Duet 3 IDEX resets at consistent position
Hi All,
I've put together an idex printer which usually works quite well. I'm using Cura as the slicer. I have been trying to print the following part, and the machine seems to reset/lose power at a consistent position.
My cabling seems fine, and I suspect my gcode is the issue. I've tried reslicing it and changing a few parameters eg turn of coast, z hop etc with no luck. The print seems to reset on layer 5, when tool T1 begins to print.
I have attached my m122, config.g and g code below.
Thanks in advance!
M122 report
M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (standalone mode) Board ID: 08DJM-956L2-G43S8-6J1D6-3S46T-KU2QF Used output buffers: 1 of 40 (29 max) === RTOS === Static ram: 154604 Dynamic ram: 163416 of which 96 recycled Exception stack ram used: 312 Never used ram: 74788 Tasks: NETWORK(ready,228) ETHERNET(blocked,404) HEAT(blocked,1104) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1424) TMC(blocked,204) MAIN(running,4528) IDLE(ready,76) Owned mutexes: === Platform === Last reset 00:27:25 ago, cause: power up Last software reset at 2021-08-24 10:39, reason: User, spinning module GCodes, available RAM 74580 bytes (slot 3) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN Error status: 0 MCU temperature: min 32.0, current 33.0, max 34.5 Supply voltage: min 23.8, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0 Driver 0: standstill, reads 23554, writes 14 timeouts 0, SG min/max 0/0 Driver 1: standstill, reads 23554, writes 15 timeouts 0, SG min/max 0/0 Driver 2: standstill, reads 23555, writes 14 timeouts 0, SG min/max 0/0 Driver 3: standstill, reads 23556, writes 14 timeouts 0, SG min/max 0/0 Driver 4: standstill, reads 23556, writes 14 timeouts 0, SG min/max 0/0 Driver 5: standstill, reads 23556, writes 14 timeouts 0, SG min/max 0/0 Date/time: 2021-08-24 11:25:40 Slowest loop: 53.69ms; fastest: 0.21ms === Storage === Free file entries: 10 SD card 0 detected, interface speed: 25.0MBytes/sec SD card longest read time 26.9ms, write time 1.8ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 522351ms Bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves: 47569, completed moves: 47569, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 28.65ms; fastest: 0.03ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions HTTP sessions: 1 of 8 - Ethernet - State: active Error counts: 0 0 0 0 0 Socket states: 5 2 2 2 2 0 0 0 === Filament sensors === Extruder 0 sensor: ok Extruder 1 sensor: ok === CAN === Messages sent 6582, longest wait 0ms for type 0 === Linux interface === State: 0, failed transfers: 0 Last transfer: 1645819ms ago RX/TX seq numbers: 0/1 SPI underruns 0, overruns 0 Number of disconnects: 0 Buffer RX/TX: 0/0-0
Config.g
; Configuration file for Duet 3 (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Mar 31 2021 21:23:47 GMT+1100 (Australian Eastern Daylight Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"duet" ; set printer name ; Network M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0.0 S0 ; physical drive 0.0 goes forwards: idex 1 M569 P0.1 S1 ; physical drive 0.1 goes forward: idex 2 M569 P0.2 S0 ; physical drive 0.2 goes backwards: y axis M569 P0.3 S0 ; Z axis M569 P0.4 S1 ;Extruder 1 M569 P0.5 S1 ; extruder 2 M584 X0.0 U0.1 Y0.2 Z0.3 E0.4:0.5 ; set drive mapping M350 X16 U16 Y16 Z16 E16 i1 ; configure microstepping with interpolation M92 X80.00 U80 Y80.00 Z400.00 E394.20:394.2 ; set steps per mm M566 X700.00 U700 Y700.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X12000.00 U12000 Y12000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 U500 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X800 u800 Y725 Z1900 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout M911 S21.0 R23.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; if voltage drops <21v ; Axis Limits M208 x-100 u0 y0 z0 s1 ; set axis minima m208 x420 u523 y380 z400 s0 ; Endstops M574 X1 S1 P"io2.in" ; configure active-high endstop for low end on X via pin io4.in M574 Y1 S1 P"io3.in" ; configure active-high endstop for high end on Y via pin io3.in M574 U2 S1 P"!io5.in" M915 U R0 F0 M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M950 S0 C"io7.out" ; create servo pin 0 for BLTouch M558 P9 C"io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds;G31 P500 X-41 Y5 Z2.5 ; set Z probe trigger value, offset and trigger height G31 P500 X32.5, Y-42 z.95 M557 X60:420 Y0:330 S40 ; define mesh grid M280 P0 S90 ; Heaters ;Bed M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 - Heated BED M950 H0 C"out1" T0 ; create bed heater output on out2 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120; set temperature limit for heater 0 to 120C ;Extruder 1 M308 S1 P"temp1" Y"thermistor" T165000 B4725 c7.06e-8 R2200 ; configure sensor 1 as thermistor on pin temp1 - Extruder 1 M950 H1 C"out2" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ;Extruder 2 M308 S2 P"temp2" Y"thermistor" T100000 B4725 c7.06e-8 ; configure sensor 1 as thermistor on pin temp1 - Extruder 1 M950 H2 C"out3" T2 ; create nozzle heater output on out1 and map it to sensor 1 M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H2 S280 ; set temperature limit for heater 1 to 280C ; Fans ; Extruder 1 - part fan M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency m106 p0 s0 ; set fan 0 value. Thermostatic control is turned on ; Extruder 2 - hot end fan M950 F1 c"out8" Q500 m106 p1 s1 h2 ; Extruder 2 - part fan ;Part fan M950 F2 c"out9" q500 ; create fan 1 on pin out8 and set its frequency M106 P2 S0 ; Custom settings are not defined ;''' Tool configuration section of config.g''' ;''' Create a tool that uses the low end (X) carriage''' M563 P0 S"Extuder A" D0 H1 F0 ; tool 0 uses extruder 0, heater 1 and fan 0 G10 P0 X0 Y0 Z0 S0 R0 ; set tool 0 offsets and temperatures M591 P1 C"io4.in" S1 D0 ; filament monitor connected to E0 endstop M591 P2 C"io1.in" S1 D1 ;''' Create a tool that uses the high end (U) carriage''' M563 P1 S"Extruder B" D1 H2 X3 F3 ; tool 1 uses extruder 1, heater 2, fan 2, and maps X to U G10 P1 Y-1 U0 Z7 S0 R0 M671 X80:460:460:80 Y300:300:-35:-35 P0.5 ; Miscellaneous M501 ; load saved parameters from non-volatile memory M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss M207 S2.0 F2400 Z.3 M929
@akayoshi you're still on firmware 3.1.1
I highly recommend updating to 3.3.0 and seeing if your problem is sorted -
