PanelDue Firmware 3.4.0-pre3 released
Hey, a new release is available. It contains mostly bug fixes.
Release Notes 3.4.0-pre3
This release requires RepRapFirmware 3.4 or later.
Version 2 (after August 2016) and Version 3 PanelDue are supported.
Features:
- add cross-platform headless builds based on cmake
- cleaned up dim/screensaver handling
- removed compiler warnings
- enabled Russian localization by default
- enabled Ukrainian localization by default
- improved list-locales tool for translation debugging
Bug fixes:
- fixed displaying of M291 S2 and S3 if followed by M292
- fixed displaying macro buttons in control tab
- fixed setting of serial baud rate after reboot
- cleaned up English
- cleaned up Czech translation
- cleaned up French translation
- cleaned up German translation
- fixed access to second sd card
- cleaned up Russian translation
- fixed persistent pressed button handling in some dialogs
- fixed updates via RRF
Downloads and flashing instructions:
Binaries can be found at https://github.com/Duet3D/PanelDueFirmware/releases/tag/3.4.0-pre3
Flashing instructions can be found at https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
