    M571 not recognizing extruder moves
    751
    • tooundefined
      too
      I am trying to set up M571 "output on extrude" on my current machine, however I am a bit stuck.
      The output of the pin never changes, whether I am extruding manually or from gcode.
      I have tried several ways and different pins all without success
      M571 S1 P"0.out8"
      M571 S1 P"out8"
      M571 S1.0 P"0.out8"
      M571 S1 P"0.out7"
      M571 P"out7" S1
      (you get the idea)
      I can successfully invert the output pin with the ! modifier and measure my VIN voltage, but the pin is not changing when the extruder is active.
      The extruder is driven by a 1XD board with CAN address 23:
      M569	P20.0	S1		; X forward on 20
      M569	P21.0	S1		; Y forward on 21
      M569	P22.0	S0		; Z forward on 22
      M569	P23.0	S0		; E forward on 23
      M569	P24.0	S0		; U forward on 24
      I have figured out that I cannot use the 1XD as output, I get the following error when I try:
      M571 P"23.out1" S1
      Error: M571: Remote ports are not supported by this command
      I suspect that I haven't configures the tool correctly, but I cannot figure out what to change:
      M563	P0	D0		; Define tool 0
      If I enter the drive number differently I get an error:
      M563 P0 D23.0
      Error: M563: bad drive number
      Does Anyone have an Idea?
      Thanks!
      Attached the full config file:
      config.g
      Cartesian Duet3+Raspberry pi 4 with 5x 1XD using servo drives printing mortars and concrete
      fcwiltundefined dc42undefined 3 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @too
        @too
        I've re-posted your config file using the </> tags - it saves folks from having to download it.
        ; generated by RepRapFirmware Configuration Tool v3.1.3 on Fri Jul 03 2020 17:01:27 GMT+0200 (Central European Summer Time)
        G90														; send absolute coordinates...
        M83														; ...but relative extruder moves
        ;Recommended by 1XD manual
        G4 S1   ;wait for expansion boards to start
        M584	X20.0	Y21.0	Z22.0	E23.0		R0			; set drive mapping for linear axes
        M584	U24.0								R1			; set drive mapping for rotational axes
        ; "fast mode" to allow for a step rate of more than 55kHz
        M569	P20.0	T2.5:2.5:5:0							; set pulse timing for X to "fast mode"
        M569	P21.0	T2.5:2.5:5:0							; set pulse timing for Y to "fast mode"
        M569	P22.0	T2.5:2.5:5:0							; set pulse timing for Z to "fast mode"
        M569	P23.0	T2.5:2.5:5:0							; set pulse timing for E to "fast mode"
        M569	P24.0	T2.5:2.5:5:0							; set pulse timing for U to "fast mode"
        ;CONCRETELAB VALUES
        ;M350	X1	Y1 	Z1 	E1 	U1	 I1		; Configure microstepping with interpolation
        ;M92	X100	Y100 	Z100 	E100 	U100			; Set steps per mm
        ;M566	X3000 	Y3000 	Z100 	U1200 	E3000 			; Set maximum instantaneous speed changes (mm/min)
        ;M203	X15000 	Y15000 	Z2500 	U6000 	E50000 			; Set maximum speeds (mm/min)
        ;M201	X300 	Y300 	Z100 	E1500 	U300   			; Set accelerations (mm/s^2)
        ;PARKER VALUES
        ;M350	X16	Y16	Z16	E16	U16	I1		; Configure microstepping with interpolation
        M92 	X180 	Y72 	Z614	E106	U525			; Set steps per mm
        M566 	X800	Y800	Z80	E3000	U3000    		; Set maximum instantaneous speed changes (mm/min)
        M203	X15000	Y15000	Z2000	E36000	U7500 			; Set maximum speeds (mm/min)
        M201 	X300	Y300	Z100	E1500	U5000			; Set accelerations (mm/s^2)
        M208	X0	Y0	Z000	E-99999	U-99999		S1	; set axis minima
        M208	X5000 	Y5000	Z3000	E999999	U999999		S0	; set axis maxima
        M574	X0							; no X endstop
        M574	Y0							; no Y endstop
        M574	Z0							; no Z endstop
        M574	E0							; no E endstop
        M574	U0							; no U endstop
        M574	V0							; no U endstop
        M558	P8	C"22.io0.in"	H20	F750	T15000	R1	; Set Z probe type to switch and the dive height + speeds
        G31		P500	X0	Y-200	Z156			; Set Z probe trigger value, offset and trigger height
        M557	X0:3200	Y0:4200	S500					; Define probing grid size and spacing
        M376	H500 							; define compensation taper
        M140	H-1							; Disable heated bed
        G10		P0	X0	Y0	Z0			; Set tool 0 axis offsets
        G10		P0	R0	S0				; Set initial tool 0 active and standby temperatures to 0C
        T0								; Select first tool
        M302	P1							; Allow cold extrusion
        ; Homing outputs
        M950 	P0	C"20.out1"									; Homing request pin for X
        ;M950 	P1	C"21.out1"									; Homing request pin for Y
        ;M950 	P2	C"22.out1"									; Homing request pin for Z
        ;M950 	P4	C"24.out1"									; Homing request pin for U
        ;M950	P5	C"25.out1"									; Homing request pin for V
        ; increase movement queque buffer size
        M595 P240 S500
        ; output on extrude
        ;M571 P"0.out7" S1			; enable output on extrude
        M571 S1 P"0.out8"
        ; ENABLE panelDUE
        M575 P1 S1 B57600
        ;For saving worklpace coordinate systems to file
        M501
        • fcwiltundefined
          fcwilt @too
          @too
          Have you tried executing config.g using M98 P"config.g" from the DWC Console to see if any errors are reported?
          Errors in the file during boot are usually not seen.
            dc42 administrators @too
            @too I've looked into this. Currently the M571 feature does not work when the extruder drive is driven from a CAN-connected expansion board. I will work on a fix.
            tooundefined 1 Reply Last reply Reply Quote 1
            • tooundefined
              too @dc42
              Hey @dc42, just wondering if you have managed to fix this?
              I couldn't see anything about that in the changelogs..
                @too I'm sorry, this has not been fixed yet but it is on the list.
                tooundefined 1 Reply Last reply Reply Quote 0
                • tooundefined
                  too @dc42
                  @dc42 alright, that's good to hear... Any idea when this will be fixed time-wise? 🙂
                  Any idea for a workaround in the meantime?
                  Could I add a second driver to the extruder axis that is mapped to a driver on the 6HC to make this run? I'll go ahead and give this a try..
                  • tooundefined
                    too
                    I was hoping to get this working by adding a second driver from the 6HC to the E axis without luck. I am now not sure if this is because of some limitation of RRF that I didn't see or if I am implementing this wrong:
                    M569	P22.0	S1							; Z forward on 22
                    M569	P24.0	S1							; U forward on 24
                    M569	P0.0	S0							; additional axis for OutOnExtrude
                    M584	X20.0		Y21.0	Z22.0	R0			; set drive mapping for linear axes
                    M584	E23.0:0.0	U24.0		R1			; set drive mapping for rotational axes
                    ;OMRON VALUES
                    ;output on extrude
                    M571 P"0.io3.out" S1			; enable output on extrude
                    Is there any workaround or quickfix that you can come up with to control a pin according to extrusion moves? Could I somehow use a driver_Enable signal configured in a certain way?
                      Phaedrux Moderator @too
                      @too said in M571 not recognizing extruder moves:
                      M584 E23.0:0.0
                      You've defined 2 extruders, but I only see settings values for one extruder.
                      Do you have a tool configured to use that extruder?
                      • tooundefined
                        too @Phaedrux
                        @phaedrux Yeah, so far I have only been using / configuring single-tool machines. The Extruder tool on 23.0 works fine. but because its on a CAN-extension board the M571 command doesn't work.
                        The tool is defined to use both drives: M563 P0 D0:1
                        I have tried to configure the Extruder tool with drives 0.0 and 23.0 and had partial success: If I write M584 E:0.0:23.0 then the output on extrude pin switches, but I don't see any STP/DIR signals on 23.0.
                        If I write M584 E:23.0:0.0 however, I get no output on extrude pin switches, but I see STP/DIR signals on 23.0...
                        ; RESTART 1XD
                        ;M98 P"0:/sys/COBOD_restart_expansionboards"			; reboot 1XD boards
                        ; additional E driver for output on extrude
                        M569	P0.0	S0
                        M584	X20.0	Y21.0	Z22.0	E0.0:23.0		R0			; set drive mapping for linear axes
                        ;CONCRETELAB VALUES
                        M350	X1	 	Y1	 	Z1	 	E1:1	U1	 	I1		; Configure microstepping with interpolation
                        M566	X3000 	Y3000 	Z100 	E3000   U1200 			; Set maximum instantaneous speed changes (mm/min)
                        M203	X15000 	Y15000 	Z2500 	E50000  U6000 			; Set maximum speeds (mm/min)
                        M208	X0		Y0		Z000	E-99999:-99999	U-99999		S1	; set axis minima
                        M208	X5000 	Y5000	Z3000	E999999:999999	U999999		S0	; set axis maxima
                        M563	P0	D0:1						; Define tool 0
                        ; Homing outputs
                        M595 P240 S500
                        ; get current position from PLC
                        G28
                        M501
                        ; output on extrude
                        M571 P"0.io0.out" S1						; enable output on extrude
                        Reading through the gcode wiki again I noticed that I probably need to define a mixing ratio, as our slicer doesn't output multiple E values...
                        I have added the corresponding command to the config.g:
                        ; set tool mixing ratio
                        M567 P0 E1:1
                        ........ and now it finally works!
                        I have added this block onto the end of the config.g
                        ; SETUP OUTPUT ON EXTRUDE
                        ; additional "virtual" E driver
                        M569	P0.0	S0
                        ; updated driver mapping
                        M584	E0.0:23.0		R0
                        ; updated microstepping setting
                        M350	E1:1
                        ; updated axis limits
                        M208	E-99999:-99999	S1	; set axis minima
                        M208	E999999:999999	S0	; set axis maxima
                        ; updated Tool definition
                        M563	P0	D0:1
                        ; set tool mixing rato
                        M567 P0 E1:1
                        Thanks for sending me into the right direction @Phaedrux !
                        • tooundefined too has marked this topic as solved
                          @too I'm sorry this has taken so long to resolve and I am glad you found a workaround. I am implementing a fix for M571 when the extruder is driven from a CAN-connected board in RRF 3.5beta2.
