    Connecting duet wifi 2
    Duet Web Control
    1.4k
    • Hellpilotundefined
      Hellpilot @SIam
      @siam I'd like to make it easy! 😢
      I believe there are no restrictions. Other devices can connect with ease.
      SIamundefined 1 Reply Last reply Reply Quote 0
      • SIamundefined
        SIam @Hellpilot
        @hellpilot Can you try to restart your Router and Your Printer and after this, post the result from M122
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        Hellpilotundefined 1 Reply Last reply Reply Quote 0
          Hellpilot @SIam
          @siam
          === Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet
          version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02
          or later<LF>Board ID: 08DJM-9178L-L2MS8-6JKDA-3S86K-K8G2N<LF>Used
          output buffers: 1 of 24 (13 max)<LF>=== RTOS ===<LF>Static ram: 23
          876<LF>Dynamic ram: 75352 of which 0 recycled<LF>Never used RAM 15
          188, free system stack 185 words<LF>Tasks: NETWORK(ready,6.7%,3
          40) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,364) MAIN(r
          unning,93.2%,439) IDLE(ready,0.0%,29), total 100.0%<LF>Owned mu
          texes: USB(MAIN)<LF>=== Platform ===<LF>Last reset 00:02:32 ago, c
          ause: power up<LF>Last software reset at 2021-09-19 13:42, reas
          on: User, GCodes spinning, available RAM 12332, slot 1<LF>Softw
          are reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0
          x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0
          n/a<LF>Error status: 0x00<LF>Aux0 errors 0,0,0<LF>Step timer max inte
          rval 0<LF>MCU temperature: min 31.4, current 32.2, max 34.7<LF>Sup
          ply voltage: min 0.4, current 0.5, max 0.6, under voltage ev
          ents: 0, over voltage events: 0, power good: no<LF>Heap OK, han
          dles allocated/used 0/0, heap memory allocated/used/recyclab
          le 0/0/0, gc cycles 0<LF>Driver 0: position 0, ok, SG min/max n
          ot available<LF>Driver 1: position 0, ok, SG min/max not availa
          ble<LF>Driver 2: position 0, ok, SG min/max not available<LF>Drive
          r 3: position 0, ok, SG min/max not available<LF>Driver 4: posi
          tion 0, ok, SG min/max not available<LF>Driver 5: position 0<LF>Dr
          iver 6: position 0<LF>Driver 7: position 0<LF>Driver 8: position 0
          <LF>Driver 9: position 0<LF>Driver 10: position 0<LF>Driver 11: posit
          ion 0<LF>Date/time: 1970-01-01 00:00:00<LF>Cache data hit count 42
          94967295<LF>Slowest loop: 3.00ms; fastest: 0.12ms<LF>I2C nak error
          s 0, send timeouts 0, receive timeouts 0, finishTimeouts 0,
          resets 0<LF>=== Storage ===<LF>Free file entries: 10<LF>SD card 0 det
          ected, interface speed: 20.0MBytes/sec<LF>SD card longest read
          time 0.4ms, write time 0.0ms, max retries 0<LF>=== Move ===<LF>DMs
          created 83, maxWait 0ms, bed compensation in use: none, com
          p offset 0.000<LF>=== MainDDARing ===<LF>Scheduled moves 0, comple
          ted moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns
          [0, 0, 0], CDDA state -1<LF>=== AuxDDARing ===<LF>Scheduled moves
          0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, U
          nderruns [0, 0, 0], CDDA state -1<LF>=== Heat ===<LF>Bed heaters =
          0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1<LF>=== GCodes ===<LF>Seg
          ments left: 0<LF>Movement lock held by null<LF>HTTP is idle in sta
          te(s) 0<LF>Telnet is idle in state(s) 0<LF>File is idle in state(s
          ) 0<LF>USB is ready with "m122" in state(s) 0<LF>Aux is idle in st
          ate(s) 0<LF>Trigger is idle in state(s) 0<LF>Queue is idle in stat
          e(s) 0<LF>LCD is idle in state(s) 0<LF>Daemon is idle in state(s)
          0<LF>Autopause is idle in state(s) 0<LF>Code queue is empty.<LF>=== N
          etwork ===<LF>Slowest loop: 0.61ms; fastest: 0.00ms<LF>Responder s
          tates: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 s
          essions<LF>HTTP sessions: 0 of 8<LF>- WiFi -<LF>Network state is chan
          gingMode<LF>WiFi module is trying to connect<LF>Failed messages: p
          ending 0, notready 0, noresp 0<LF>WiFi firmware version 1.26<LF>Wi
          Fi MAC address ec:fa:bc:5b:42:ca<LF>WiFi Vcc 3.35, reset reason
          Turned on by main processor<LF>WiFi flash size 4194304, free h
          eap 28776<LF>Clock register 00002002<LF>Socket states: 0 0 0 0 0 0
          0 0<LF>ok<LF>WiFi reported error: Wrong password while trying to
          connect to WuTangLan24<LF>WiFi module is idle<LF>WiFi reported err
          or: Wrong password while trying to connect to WuTangLan24<LF>Wi
          Fi module is idle<LF>WiFi reported error: Wrong password while
          trying to connect to WuTangLan24<LF>WiFi module is idle<LF>WiFi re
          ported error: Wrong password while trying to connect to WuTa
          ngLan24<LF>WiFi module is idle<LF>WiFi reported error: Wrong passw
          ord while trying to connect to WuTangLan24<LF>WiFi module is id
          le<LF>WiFi reported error: Wrong password while trying to conne
          ct to WuTangLan24<LF>WiFi module is idle<LF>WiFi reported error: W
          rong password while trying to connect to WuTangLan24<LF>WiFi mo
          dule is idle<LF>WiFi reported error: Wrong password while tryin
          g to connect to WuTangLan24<LF>WiFi module is idle<LF>WiFi reporte
          d error: Wrong password while trying to connect to WuTangLan
          • SIamundefined
            SIam @Hellpilot
            @hellpilot are you really sure that you use the correct password? Did you use in your password, maybe special chars?
              Hellpilot @SIam
              @siam 100%. Even changed it briefly to something simple.
              Connections to my guest network have no issue, however. Just cannot connect to the web interface after that.
              • SIamundefined
                SIam @Hellpilot
                @hellpilot said in Connecting duet wifi 2:
                That is what i'm not understand ... did you use the same encoding (wpa2 ) in your guest account as in your closed wifi (in my router I can set here different settings)?
                  Hellpilot @SIam
                  @siam Yeah I changed it all to WPA2 after issues with WPA3.
                    Hellpilot
                    Here is the terminal after connecting to my guest network. IP Address does not pull up the web interface.
                    WiFi: sleep enable,type: 2
                    WiFi: scandone
                    WiFi: state: 0 -> 2 (b0)
                    WiFi: state: 2 -> 3 (0)
                    WiFi: state: 3 -> 5 (10)
                    WiFi: add 0
                    WiFi: aid 20
                    WiFi: cnt
                    WiFi:
                    WiFi: connected with WuTangGuest, channel 9
                    WiFi: dhcp client start...
                    WiFi: wifi evt: 0
                    WiFi: ip:192.168.50.167,mask:255.255.255.0,gw:192.168.50.1
                    WiFi module is connected to access point WuTangGuest, IP add
                    ress 192.168.50.167
                    WiFi: wifi evt: 3
                    WiFi: pm open,type:2 0
                    WiFi: scandone
                    WiFi: add 0
                    WiFi: aid 20
                    WiFi: cnt
                    WiFi:
                    WiFi: wifi evt: 0
                    ress 192.168.50.167
                    WiFi: wifi evt: 3
                    SIamundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                    • SIamundefined
                      SIam @Hellpilot
                      @hellpilot Is there a difference between your WuTangGuest and your WuTangLan network (maybe wutanguest without password? Another ip-Adress range?)
                        T3P3Tony administrators @Hellpilot
                        @hellpilot are you trying to access the printer from an IP outside of the local network range of the guest network ? i.e. the machine you are connecting from should by 192.168.50.nnn try that.
                          Hellpilot @T3P3Tony
                          @t3p3tony Looks like all the IPs im using are 192.168.50.nnn or .nn
                            Hellpilot @SIam
                            @siam I don't see any major differences. Intranet access is disabled on my guest network. But changing it doesn't seem to have effect.
                            T3P3Tonyundefined SIamundefined 3 Replies Last reply Reply Quote 0
                              @hellpilot can you ping the Duet from your machine?
                              (thanks @SIam)!
                              • SIamundefined
                                SIam @T3P3Tony
                                @t3p3tony said in Connecting duet wifi 2:
                                cn you pin the Duet from your machine?
                                translated: can you ping your machine 😄
                                • SIamundefined
                                  SIam @Hellpilot
                                  I'm not sure that this will help, but this is the last idea I have.
                                  Remove all known networks (M588) then reflash your duet board (M997) and after this try to add your wifi again
                                    @hellpilot and the other related question from me is what is the IP you are trying to connect from.
                                      Hellpilot @SIam
                                      @siam
                                      @T3P3Tony
                                      Awh no luck with this method of reflash of M588. Even reinstalled firmware. Interesting enough I changed my main 2.4 network to enable WPS. I no longer get "Failed while trying to connect to WuTangLan24", it is now "Wrong password while trying to connect to WuTangLan24".
                                      I am not to sure what is meant by pinging?
                                      T3P3Tonyundefined SIamundefined 2 Replies Last reply Reply Quote 0
                                        @hellpilot if you are on windows open up a command prompt and send:
                                        ping <ip-address>
                                        where the ip address is the once your machine is getting.
                                        Also to check what ip address the machine you are using has send:
                                        ipconfig
                                        basically i want to see if you can communicate with the duet, and if you are on the same subnet.
                                        • SIamundefined
                                          SIam @Hellpilot
                                          As shown in your 7. Post the error is the same .... but why nobody knows (at the moment). Which router do you use ? Did you run the router with the latest firmware? Have you tried another channel for your wifi?
                                            Hellpilot @T3P3Tony
                                            @t3p3tony
                                            This was while connected to my guest network.
                                            Pinging 192.168.50.167 with 32 bytes of data:
                                            Reply from 192.168.50.177: Destination host unreachable.
                                            Ping statistics for 192.168.50.167:
                                            Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),Pinging 192.168.50.167 with 32 bytes of data:
                                            Also
                                            Subnet Mask . . . . . . . . . . . : 255.255.255.0
