    How to run a macro after resume.g
    • code7undefined
      code7
      Does anyone know how I can run a macro that is executed directly after running resume.g?
      Resume.g returns the tool to the position it was in prior to pausing but I need to run a macro after the tool returns to this location and starts printing again.
      Delta Printer Using a Duet 2 Wifi v1.04c, FW3.4.0beta2, Duet WiFi sever 1.26, Duet Web Control 3.3.0
      cosmowaveundefined 1 Reply Last reply Reply Quote 0
      • cosmowaveundefined
        cosmowave @code7
        @code7 why not calling the macro at the end of resume.g?
        Mankati FSXT+, DeltaTowerV2, E3D MS/TC
        code7undefined 1 Reply Last reply Reply Quote 1
        • code7undefined
          code7 @cosmowave
          @cosmowave said in How to run a macro after resume.g:
          Adding the macro in the resume.g runs it prior to the tool returning to its paused position.
          fcwiltundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
          • fcwiltundefined
            fcwilt @code7
            @code7 said in How to run a macro after resume.g:
            Have you tried adding a M400 command after the last command in resume.g?
            And then adding any additional commands after that?
              deckingman @code7
              It shouldn't do. The command to move to the last print position should be a G1 R1...... So if you add your commands or M98 macro call after this line, it ought to work. But you will probably need to add M400 or an appropriate G4 command to wait for any moves to complete. So something like G1 R1 ...... then M400 (or G4 Pn) then M98......(or a bunch of other commands) ought to work.
              EDIT. @fcwilt beat me to it while I was typing.
              • code7undefined
                code7
                @deckingman @fcwilt
                That was a simple fix. Thanks guys.
