Solved Fan Selection on Paneldue
Is it possible to change the Active Fan on the PanelDue?
i think i remember that in earlier Version this was possible,
but now on the Status Page it's just "FAN" where i can set it from 0-100% (which is normally
the Partcoolingfan, at least on my Chiron)
i wanted to control every Available fan on the PanelDue.... FW PanelDue-3.4.0-pre2 -
Hey @NeueKlasse, i had a look into the sources. I don't think it was ever possible.
At the moment you can only adjust the speed. Although you could write a macro to reconfigure your fans. Command M563 might be helpful.
Please check the gcode specification
then i was wrong, i thought i changed the fan sometime... i'm looking forward to a
"Fan Change" possibilityThank's for the Advise, with M563 it's possible to get around that function
