    Software bundle 3.4.0 beta 3 now available
    Beta Firmware
    13
    30
    2.0k
    • Blacksheep99undefined
      Blacksheep99 @dc42
      @dc42 Thanks. I’ll leave the Maestro in then and look to hook the accelerometer when I have time. Look forward to testing the functionality
      • Sotidiiundefined
        Sotidii @dc42
        @dc42 Thanks!!
        • SIamundefined
          SIam @dc42
          @dc42 have you forgot to look after the idle problem? It's still not working here
          Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
          Duet WiFi 1.02 or later + DueX5
          RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
          Duet WiFi Server: 1.26
          Duet Web Control 3.4.0beta4 (2021-09-27)
            dc42 administrators @SIam
            @siam said in Software bundle 3.4.0 beta 3 now available:
            That one is still on my list to look into.
            SIamundefined 1 Reply Last reply Reply Quote 0
            • SIamundefined
              SIam @dc42
              @dc42 Okay Thank you !!!
              • Fred-Yundefined
                Fred-Y
                @dc42 My printer doesn't seem to hung anymore (https://forum.duet3d.com/topic/24694/3-4-0beta2-printer-stop-mid-print-with-no-reason-errors), I ran the gcode file that caused some troubles and it appears to be fine 👍
                I'm going to run more prints within the next few days and also do some testing on my delta.
                • Aitorundefined
                  Aitor @dc42
                  Good morning @dc42,
                  I'm testing the new echo functionality, it doesn't allow me to put tabulation, as shown in this example:
                  echo >>"config1.g" "G90 (tabulation) ; Enviar coordenadas absolutas"
                  Is there any way to put them, or I forget about them?
                    @aitor I'll make a note to look into this. Meanwhile, I suggest you use spaces instead.
                    • Diamondbackundefined
                      Diamondback
                      I just tried upgrading to 3.4b3 from 3.3. Unfortunately my Y homing doesn't work correctly anymore. I have my origin in the middle of the bed, with Y homing against the minimum of that axis (-149). With 3.4b3, the machine instead thinks it's at Y0 after homing.
                      jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
                        jay_s_uk @Diamondback
                        @diamondback post your homing files. probably best to start a new thread
                          dc42 administrators @Diamondback
                          @diamondback yes please create a new thread and post your config.g and homing files in it.
                          oozeBotundefined 1 Reply Last reply Reply Quote 1
                          • KevinMarundefined
                            KevinMar
                            I'd like to confirm that this beta fixed an issue I had with a tool board reading very erratic thermistor values which spiked up and down constantly.
                            Thanks!
                            • oozeBotundefined
                              oozeBot @dc42
                              @dc42 The addition of stepper braking is a game changer and fixed several issues for us! Thank you. Will you please confirm the following is the correct syntax? It's working, but the example didn't show multiple motors on a single port. Thanks
                              M569.7 P0.0:0.2 C"0.out3"
                                dc42 administrators @oozeBot
                                @oozebot all the M569.x commands take only a single P parameter.
                                oozeBotundefined 1 Reply Last reply Reply Quote 0
                                • oozeBotundefined
                                  oozeBot @dc42
                                  @dc42 Hmm.. our two stepper motor brakes are wired together. Can C"0.out3" be defined twice? Once per motor? Or am I overthinking it? Thanks
                                    @oozebot assuming those motors are used for the same axis, they will always be enabled or disabled together. Therefore you need only declare the brake port for one of the motors.
                                      Diamondback
                                      Does anyone else have the issue that M122 from DWC does not produce any output on the console?
                                        @diamondback that's a known issue. Duet 2 WiFi I assume?
                                        Diamondbackundefined 1 Reply Last reply Reply Quote 1
                                          Diamondback @jay_s_uk
                                          @jay_s_uk Correct, thanks for the info 🙂
