    Help duet 2 wifi is just not working correctly
    My Duet controlled machine
    1.9k
    • po3plestormundefined
      po3plestorm @jay_s_uk
      @jay_s_uk
      ; Configuration file for Duet Maestro (firmware version 3)
      ; generated by RepRapFirmware Configuration Tool v3.3.2 on Thu Sep 02 2021 14:24:44 GMT-0400 (Eastern Daylight Time)
      M575 P1 S1 B57600                              ; enable support for PanelDue
      G90                                            ; send absolute coordinates...
      M83                                            ; ...but relative extruder moves
      M550 P"Ender 3 Pro"                            ; set printer name
      M918 P1 E4 F2000000                            ; configure direct-connect display
      M552 S1                               		   ; enable network and acquire dynamic address via DHCP
      M586 P0 S1                                     ; enable HTTP
      M586 P1 S0                                     ; disable FTP
      M586 P2 S0                                     ; disable Telnet
      M569 P0 S1                                     ; physical drive 0 goes backwards
      M569 P1 S1                                     ; physical drive 1 goes backwards
      M569 P2 S0                                     ; physical drive 2 goes backwards
      M569 P3 S0                                     ; physical drive 3 goes backwards
      M584 X0 Y1 Z2 E3                               ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E93.00               ; set steps per mm
      M566 X1200.00 Y1200.00 Z24.00 E300.00          ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z180.00 E6000.00        ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E5000.00          ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E1000 I50                  ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                        ; Set idle timeout
      M208 X0 Y0 Z0 S1                               ; set axis minima
      M208 X235 Y235 Z260 S0                         ; set axis maxima
      M574 X1 S1 P"!xstop"                            ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"!ystop"                            ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S1 P"!zstop"                            ; configure active-high endstop for low end on Z via pin zstop
      M558 P0 H5 F120 T6000                          ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:195 S20                       ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B0 R0.224 C550.0 D2.74 S1.00 V13.8     ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                        ; map heated bed to heater 0
      M143 H0 S150                                   ; set temperature limit for heater 0 to 150C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8   ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H0 B0 R0.224 C550.0 D2.74 S1.00 V13.8     ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S275                                   ; set temperature limit for heater 1 to 275C
      M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S1 H-1                                 ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H-1                                 ; set fan 1 value. Thermostatic control is turned off
      M950 F2 C"fan2" Q500                           ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S1 H-1                                 ; set fan 2 value. Thermostatic control is turned off
      M563 P0 D0 H1 F0                               ; define tool 0
      G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
      G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
      • Dougal1957undefined
        Dougal1957 @po3plestorm
        @po3plestorm missing a M584 by any chance (I fell into this trap a few week back)
        Doug
        po3plestormundefined 1 Reply Last reply Reply Quote 0
          po3plestorm @Dougal1957
          @dougal1957 said in Help duet 2 wifi is just not working correctly:
          M584
          M584 assigns motors? I cant get the nozzle to heat up
          https://duet3d.dozuki.com/Wiki/M584
            @po3plestorm yep but it completes the setup I had exactly the same issues.
            see https://forum.duet3d.com/topic/24676/printer-fails-to-start-after-3-weeks-of-power-down?_=1630916312737
              @dougal1957 I did this but still no change
              M584 X0 Y1 Z2 E3
              po3plestormundefined Dougal1957undefined 2 Replies Last reply Reply Quote 0
                po3plestorm @po3plestorm
                @po3plestorm I also just noticed none of the fans work either, always on and the pwm all dont work
                  Phaedrux Moderator @po3plestorm
                  @po3plestorm said in Help duet 2 wifi is just not working correctly:
                  I also measured a 12v voltage on the output and tried with multiple different heater cartridges. still nothing, the light does turn on for heating as well.
                  When you measured the voltage did it turn on and off along with the heater activation?
                  You're using E0 heater right now, can you change over to E1 heater port and change the config M950 H1 C"e0heat" T1 to match?
                    Are you sure the blade fuses are intact? Have you tested them with a multimeter for continuity?
                      po3plestorm @Phaedrux
                      @phaedrux the e0heater has a voltage when the heater is activated and was tested with multiple heater cartridges. I just checked all the fuses with a multi-meter and no problems there.
                      I changed the config to
                      M950 H1 C"e1heat" T1
                      and now its got a voltage on the e1 heater but still the same problem.
                      and
                      was what is was at before
                        Supply voltage: min 14.2, current 14.3, max 14.4,
                        The supply voltage seems strange. What does a multimeter read for the PSU output voltage?
                        I also don't understand how there can be a voltage present on the heater outputs but no response from the heater cartridge itself.
                        Is your system supposed to be 12v or 24v?
                          @phaedrux my power supply is running 12.22 volts and so does the heater cartage. and my heater cartrage is running 115ohms.
                          Like I said before I had this issue with the non genuine duet as well but I assumed I broke the mosfet for some junk from a cheep board, but this one is a genuine with the exact issue.
                            How many heater cartridges have you tried? Are you using extension wiring for them?
                              @phaedrux i tried 3 different cartridges that were brand new, that I checked the resistance was all around 100kohm +- 10. I also tried putting just straight wires without the ferales. I just now checked with a mutimeter in series to measure current and it just read 0amps.
                                This post is deleted!
                                  @po3plestorm https://www.youtube.com/watch?v=4C-8MqbSAJM
                                    As a sanity check, since the bed heater is working, can you move the heater cartridge and thermistor to the bed heater terminals and command the bed to heat?
                                    And yes, move the M584 earlier in the config.g it needs to be before any commands that reference a defined axis anyway.
                                    Can you also send M98 P"config.g"?
                                    You said before the fans were working, but now they are not?
                                    And the fan fuse is intact?
                                    Do the fans work when connected directly to VIN?
                                    Do you get any voltage readings off the fan headers?
                                    po3plestormundefined 2 Replies Last reply Reply Quote 0
                                      @phaedrux okkkk I think I just have a bunch of bad heater cartrages, I plugged the cartrage and the thermistor into the bed pins and it doesnt work, so I think I just have a bunch of bad thermistors. thats unreal if it is true.
                                        @po3plestorm
                                        and there is the m98 command
                                        M98 P"config.g"
                                        HTTP is enabled on port 80
                                        FTP is disabled
                                        TELNET is disabled
                                          @phaedrux @jay_s_uk Hey just wanted to thank you guys for helping me out. I found the problem.
                                          the entire pack of heater cartridges I have are just bad. I got a huge pack on amazon and I just tested them on my room mates 3d printer and not a single one worked. The resistance on them is totally fine, they look fine, but all 8 of them in the pack are just bad, no clue how.
                                          Im so angry but at least I got down to the bottom of it.
