Invalid GPIO
Send: M122
Recv: === Diagnostics ===
Recv: RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0 running on Duet WiFi 1.02 or later + DueX5
Recv: Board ID: 0JD0M-9P61A-J8PSJ-6JTD8-3S46M-9BQUS
Recv: Used output buffers: 1 of 24 (10 max)
Recv: === RTOS ===
Recv: Static ram: 30516
Recv: Dynamic ram: 92516 of which 16 recycled
Recv: Exception stack ram used: 592
Recv: Never used ram: 7432
Recv: Tasks: NETWORK(ready,640) HEAT(blocked,1240) DUEX(suspended,160) MAIN(running,1320) IDLE(ready,156)
Recv: Owned mutexes:
Recv: === Platform ===
Recv: Last reset 03:23:57 ago, cause: software
Recv: Last software reset at 2021-09-10 10:30, reason: User, spinning module GCodes, available RAM 7836 bytes (slot 3)
Recv: Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
Recv: Error status: 8
Recv: Free file entries: 10
Recv: SD card 0 detected, interface speed: 20.0MBytes/sec
Recv: SD card longest block write time: 6.0ms, max retries 0
Recv: MCU temperature: min 31.4, current 32.2, max 33.2
Recv: Supply voltage: min 23.9, current 24.1, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
Recv: Driver 0: standstill, SG min/max 0/324
Recv: Driver 1: standstill, SG min/max 47/307
Recv: Driver 2: temperature-shutdown! short-to-ground standstill, SG min/max not available
Recv: Driver 3: standstill, SG min/max not available
Recv: Driver 4: temperature-shutdown! short-to-ground standstill, SG min/max not available
Recv: Driver 5: standstill, SG min/max 0/326
Recv: Driver 6: standstill, SG min/max 0/1023
Recv: Driver 7: standstill, SG min/max 0/322
Recv: Driver 8: standstill, SG min/max 0/1023
Recv: Driver 9: temperature-shutdown! short-to-ground standstill, SG min/max not available
Recv: Date/time: 2021-09-10 13:54:07
Recv: Cache data hit count 4294967295
Recv: Slowest loop: 25.74ms; fastest: 0.09ms
Recv: I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0
Recv: === Move ===
Recv: Hiccups: 0(0), FreeDm: 169, MinFreeDm: 163, MaxWait: 7856434ms
Recv: Bed compensation in use: none, comp offset 0.000
Recv: === MainDDARing ===
Recv: Scheduled moves: 379, completed moves: 379, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
Recv: === AuxDDARing ===
Recv: Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
Recv: === Heat ===
Recv: Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
Recv: === GCodes ===
Recv: Segments left: 0
Recv: Stack records: 3 allocated, 0 in use
Recv: Movement lock held by null
Recv: http is idle in state(s) 0
Recv: telnet is idle in state(s) 0
Recv: file is idle in state(s) 0
Recv: serial is ready with "M122" in state(s) 0
Recv: aux is idle in state(s) 0
Recv: daemon is idle in state(s) 0
Recv: queue is idle in state(s) 0
Recv: autopause is idle in state(s) 0
Recv: Code queue is empty.
Recv: === Network ===
Recv: Slowest loop: 8446.66ms; fastest: 0.00ms
Recv: Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
Recv: HTTP sessions: 0 of 8
Recv: - WiFi -
Recv: Network state is running
Recv: WiFi module is providing access point
Recv: Failed messages: pending 0, notready 0, noresp 1
Recv: WiFi firmware version 1.23
Recv: WiFi MAC address 4a:3f:da:51:11:37
Recv: WiFi Vcc 3.41, reset reason Hardware watchdog
Recv: WiFi flash size 4194304, free heap 24608
Recv: WiFi IP address 192.168.1.1
Recv: Connected clients 1
Recv: Socket states: 0 0 0 0 0 0 0 0
Recv: === Filament sensors ===
Recv: Extruder 0 sensor: ok
Recv: ok -
Send: M98 P"CONFIG.G"
Recv: Error: M574: endstop type 0 is no longer supported. Use type 1 and invert the input pin instead.
Recv: Turn off the current WiFi mode before selecting a new one
Recv: HTTP is enabled on port 80
Recv: FTP is disabled
Recv: TELNET is disabled
Recv: Error: M307: Heater 3 not found
Recv: Warning: M307: heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 542C.
Recv:
Recv: Error: M106: Fan number 3 not found
Recv: Error: M106: Fan number 4 not found
Recv: Error: M106: Fan number 5 not found
Recv: Error: M106: Fan number 6 not found
Recv: Error: M106: Fan number 7 not found
Recv: Error: M106: Fan number 8 not found
Recv: Warning: M307: heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 763C.
Recv:
Recv: ok -
i tried to post those in the </> and it was flagged as spam
@fishpig said in Invalid GPIO:
Are you able to update to 3.3?
It looks like your config is still using a lot of RRF2 syntax.
@phaedrux
don't have a link to the files do you?
also as i have a rare not well known printer i am a little hesitant to update further without some files to make sure it runs on this big girl, it's a work printer not mine personally. -
@Phaedrux the custom vivedino board doesn't work with RRF since RRF3.1RC11 for unresolved reasons, see https://forum.duet3d.com/topic/16997/formbot-troodon-rrf-3-1-1-update/7 for the discussion back at the time.
EDIT: The config provided by vivedino is available at https://github.com/InsanityAutomation/FormbotTroodon/
@Fishpig check if that
M42 P25
is maybe in your slicer's start gcode and remove if from there. Assuming the configuration files haven't been changed, there's no reference to a GPIO 25 in there. And yes, it looks like an RRF2.x config running on RRF3.x, so the configuration for the LEDs doesn't work. -
Thanks guys,
i'll test out M42 P25 in a short while, i think i might try and find the RRF2.X firmware and go back to that. -
@oliof said in Invalid GPIO:
Yes I had suspected it was the custom board.
I just entered M42 P25
Send: M42 P25 Recv: Error: Invalid gpio port 25 Recv: ok and it throws the error outside of starting a print.
@oliof
well would you look at that.....just got the cura going and found not only was it set to marlin but the start code wasM42 P25 S0 M42 P26 S0 M42 P24 S255 M280 P7 S160 T0 G92 E0 G1 E-10 F1800 G32 G29 G1 X0 Y0 F4800 G92 E0 G1 E10 F540 G92 E0 G1 E-3.0000 F1800 G1 Z0.200 F1000 G1 X400 Y0 E43.5631 F1000 G92 E0 G1 E-8.0000 F5400 G1 X205 Y200 F18000 G1 E0 F5400 -
Try a lower number than 25. I think 25 may be higher than the maximum allowed.
EDIT: the highest GpOut port number allowed in Duet 2 builds of RRF is 19.
@Phaedrux you never figured out what change in RRF broke the board, right?
I don't think anyone affiliated with Duet has a Troodon board in hand to know how it's different.
Last I heard the only difference is that the TMC2660s stallguard pins are floating since those aren't required on the troodon. Otherwise, it's a single board combining Duet2Wifi and Duex5. Unfortunately, I don't have a board (or schematics) either.
@Phaedrux I ordered a board and expect it to arrive by October. If I don't manage to find the offending change by a couple bisecting builds, I'm happy to send it over to Duet3D for inspection.
