    Mesh compensation results backwards
    4.3k
    • fcwiltundefined
      fcwilt @Gamefanatic3D
      @gamefanatic3d said in Mesh compensation results backwards:
      G1 X168.25 Y234.4 Z6
      Where does those X and Y values come from?
      They are different from the X and Y values you use in homez.g when setting the Z=0 Datum.
      Given that with a single tool printer the nozzle becomes the reference for checking the Z probe Z Trigger Height setting I'm thinking that to deal with multiple tools the tool 0 Z Offset setting would be 0 so you take the value out of the equation and you can now use the nozzle of that tool as your reference for checking the Z probe Z Trigger Height setting.
      Then you set the other tool(s) Z offset based on tool 0.
      Gamefanatic3Dundefined 2 Replies Last reply Reply Quote 0
      • Gamefanatic3Dundefined
        Gamefanatic3D @fcwilt
        @fcwilt
        I think this issue is related to a failing Z-Axis motor. I heard a noise once when letting things sit idle earlier today which resulted in an obvious deviation in the Z-Level. I thought this might be due to the motors going idle and possibly the bed falling. Normally with power off, I don't get more than 0.08 of drift between the two lead screws.
        However, I was printing just a moment ago and hit the pause button, but when I resumed I heard that noise again when the bed was lifting. So instead of continuing, I paused again and moved the X-Gantry to dead center between the lead screws and measured with my calipers from the top of the rails on either side with an approximately 2.3 mm deviation.
        I'm really hoping this is the root cause. They are the original motors operating for over 4 years on my inexpensive starter kit!
        I have to take a bit of it apart to get after them so that will have to wait until next weekend, time permitting!
          @fcwilt said in Mesh compensation results backwards:
          That is technically where the Probe - probes when I do my startup. The X/Y noted in the G1 command are where 0 would be at the time, in my case, it's the front of my tool plate (not including the shaft).
          The offset of my probe from that location is X31.75 Y-34.4.
          When I perform a G1 X200 Y200 the probe is actually probing at X168.25 Y234.4.
          Gamefanatic3Dundefined 1 Reply Last reply Reply Quote 0
            Gamefanatic3D @Gamefanatic3D
            @gamefanatic3d
            Okay I'm back and after much testing over the past week, I'm convinced there is nothing wrong with my Z-Motors, even though the issue I experienced was real. I believe the Duet may have just been having a moment as I was getting a homing error with negative values when performed the first homez.g after startup. Any future homing would be successful. This appears to have cleared itself up as easily as it came with me doing nothing to the system other than turning it off and back on a few times...
            Moving back to the issue at hand here I have mounted a Dial Indicator tool to my system and validated my original statement that the Z-Probing being done and recorded is in fact opposite of what I would expect.
            Note: I made the mount for the Dial Indicator such that I could probe with the BLTouch while having the Dial Indicator tool attached. I realize there is a tension that is created as the Dial Indicator gets closer to the end of its measuring.
            Probing at a point with the BLTouch will return a positive value to the homing file when it should in fact be a negative value.
            My BLTouch trigger value is 0.9.
            I validated this by performing the following procedure:
            Step 1: Setup
            • G28
            • Disable Mesh Compensation
            • Attach Dial Indicator tool. (Manual process for now)
            • G1 X180 Y227 Z6 (Move the BLTouch to a center point on bed)
            • G30
            • G1 X206.8 Y143.4 Z15 (Move Dial Indicator to same point on the bed with specific height/trigger point)
            • Set the Dial Indicator to 0.000
            Now I go to a spot on the bed shown on the heightmap that I know to be a low spot (further away from tools)
            Step 2: Probing Low
            • G1 X328.23 Y224.37 Z6
            • M98 P"/macros/Homing/Bed/MyMeshCompStep1"
            • G1 X355.03 Y140.77 Z15
            The result of BLTouch
            8/28/2021, 2:37:40 PM	G1 X355.03 Y140.77 Z15
            8/28/2021, 2:37:29 PM	Stopped at height 0.987 mm
            -0.085
            8/28/2021, 2:37:28 PM	M98 P"/macros/Homing/Bed/MyMeshCompStep1"
            Stopped at height 0.983 mm
            8/28/2021, 2:36:46 PM	G1 X328.23 Y224.37 Z6
            8/28/2021, 2:36:14 PM	G1 X206.8 Y143.4 Z15
            8/28/2021, 2:36:03 PM	G30
            Dial Indicator: -0.08
            I repeat this procedure 3 times in the same spot to validate any potential mechanical issues. Keeping in mind the dial indicator is not as accurate as of the BLTouch and validate the numbers are still roughly the same.
            The heightmap.g in this area is showing a positive value in this area. I believe this is due to the BLTouch returning a positive number when subtracting the two probing values which are greater than my trigger (Z-0) value.
            IE)
            Probe1 returns: 0.918
            Probe2 returns: 0.923
            The resulting value would be acceptable as it's within 0.005
            The value returned should be:
            -0.0205 = 0.9 - ((0.918+0.923)/2)
            But what is recorded in the heightmap is 0.0205
            This is my assumption of what is happening based on the heightmaps I am obtaining. I could be missing something here still...
            MyMeshCompStep1
            var probezHeight = 6
            var TravelSpeed = 6000
            var probezOne = 0
            var probezTwo = 0
            	while true
            		if iterations = 5
            			abort "Too many auto calibration attempts"
            		G1 Z{var.probezHeight} F{var.TravelSpeed}
            		G30 S-1
            		set var.probezOne = sensors.probes[0].lastStopHeight
            		G30 S-1
            		set var.probezTwo = sensors.probes[0].lastStopHeight
            		if var.probezOne - var.probezTwo <= 0.005
            			echo sensors.probes[0].triggerHeight-((var.probezOne + var.probezTwo)/2)
            			break
            fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
            • fcwiltundefined
              @gamefanatic3d
              In your MyMeshCompStep1 file you have
              Ignoring any floating point errors:
              if var.probezOne = 1.006 and var.probeTwo = 1.000 then var.probezOne - var.probezTwo = 0.006 and the test fails.
              if var.probezOne = 1.000 and var.probeTwo = 1.006 then var.probezOne - var.probezTwo = -0.006 and the test succeeds.
              In both cases the difference is 0.006.
              I don't understand what you are testing for.
              Also the number returned by G30 S-1 does not have a fixed relationship to the probe Z Trigger Height setting.
                Phaedrux Moderator @Gamefanatic3D
                Have you tried a homez.g without the conditional gcode?
                  Gamefanatic3D @Phaedrux
                  @phaedrux said in Mesh compensation results backwards:
                  I started off without the conditional code and only added it due to a recommendation by @fcwilt.
                    @gamefanatic3d
                    I'm attempting to get a height value from the BLTouch that represents the difference from Z-0 which I am interpreting to be in direct relation to when I run my G30.
                    In this case, I'm interested in the return values so I can better understand what is happening and see the variations. I'm not so sure how much it matters on the macro as it's not what's actually coming up with the heightmap values, I'm just using it to test my theory and why I can manually set my values in the heightmap vs using the BLTouch and the G29.
                    • fcwiltundefined
                      @gamefanatic3d
                      I just got back from testing on my printer. I setup the M557 to probe a 3x3 grid. I placed a 1mm thickness gauge at the point at the center of the grid. I created the height map. Below are the values. As you can see the 1mm thickness gauge is showing as a positive value which is as it should be.
                       -0.243, -0.082,  0.013
                       -0.217,  1.115,  0.050
                       -0.195, -0.053,  0.027
                      Here I used a larger and thicker object leaving it in place at the center of the bed so it's thickness was affecting the Z=0 Datum. As you can see the center point is now reading near 0 and all that other points are reading low by appx the thickness of the object.
                       -3.311, -3.171, -3.068
                       -3.306,  0.001, -3.036
                       -3.278, -3.145, -3.065
                      So all I can think of is your Z=0 Datum is off.
                        @fcwilt
                        Going with where you are headed I did 3 heightmaps. All will use the same points and were done with the bed at 70°C.
                        Map1
                        Normal height map
                         -0.050, -0.086,  0.053
                          0.067,  0.007,  0.090
                          0.251,  0.020, -0.019
                        Map2
                        Normal level with 0.8 feeler gauge put in after in the middle:
                         -0.031, -0.124, -0.038
                          0.061,  0.836, -0.013
                          0.242, -0.035, -0.120
                        Map3
                        0.8 feeler gauge in place when G30 performed:
                         -0.927, -0.969, -0.847
                         -0.833, -0.004, -0.807
                         -0.653, -0.874, -0.904
                        Now taking a look at just the difference between Map1 and Map2 we can see the obvious and expected difference at the middle point. I am a little plagued by the right values being nearly 0.1mm difference. I now wonder if this is my probe or my hardware.
                        When I run my Dial Guage out from the middle I get a negative value of ~ -0.14 after setting its Z-0 at my middle probing point. This is about what I expect based on my manual leveling.
                        https://youtu.be/GCf9Ta9aJSo
                        • fcwiltundefined
                          @gamefanatic3d
                          Hmm... Curious.
                          Some Z axis movement error perhaps?
                          What is your Z axis setup? What is the Z axis movement for one full stepper step - not a micro-step?
                            @fcwilt
                            So I'm not exactly sure how to move a single step, but mechanically this is how I am setup:
                            Dual 1.8° steppers w/ TR8*2 lead screws
                            M350 X16 Y16 Z16 E16:16 I1                ; Configure microstepping with interpolation
                            M92 X201.2499 Y201.2499 Z1601.584008 C100 E421.1332199:690    ; T8x2 1-Start Lead Screw
                            When I perform a single rotation of the Z motor my Dial Gauge reads 2mm at bed center, which is expected. It reads the same when moved to the lead screws and moved one full rotation.
                            Maybe I need to perform some tests for repeatability?
                            • fcwiltundefined
                              @gamefanatic3d
                              Great.
                              That's what I needed to know. You have plenty of resolution even at full steps. A 1.8 degree stepper has 200 steps per revolution. You have 2mm of movement per full revolution. Which means one full step moves 2mm / 200 or 0.01mm.
                              I have heard tell of inexpensive lead screws having poor linearity (moving the same amount for each revolution) . I don't know how common that may be. You could easily use the dial gauge to measure that at different Z positions if you have a 123 block or something to perform the same function.
                              I get my lead screws from these folks: McMaster Carr
                                @fcwilt
                                Thank you for your help up until now. I'll continue to do some testing later this week to see if this is motor-related.
                                I got my Lead Screws from ZYLTech a few years ago. Never thought to look at McMaster. I suspect if there were variations I should see those in my layer lines, which I don't normally have an issue with since upgrading to these. However the anti-backlash nuts are brass and could have some play. I do my best to keep them greased.
                                I am thinking there may be some play in my Tool Carrier. I know that I can get flex up to 0.14mm when I put some pressure on it, but it does want to return back to 0. Today looking into this further I dove the tool into the bed and found it didn't want to return to its normal height. So I docked and undocked it and picked it up again, the tool height was back to normal. I'm suspecting that it's shifting in the kinematics and even though it's a ball bearing and has no scoring it's not able to return. This would not explain the BLTouch variation, but maybe a factor when it comes to printing.
