    Reset from reset botton
    425
    • lodgerundefined
      lodger
      My printer keeps resetting and i am trying to narrow the issuse down.
      My M122 says reset button has caurse it. This happens in both standalone and SBC,
      Yesterday i did update to b3 firmware but have since dropped back to 3.3 stable. Before i updated the printer was fine. and i did not try to print last night , It was late and bed time !
      It resets as soon as i start printing . So i have tried a old Gcode which printed fine before but same again.
      Anyone got anyideas.
      	M122
      RepRapFirmware for Duet 3 Mini 5+ version 3.3 (2021-06-15 21:46:11) running on Duet 3 Mini5plus WiFi (standalone mode)
      Board ID: 9Y0D5-4396U-D65J0-40KM2-LF03Z-ZRMYB
      Used output buffers: 3 of 40 (20 max)
      Static ram: 102724
      Dynamic ram: 106152 of which 36 recycled
      Never used RAM 34792, free system stack 198 words
      Tasks: NETWORK(ready,11.6%,226) HEAT(notifyWait,0.0%,358) Move(notifyWait,0.1%,362) CanReceiv(notifyWait,0.0%,941) CanSender(notifyWait,0.0%,371) CanClock(delaying,0.0%,340) TMC(notifyWait,1.1%,115) MAIN(running,84.8%,412) IDLE(ready,1.6%,29) AIN(delaying,0.8%,273), total 100.0%
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:00:14 ago, cause: reset button
      Last software reset at 2021-08-25 19:52, reason: User, GCodes spinning, available RAM 34792, slot 1
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x00
      Aux0 errors 0,0,0
      MCU revision 3, ADC conversions started 14341, completed 14340, timed out 0, errs 0
      Step timer max interval 751
      MCU temperature: min 40.1, current 41.2, max 41.2
      Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 22, reads 1273, writes 9, timeouts 0, DMA errors 0
      Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 21, reads 1272, writes 9, timeouts 0, DMA errors 0
      Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 21, reads 1272, writes 9, timeouts 0, DMA errors 0
      Driver 3: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 21, reads 1272, writes 9, timeouts 0, DMA errors 0
      Driver 4: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 22, reads 1272, writes 9, timeouts 0, DMA errors 0
      Driver 5: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 21, reads 1272, writes 9, timeouts 0, DMA errors 0
      Driver 6: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 1272, writes 9, timeouts 0, DMA errors 0
      Date/time: 2021-08-25 20:22:37
      Cache data hit count 27239000
      Slowest loop: 5.09ms; fastest: 0.12ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 0.5ms, write time 0.0ms, max retries 0
      === MainDDARing ===
      === AuxDDARing ===
      Bed heaters = 0 -1, chamberHeaters = -1 -1
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === CAN ===
      Messages queued 128, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17), ts 72/0/0
      Tx timeouts 0,0,71,0,0,55 last cancelled message type 30 dest 127
      === Network ===
      Slowest loop: 15.87ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is active
      WiFi firmware version 1.26
      WiFi MAC address f4:cf:a2:70:32:3b
      WiFi Vcc 3.40, reset reason Power up
      WiFi flash size 2097152, free heap 25624
      WiFi IP address 10.174.1.101
      WiFi signal strength -60dBm, mode 802.11n, reconnections 0, sleep mode modem
      Clock register 00002002
      • fcwiltundefined
        fcwilt @lodger
        @lodger
        How is your reset button connected? Perhaps you are responding to the wrong button state.
        lodgerundefined 1 Reply Last reply Reply Quote 0
        • lodgerundefined
          lodger @fcwilt
          @fcwilt I have not wired a reset in .
            Have you tried pressing/inspecting the button yourself? Is it stuck in or something?
            • lodgerundefined
              lodger @Phaedrux
              @phaedrux It looks fine . when i press it it clicks as it should. and pops out again as it should.
              I dont think its the button itself..
              • fcwiltundefined
                fcwilt @lodger
                @lodger said in Reset from reset botton:
                So you have a button but it is not connected?
                • lodgerundefined
                  lodger @fcwilt
                  @fcwilt Sorry i was thinking about the small button on the board itself. i have not wired or connected anything external
                  • lodgerundefined
                    lodger
                    So after a bit of hair pulling . I thought to myself ....It only resets when it starts to extrude.
                    So i powered the printer off and unpluged the exturders cable.
                    And she started happy printing in mid air. I quick dug out a spare stepper cable poorly tie rap it place and plug her in..Yes she is printer happy as can be.
                    So i did not know a crappy stepper cable can reset the duet.
                      Was the stepper cable shorting out to anything else?
                      • lodgerundefined
                        lodger @Phaedrux
                        @phaedrux No not really . I think it was just a lose joint / bad crimp. I did not get any driver errors nothing .
