    Duex 2 disabling X,Y and Z axis
    494
    • BR549undefined
      BR549 @Phaedrux
      @phaedrux The page I referenced in the post said Duex is supported in firmware 1.16 and later. No mention was made of config changes. Basically check the wiring is correct and plug in. M115 reports Duet2 and Duex2, heaters work but not the steppers.Duet config.png
        Where are the steppers plugged in? Your config is only defining the drivers on the Duet2.
        The Duex drivers will need M569 definitions and any axis using those drivers must be defined in M584.
        BR549undefined 2 Replies Last reply Reply Quote 0
        • BR549undefined
          BR549 @Phaedrux
          @phaedrux Yes I know, but is the Duet steppers being disabled because the Duex is plugged in normal ? I don't want to change a working config just to find out that defining steppers on the Duex doesn't work. My plan was to add the Duex and then set up the Z drivers, but a spanner got thrown in when the Duet steppers stopped operation
          • BR549undefined
            BR549 @Phaedrux
            @phaedrux The stepper cables are plugged in as the config shows. All I did was add the Duex, then came to a halt because of the title of the post
              Post a photo of your wiring. Adding the Duex won't change any drivers already in use on the Duet.
              I wasn't sure if you meant you connected motors to the Duex, or if they were still connected to the Duet.
              Also post the results of M122 when the Duex is connected please.
              BR549undefined 1 Reply Last reply Reply Quote 0
              • BR549undefined
                BR549 @Phaedrux
                @phaedrux Do you want a photo of the supply to the Duex and the ribbon cable ?
                It's late now where I am so will do it tomorrow morning as the Duex is not currently connected
                  dc42 administrators @BR549
                  @br549 do you perhaps have the ribbon cable connected to the DueX, but no VIN power supplied to the DueX? I think that may prevent the drivers on the Duet being programmed.
                  • BR549undefined
                    BR549 @dc42
                    @dc42 No, both the supply and the ribbon were connected. No magic smoke leaked and M115 reported Duet 2 and Duex 2
                    • BR549undefined
                      BR549 @dc42
                        @br549 what does M122 report ?
                        • BR549undefined
                          BR549 @dc42
                          @dc42 Thanks for your help. It turned out to be a break in the supply circuit. Your comment made me investigate the incoming power. At the Duex incoming power terminals I measured 24v but there was a dry joint on the neutral connection to the board, manufacturing fault. I resoldered it and now everything is working as it should. Once again, thank you
