M584 doesn't work with axis drives
Hi all,
We are getting an error at M584. Our command is:
M584 X40.0 Y41.0:42.0 Z43.0 U44.0 V45.0 ; axis drive mapping But this is working, and extruder drives are declared correctly
M584 E20.0:21.0:22.0; extruders drive mapping Out firmware version is 3.4beta3. Each extruder uses a 1LC board, and the axis use 1XD board.
Thanks in advance
@carlosr is each board being correctly identified? i.e. if you send M122 B40, is the correct information displayed?
Could you post the above output from one of the 1XD? -
@jay_s_uk Yes, it seems to be correctly connected
@jay_s_uk Yes, we have a "G4 S3" that waits for boards to start before running the M584
@carlosr ok, not much else I can add here. Please post your config.g for completeness anyway
Our config.g it is very messy and complex, don't think it would help you to understand the problem.
My feeling is that it is related to the 1XD board...
Just a point, it worked properly before upgrading to 4.3beta3.
@carlosr do the following commands work:
M584 X40.0
M569 P40.0Also, please can you construct a simple config.g file that reproduces the problem.
