    InputShaping-Plugin-0.2.0-pre5 released
    Plugins for DWC and DSF
    848
    • mfs12undefined
      mfs12
      Hey,
      one more homing issue got resolved and tested with @SIam. Thank you.
      Luckily natural numbers are unlimited so there's still space for more releases.
      Looking forward to your feedback. And one more time thanks to the people reporting and helping me testing.
      As this plugin is still experimental in its early phase please take the time and read at least through the howto section. 😉
      Have a nice weekend.
      release notes for inputshaping plugin 0.2.0-pre5
      This work is based on the original acceleration plugin. Input shaping plugin tries to take
      the input shaping calibration to a next level.
      The current state is still EXPERIMENTAL!!!
      Although it's experimental it brings already some handy features which is why i
      am doing this release. Therefore please comment, give feedback, report bugs and share your
      ideas.
      requirements
      • Duet Web Control 3.4.0-b4
      • RepRap Firmware 3.4.0-b4
      features
      • restructre plugin to use vue components
      • added test configuration component
      • added recorder component
      • added chart component
      • use object model to determine status of test
      • added add/delete of algorithm configurations
      • added add/delete/select of records
      • added add/delete/select of sessions
      • display test parameters in chart component
      • allow records with differing samples rates of up to 1%
      • cleaned up debugging output
      • added localization
      • home device only if not homed
      • improved ui layout
      • added component to manage multiple sessions
      • added more parameter validation for test and algorithm
      • disable tab record tab when no algorithms defined
      • disable tab chart when no records available
      • improved error reporting
      bugs
      • fixed initial filtering of records by axis
      • fixed session cleanup when session is deleted
      • fixed data handling when swapping sessions
      • fixed can address handling (needs more testing)
      • fixed record integrity when referenced algorithm is changed
      • fixed CAN address handling when address is null
      • fixed one-time homing for some machines
      known issues
      • parameter validation doesn't cover every situation
      downloads
      • https://github.com/mfs12/DuetWebControl/releases/tag/inputshaping-plugin-0.2.0-pre5
      howto
      initialize session
      • switch to tab "initialize"
      • create a new session or
      • select an available session
      configure session
      • switch to tab "configure"
      • configure your session session
      • configure test parameters
      • add as many input shaping algorithm configurations as you like
        • more than one per algorithm are allowed
        • this is good to compare different input shaping configuration of the same algorithm
      • CAUTION: once a record in a session exists test parameters can't be changed anymore.
      record profiles
      • switch to tab "record profiles"
      • press "run" button and wait until recording is done
      frequency analysis
      • switch to tab "frequency analysis"
      • in "acceleration records" section you see a list of profiles recorded
        • clicking on the entry DELETEs it form the session!!! (it is lost!!!)
      • in "filter" section the show/hidden graphs are displayed
        • un-checking an axis will hide or show all charts of an axis group
      • in chart section
        • individual graphs can be shown or hidden by pressing the colour next to the name
      • press "FFT" button to show FFT representation of the graph
      • press "Time" button to show time representation of the graph
      limitations
      • currently no data is stored permanently!!!
      • everything is volatile so avoid hitting browser's reload
      what's next?
      Potential next steps are
      • store session in a local file or in browser's local storage or
      • load session from local file or browser's local storage
      • recommend input shaping parameters
      • improve input validation
      • add translations
      Visit me on github at https://github.com/mfs12/
      xiaokundefined 1 Reply Last reply Reply Quote 2
      • mfs12undefined
        mfs12
        Can somebody test the plugin using a toolboard?
        SilviuZundefined 1 Reply Last reply Reply Quote 0
        • Heartleander81undefined
          Heartleander81
          Hi. I have the plugin running.
          I had start-up problems because I had forgotten to update my toolboard to firmware 3.4b4.
          I now get data that I have to deal with now.
          Thanks for the work you put in there.
          • xiaokundefined
            xiaok @mfs12
            @mfs12
            Hello, I submitted a PR from github to support Simplified Chinese, you can take a look, if you have any questions, please let me know.
            thanks
            mfs12undefined 1 Reply Last reply Reply Quote 0
            • mfs12undefined
              mfs12 @xiaok
              @xiaok, this is very nice, thank you. I will get back to as soon as the plugin gets more production ready and the texts finalized.
              • mfs12undefined
                mfs12
                @xiaok i didn't receive an PR.
                xiaokundefined 1 Reply Last reply Reply Quote 0
                • xiaokundefined
                  xiaok @mfs12
                  @mfs12 Good morning, branch at inputshaping-accel-plugin
                  https://github.com/mfs12/DuetWebControl/pull/18
                  kluoyun opened this pull request in mfs12/DuetWebControl
                  open Inputshaping accel plugin #18
                  • SilviuZundefined
                    SilviuZ @mfs12
                    @mfs12 hi!
                    I've tested the plugin and its working nice.
                    can I suggest to have a automatic ringing test going trough the range 15-150 HZ with the option of changing in between NONE, ZVD, ZVDD EI2, EI3, minimum acceleration and the damping factor.
                    Thank you
                    • mfs12undefined
                      mfs12
                      @SilviuZ, can you be more specific about the ringing test. what do you exactly mean by that?
                      • SilviuZundefined
                        SilviuZ @mfs12
                        something that can generate multiple auto tuning algorithms similar with below to find the perfect input shaping values in type, hz and damping values
                        0-ei3-dba218c3 1633266073427 1000 1356 0 ei3 25 0.1 800
                        1-ei3-dba218c3 1633266078416 1000 1356 0 ei3 26 0.1 800
                        2-ei3-dba218c3 1633266083309 1000 1353 0 ei3 27 0.1 800
                        3-ei3-dba218c3 1633266088439 1000 1361 0 ei3 28 0.1 800
                        4-ei3-dba218c3 1633266093576 1000 1357 0 ei3 29 0.1 800
                        5-ei3-dba218c3 1633266098567 1000 1356 0 ei3 30 0.1 800
                        6-ei3-dba218c3 1633266103563 1000 1366 0 ei3 31 0.1 800
                        7-ei3-dba218c3 1633266108571 1000 1356 0 ei3 32 0.1 800
                        8-ei3-dba218c3 1633266113494 1000 1356 0 ei3 33 0.1 800
                        9-ei3-dba218c3 1633266118404 1000 1359 0 ei3 34 0.1 800
                        10-ei3-dba218c3 1633266123400 1000 1363 0 ei3 35 0.1 800
                        11-ei3-dba218c3 1633266128449 1000 1356 0 ei3 36 0.1 800
                        12-ei3-dba218c3 1633266133376 1000 1356 0 ei3 37 0.1 800
                        13-ei3-dba218c3 1633266138590 1000 1363 0 ei3 38 0.1 800
                        14-ei3-dba218c3 1633266143640 1000 1359 0 ei3 39 0.1 800
                        15-ei3-dba218c3 1633266148722 1000 1353 0 ei3 40 0.1 800
                        • mfs12undefined
                          mfs12
                          @SilviuZ, a feature like this will come very likely.
                          • mfs12undefined
                            mfs12
                            New release was published. Check...
                            https://forum.duet3d.com/topic/25515/inputshaping-plugin-0-2-0-pre6-released/1
