    Hobby Servo Wiring
    814
    • cosmowaveundefined
      cosmowave @superpotato
      @superpotato With this wiring you have to be carefull because the servo can drawback relatively high voltage to your Duet.
      Do you have the possibility for an external 5V supply?
      I have my servo wired like this:
      Duet_Mankati_Schema.pdf
      About the code, i have to look later. I'm not at the machine...
      Mankati FSXT+, DeltaTowerV2, E3D MS/TC
      superpotatoundefined Fred-Yundefined JoergS5undefined 3 Replies Last reply Reply Quote 1
      • superpotatoundefined
        superpotato @cosmowave
        @cosmowave
        Thanks for the reply
        At the moment with the setup I do not have any 5V supply. I was hoping to power it directly through the Duet as I had a look at this section: https://duet3d.dozuki.com/Wiki/Using_servos_and_controlling_unused_IO_pins and the 9G servos I am using seem to be okay for it.
        Also had a look at your servo wiring, so it seems that the wiring to control the servo is okay and the same with mine but mainly its a matter of figuring out if the 5V supply will work and if the code is correct now.
        Think I will just try it out tonight 🤞
        cosmowaveundefined 1 Reply Last reply Reply Quote 0
          @superpotato When i'm at home, i can share my code for controlling the servo...
          superpotatoundefined c310undefined 2 Replies Last reply Reply Quote 0
            @cosmowave
            Perfect, thanks for the help 🙂
            • c310undefined
              c310 @cosmowave
              @cosmowave can you share brush pictures too?
              thanks!
              cosmowaveundefined 2 Replies Last reply Reply Quote 0
                cosmowave @c310
                @c310 Yes of course.
                Today evening....
                  cosmowave @c310
                  @c310 Here are some pictures of my brush for nozzle cleaning.
                  The brush is made from the head of this "brush".
                  The system works pretty well. But it's not really necessary! 😄
                  I have made this just for fun, and i had a servo laying around...
                  Here is a video.
                  https://www.youtube.com/watch?v=9iB9oI-SMB0
                  The config.g part for the servo is:
                  ; Cleaning Brush
                  M950 S1 C"exp.heater3"		; assign GPIO port 1 to heater3 on expansion connector, servo mode
                  M280 P1 S1    			; set (1deg) servo position on GPIO port 1
                  For deploying the brush:
                  ; this macro deploys the brush for cleaning the nozzle(s)
                  if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed	; are axles homed ?
                  	M291 P"axles not homed! perform homing ?" R"DeployBrush" S3	; message when not homed
                  	G28							   ; homing
                  if move.axes[2].machinePosition < 26					; z < 26mm ? because brush can crash with bed!
                  	M291 P"bed to high for brush! move 60mm down?" R"DeployBrush"		; message
                  	G0 Z26																; move z to 26mm
                  M280 P1 S90																	; set servo position to 90°
                  M291 P"brush ready" R"DeployBrush" S1										; message
                  For retracting the brush:
                  ; this macro retract the cleaner brush
                  M280 P1 S0							; set servo position to 0°
                  M291 P"brush retracted" R"RetractBrush" S1			; message
                  superpotatoundefined 1 Reply Last reply Reply Quote 0
                  • Fred-Yundefined
                    Fred-Y @cosmowave
                    @cosmowave Using an external power supply is a very good advice!
                    I think I burned a PanelDue because of a servo directly powered by the Duet 2.
                      @cosmowave
                      Ah great, thanks for posting this :). I didn't get the time yesterday but will try it out over the weekened.
                        superpotato @Fred-Y
                        @fred-y 😓 Thanks for letting me know, might be best if I source the power supply just to be safe, really don't want to destroy the board
                        • JoergS5undefined
                          JoergS5 @cosmowave
                          @cosmowave said in Hobby Servo Wiring:
                          Hello, thank you for sharing your schema, which helps me also. But I have a question, which is probably because of my limited electronic knowledge: isn't it necessary to connect ground of the 5V servo PSU with the Duet PSU, so the Duet knows the signal level?
                            cosmowave @JoergS5
                            @joergs5 Yes, you're right. The GND has to be connected, This is not shown on my scheme, because this scheme was only a quick "remender" for my old brain! 😊
                            • JoergS5undefined
                              JoergS5 @cosmowave
                              @cosmowave ok, thanks for clearifying. I'm doing my best to get better with electronics, but sometimes I have my problems (eg to connect ground high with low voltage - this feels very wrong and dangerous...). I plan to use servos as brakes for hinges, the servo acting as compliant switch.
                              • JoergS5undefined JoergS5 referenced this topic
