    Firmware 1.19+3 (1.19.1 release candidate)
    Firmware installation
    16
    37
    4.5k
    • lolorcundefined
      lolorc
      still having major issues with file uploads, they never complete have to M999 to duet (WiFi signal strength -59dBm)
      also having the gcode issues I reported earlier
      edit: after ~10 tries, I managed to upload a 4MB gcode file… during the first tries a rpi was connected to the usb port of the duet (no software connection tho), for the successful try I disconnected it. Time will tell if there's a relation. If it happens again I'll either downgrade to 1.18 or replace the web ui by octoprint.
      • MoS-tekknixundefined
        MoS-tekknix
        @dc42:
        @dc42:
        @MoS-tekknix:
        Also currently printing on my Machine with 1.19+3 without any kind of problems. Indeed it seems to fix the BedSurface-Problems cause i use over 200 Measure-Points. Now it looks much more real πŸ˜‰
        Also before with 1.19+1 i've noticed that Filament-Measurement isn't working well (800mm printed of 1700mm but finished) which seems to show now the real values.
        Cheers
        MoS-tekknix
        Thanks for the feedback. Which figure do you think is correct, the 800mm or the 1700mm? Does that print use just one filament, or more than one? Are you using relative or absolute extruder coordinates in your slicer?
        I've just done a print and it finished with 1274.7mm of 1280.7mm, so it's working for me.
        One more question: are you using volumetric extrusion?
        Yes, indeed.
          MoS-tekknix
          @dc42:
          @MoS-tekknix:
          Cheers
          MoS-tekknix
          800mm was the correct one. It seems to wokr now all the time +- a few mm.
          • DeltaConundefined
            DeltaCon
            Has been a few days since I checked this πŸ˜‰ I will try this evening concerning the heightmap correction.
            If you think trial and error is dangerous, try routine. That's even more so!
            • synergy41undefined
              synergy41
              Hello everyone,
              I noticed that the bar in the print status tab is not fair, I want to tell by that on my copy of screens you can see which indicates 100% while I am in the 28th Layers on 48.
              This is normal or not.
              Thank you for your answers.
              I LOVE MY DUET WIFI
              Board: Duet 2 WiFi (2WiFi)
              Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.1 (2022-06-01)
              Duet WiFi Server Version: 1.26
              Duet Web Control 3.4.1
              Cura 4.10
                MoS-tekknix
                Observed the same but was my fault. What your END-GCode looks like?
                I've set relative Modes before and raise Z to my maximum (200mm) and it always shows up 1000 Layers to print.
                Now i've set it to G91 (Relative Positioning) lift Z 5mm and set it back to G90 (Absolute Positioning)
                That solves the problem. I assume that Reprap seems to analyze also the END-Script too and calculates the maximum heigh of all Moves. And that was my maximum Z-Heigh.
                Cheers
                MoS-tekknix
                  synergy41
                  My g end code is like this
                  "G28 ; Home all axes
                  M140 S0 ; Set Bed Temperature
                  M84 ; Stop idle hold
                  G1 E-3 ; Remove 3.00mm of material
                  M400 ; Wait for current moves to finish
                  M104 S0 ; Set Extruder Temperature
                  M106 S0 P0 ; Stop Fans Print"
                  I LOVE MY DUET WIFI
                  Cura 4.10
                  • sigxcpuundefined
                    sigxcpu
                    +1 was fine, +3 repeats the same response since last console command as a UI notification. Is there an update to the web interface, too?
                      @sigxcpu:
                      There is no update to the web interface. Please can you explain more clearly what you think has changed.
                      • sigxcpuundefined
                        sigxcpu
                        During printing the last console message is repeated. In this case I was checking the motors currents (I've typed M906 once).
                          Is that a behaviour that you can reproduce? Does it also happen if you install the 1.19+4 firmware?
                          • sigxcpuundefined
                            sigxcpu
                            I have installed +4, but didn't have the chance to test it, as I have nothing to print yet πŸ™‚
                            • tomasfundefined
                              tomasf
                              I experienced something similar to that, where every command in the console showed the output of an older M122 command, but I haven't seen it happen yet in +4.
                              • sigxcpuundefined
                                sigxcpu
                                Yeap, can confirm that. It seems +4 is not repeating.
                                • sigxcpuundefined
                                  sigxcpu
                                  Actually it is repeating again.
                                  [[language]]
                                  Firmware Name:	RepRapFirmware for Duet WiFi
                                  Firmware Electronics:	Duet WiFi 1.0
                                  Firmware Version:	1.19.2 (2017-09-01)
                                  WiFi Server Version:	1.19.2
                                  Web Interface Version:	1.19.3
                                  It looks like the issue is with the client side, because server doesn't repeat.
                                  T 2017/10/13 16:05:33.938039 192.168.27.116:34083 -> 192.168.27.7:80 [AP]
                                  GET /rr_gcode?gcode=M221%20D0%20S95 HTTP/1.1.
                                  Host: 192.168.27.7.
                                  Connection: keep-alive.
                                  Accept: application/json, text/javascript, */*; q=0.01.
                                  X-Requested-With: XMLHttpRequest.
                                  User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_12_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/56.0.2924.87 Safari/537.36.
                                  Referer: http://192.168.27.7/.
                                  Accept-Encoding: gzip, deflate.
                                  Accept-Language: en-GB.
                                  T 2017/10/13 16:05:33.941879 192.168.27.7:80 -> 192.168.27.116:34083 [AP]
                                  HTTP/1.1 200 OK
                                  Cache-Control: no-cache, no-store, must-revalidate
                                  Pragma: no-cache
                                  Expires: 0
                                  Access-Control-Allow-Origin: *
                                  Content-Type: application/json
                                  Content-Length: 12
                                  Connection: close
                                  {"buff":243}
                                  Or server is repeating in "rr_reply"?
                                  T 2017/10/13 16:05:34.403518 192.168.27.116:34085 -> 192.168.27.7:80 [AP]
                                  GET /rr_reply HTTP/1.1.
                                  Host: 192.168.27.7.
                                  Accept: text/html, */*; q=0.01.
                                  T 2017/10/13 16:05:34.407117 192.168.27.7:80 -> 192.168.27.116:34085 [AP]
                                  HTTP/1.1 200 OK
                                  Pragma: no-cache
                                  Expires: 0
                                  Content-Type: text/plain
                                  Content-Length: 62
                                  Connection: close
                                  File Elevator/pulley.FCStd_PLA.gcode selected for printing
                                    I believe this is an issue with the interaction between DWC and the firmware. It's more chrishamm's area than mine. It's probably triggered by connecting two network clients and stopping one of them without pressing Disconnect first.
                                    • whosrdaddyundefined
                                      whosrdaddy
                                      @dc42:
                                      I can confirm this behavior, as I often upload a print from my computer and then control the printer via my phone (they are not in the same room).
                                      When I connect with my phone and control the printer, and I go back to my PC , sometimes the session is disconnected (AJAX error) and if I reconnect, I get echo on each command.
                                      • jlegereundefined
                                        jlegere
                                        @dc42:
                                        I've just released an update to firmware 1.19. the binaries an be found at https://www.dropbox.com/sh/wq0u70kpapqc3is/AAC6I8TS5Lbwuziq_r3M15Qea?dl=0. The changes since the 1.19+1 test version are:
                                        Thank you for this link, the one on github says it would not work with my electronics ( a duet ethernet, I did not grab the wifi firmware on accident)
                                          Version 1.19+1 has been superseded by 1.19.2 which is an official release on github.
