    Problem with G30
    • SIamundefined
      SIam
      yesterday i have build my Printer with the Due Wifi board with the Firmware 1.18 and all functions were good!
      Today i have the Firmware upgraded to 1.19. +3 and now the Printer will Crash with the G30 command as shown in this Video
      https://photos.google.com/share/AF1QipMx7FYw6zy2upiM2hqK8RYynvf0VWZQmeXnv8H3ma7-Iyo1H0cajoW8roNWTnE-lQ?key=T0I0R2RBQlJ2OTV0VC1MeDgzNjRIOER0cFNBVE9R
      i have "played" with this settings
      G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
      M557 X15:395 Y15:395 S20 ; Define mesh grid
      i have testet the x and y values with positive and negative values but noting changes 😞
      can someone tell me were i make a mistake ?
      regards
      Andy
      here is my Config file :
      ; Configuration file for Duet WiFi (firmware version 1.17)
      ; generated by RepRapFirmware Configuration Tool on Mon Aug 28 2017 12:04:38 GMT+0200
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      G90 ; Send absolute coordinates…
      M555 P2 ; Set firmware compatibility to look like Marlin
      M667 S1 ; Select CoreXY mode
      M208 X-10 Y-10 Z0 S1 ; Set axis minima
      M208 X420 Y420 Z450 S0 ; Set axis maxima
      M574 Z0 S0 ; Define active low and unused microswitches
      M574 X1 Y1 S1 ; Define active high microswitches
      M558 P1 X0 Y0 Z1 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
      M350 X16 Y16 Z16 E16 I0 ; Configure microstepping without interpolation
      M92 X80.85 Y80 Z1065.73 E100 ; Set steps per mm
      M566 X900 Y900 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
      M203 X24000 Y24000 Z480 E1500 ; Set maximum speeds (mm/min)
      M201 X1500 Y1500 Z100 E10000 ; Set accelerations (mm/s^2)
      M906 X1600 Y1600 Z2000 E1600 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M143 S260 ; Set maximum heater temperature to 260C
      M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
      M563 P0 D0 H1 ; Define tool 0
      M550 Phypercube ; Set machine name
      M552 S1 ; Enable network
      M587 Skleinersonnenschein.eu P"*********************" ; Configure access point. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T35 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
      Duet WiFi 1.02 or later + DueX5
      RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
      Duet WiFi Server: 1.26
      Duet Web Control 3.4.0beta4 (2021-09-27)
      • number40fanundefined
        number40fan
        There are a couple of folders you have to remove after upgrading. Did you read all of the release notes and trouble shooting guide?
        • DjDemonDundefined
          DjDemonD
          It's most likely trying to run deployprobe macros which have to be deleted.
          www.precisionpiezo.co.uk
          • SIamundefined
            SIam
            thanks deployprobe was the problem
              Also delete retractprobe.g if it is there.
