstill, reads 25303, writes 14 timeouts 0, SG min/max 0/0
                              Driver 1: position 0, standstill, reads 25303, writes 14 timeouts 0, SG min/max 0/0
                              Driver 2: position 0, standstill, reads 25303, writes 14 timeouts 0, SG min/max 0/0
                              Driver 3: position 0, standstill, reads 25303, writes 14 timeouts 0, SG min/max 0/0
                              Driver 4: position 0, standstill, reads 25303, writes 14 timeouts 0, SG min/max 0/0
                              Driver 5: position 0, standstill, reads 25307, writes 11 timeouts 0, SG min/max 0/0
                              Date/time: 2021-08-31 21:48:07
                              Slowest loop: 7.54ms; fastest: 0.05ms
                              === Storage ===
                              Free file entries: 10
                              SD card longest read time 2.1ms, write time 0.0ms, max retries 0
                              DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                              === MainDDARing ===
                              === AuxDDARing ===
                              Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
                              Segments left: 0
                              Movement lock held by null
                              HTTP is idle in state(s) 0
                              Telnet is idle in state(s) 0
                              File is idle in state(s) 0
                              USB is idle in state(s) 0
                              Aux is idle in state(s) 0
                              Trigger is idle in state(s) 0
                              Queue is idle in state(s) 0
                              LCD is idle in state(s) 0
                              SBC is idle in state(s) 0
                              Daemon is idle in state(s) 0
                              Aux2 is idle in state(s) 0
                              Code queue is empty.
                              === CAN ===
                              Messages queued 254, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 49 (min 49), ts 142/0/0
                              Tx timeouts 0,0,141,0,0,111 last cancelled message type 30 dest 127
                              === Network ===
                              Slowest loop: 15.23ms; fastest: 0.02ms
                              HTTP sessions: 2 of 8
                              - Ethernet -
                              State: active
                              Error counts: 0 0 1 0 0
                              George
