    Uploading multiple files to multiple printers
    • markduetundefined
      markduet
      What would be the most efficient and recommended way to upload gcode files to 2 or more machines/duet board SD cards? I tried to use FIlezilla, but having problems. I want to delete and upload several files to multiple machines, and I do this whenever the version of my design file gcode changes. Currently I do this manually to each machine, but wondered if there is a more efficient way to do this repetitive process, something analogous to a batch file.
        Probably with CURL.
        If you do a forum search for curl you'll find some examples.
        markduetundefined 1 Reply Last reply Reply Quote 0
        • markduetundefined
          markduet @Phaedrux
          @phaedrux Sounds perfect! Makes my day better reading this.
