    Software bundle 3.4.0 beta 3 now available
    Beta Firmware
    13
    30
    2.0k
    • Diamondbackundefined
      Diamondback
      I just tried upgrading to 3.4b3 from 3.3. Unfortunately my Y homing doesn't work correctly anymore. I have my origin in the middle of the bed, with Y homing against the minimum of that axis (-149). With 3.4b3, the machine instead thinks it's at Y0 after homing.
      jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @Diamondback
        @diamondback post your homing files. probably best to start a new thread
          dc42 administrators @Diamondback
          @diamondback yes please create a new thread and post your config.g and homing files in it.
          oozeBotundefined 1 Reply Last reply Reply Quote 1
          • KevinMarundefined
            KevinMar
            I'd like to confirm that this beta fixed an issue I had with a tool board reading very erratic thermistor values which spiked up and down constantly.
            Thanks!
            • oozeBotundefined
              oozeBot @dc42
              @dc42 The addition of stepper braking is a game changer and fixed several issues for us! Thank you. Will you please confirm the following is the correct syntax? It's working, but the example didn't show multiple motors on a single port. Thanks
              M569.7 P0.0:0.2 C"0.out3"
                dc42 administrators @oozeBot
                @oozebot all the M569.x commands take only a single P parameter.
                oozeBotundefined 1 Reply Last reply Reply Quote 0
                • oozeBotundefined
                  oozeBot @dc42
                  @dc42 Hmm.. our two stepper motor brakes are wired together. Can C"0.out3" be defined twice? Once per motor? Or am I overthinking it? Thanks
                    @oozebot assuming those motors are used for the same axis, they will always be enabled or disabled together. Therefore you need only declare the brake port for one of the motors.
                      Diamondback
                      Does anyone else have the issue that M122 from DWC does not produce any output on the console?
                        @diamondback that's a known issue. Duet 2 WiFi I assume?
                        Diamondbackundefined 1 Reply Last reply Reply Quote 1
                          Diamondback @jay_s_uk
                          @jay_s_uk Correct, thanks for the info 🙂
