    M584 doesn't work with axis drives
    Beta Firmware
    288
    • CarlosRundefined
      CarlosR
      Hi all,
      We are getting an error at M584. Our command is:
      M584 X40.0 Y41.0:42.0 Z43.0 U44.0 V45.0 ; axis drive mapping
      But this is working, and extruder drives are declared correctly
      M584 E20.0:21.0:22.0; extruders drive mapping
      Out firmware version is 3.4beta3. Each extruder uses a 1LC board, and the axis use 1XD board.
      Thanks in advance
        jay_s_uk @CarlosR
        @carlosr is each board being correctly identified? i.e. if you send M122 B40, is the correct information displayed?
        Could you post the above output from one of the 1XD?
        CarlosRundefined 1 Reply Last reply Reply Quote 0
        • CarlosRundefined
          CarlosR @jay_s_uk
          @jay_s_uk Yes, it seems to be correctly connected
          jay_s_ukundefined 1 Reply Last reply Reply Quote 1
            jay_s_uk @CarlosR
            @carlosr and one last question, I'm assuming the M584 in your config is taking place after a delay has been inserted? e.g. G4 S2 as instructed here
            CarlosRundefined 1 Reply Last reply Reply Quote 1
            • CarlosRundefined
              CarlosR @jay_s_uk
              @jay_s_uk Yes, we have a "G4 S3" that waits for boards to start before running the M584
                jay_s_uk @CarlosR
                @carlosr ok, not much else I can add here. Please post your config.g for completeness anyway
                • CarlosRundefined
                  CarlosR @jay_s_uk
                  @jay_s_uk
                  Our config.g it is very messy and complex, don't think it would help you to understand the problem.
                  My feeling is that it is related to the 1XD board...
                  Just a point, it worked properly before upgrading to 4.3beta3.
                  • CarlosRundefined
                    CarlosR @CarlosR
                    Any ideas on this?
                    It worked properly on the 3.4beta2+ you shared with @Marcossf, we just upgraded to 3.4beta3 to fix the temperature sensor issues, but now the M584 doesn't work.
                      dc42 administrators @CarlosR
                      @carlosr do the following commands work:
                      M584 X40.0
                      M569 P40.0
                      Also, please can you construct a simple config.g file that reproduces the problem.
