    M540 and MAC address problems on Duet 3
    Using Duet Controllers
    598
      T3P3Tony administrators @sergio
      @sergio are you using the Duet 3 in stand alone mode or SBC mode?
      I don't think it will be firmware related but I notice you are on 3.3RC1, can you try 3.3 stable as well please
      sergioundefined 1 Reply Last reply Reply Quote 0
      • sergioundefined
        sergio @sergio
        More tests, updated firmware to 3.4 Beta 4
        Board: Duet 3 MB6HC (MB6HC)
        Firmware: RepRapFirmware for Duet 3 MB6HC 3.4.0beta4 (2021-09-27)
        Turned off network before changing MAC
        M552 S0
        M540 P00:AD:BE:EF:CA:00
        M552 P192.168.102.101
        M554 P192.168.0.1
        M553 P255.255.0.0
        M552 S1
        Stills gives:
        Unicast reply from 192.168.101.121 [BE:62:38:3A:53:37] 0.994ms
        Second duet in conflict:
        Unicast reply from 192.168.102.105 [BE:62:38:3A:53:37] 1.384ms
        M540 gcode returns the right MAC, but it doesn't seem to be propagated to layer 2.
        • sergioundefined
          sergio @T3P3Tony
          @t3p3tony
          Will try 3.3 stable, and it is stand alone.
          We use it pretty much as a duet 2.
          dc42undefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
            dc42 administrators @sergio
            @sergio please run M122 on each of those 2 Duets and post the result.
              @sergio I can reproduce this.
              from start on my test board:
              M540
              MAC: be:62:3b:3a:53:32
              M122
              RepRapFirmware for Duet 3 MB6HC version 3.4.0beta4+1 (2021-10-04 17:49:00) running on Duet 3 MB6HC v1.01 or later (standalone mode)
              Board ID: 08DJM-956L2-G43S8-6JKD0-3S46T-9U2YF
              Used output buffers: 1 of 40 (15 max)
              Static ram: 151104
              Dynamic ram: 97260 of which 12 recycled
              Never used RAM 102296, free system stack 200 words
              Tasks: NETWORK(ready,19.3%,249) ETHERNET(notifyWait,0.1%,173) HEAT(notifyWait,0.0%,273) Move(notifyWait,0.0%,351) CanReceiv(notifyWait,0.0%,797) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,8.4%,92) MAIN(running,48.3%,943) IDLE(ready,23.9%,30), total 100.0%
              Owned mutexes:
              Last reset 00:01:41 ago, cause: software
              Last software reset at 2021-10-06 10:57, reason: User, GCodes spinning, available RAM 102296, slot 0
              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
              Error status: 0x00
              Step timer max interval 128
              MCU temperature: min 36.3, current 36.6, max 37.6
              Supply voltage: min 23.7, current 23.8, max 23.8, under voltage events: 0, over voltage events: 0, power good: yes
              12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
              Driver 0: pos 0, standstill, SG min/max 0/0, reads 39502, writes 11 timeouts 0
              Driver 1: pos 0, standstill, SG min/max 0/0, reads 39502, writes 11 timeouts 0
              Driver 2: pos 0, standstill, SG min/max 0/0, reads 39499, writes 14 timeouts 0
              Driver 3: pos 0, standstill, SG min/max 0/0, reads 39502, writes 11 timeouts 0
              Driver 4: pos 0, standstill, SG min/max 0/0, reads 39499, writes 14 timeouts 0
              Driver 5: pos 0, standstill, SG min/max 0/0, reads 39500, writes 14 timeouts 0
              Date/time: 2021-10-06 10:59:04
              Slowest loop: 4.44ms; fastest: 0.05ms
              === Storage ===
              Free file entries: 10
              SD card longest read time 3.1ms, write time 0.0ms, max retries 0
              DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
              === MainDDARing ===
              === AuxDDARing ===
              Segments left: 0
              Movement lock held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              SBC is idle in state(s) 0
              Daemon is idle in state(s) 0
              Aux2 is idle in state(s) 0
              Code queue is empty
              === CAN ===
              Messages queued 908, received 1638, lost 0, longest wait 1ms for reply type 6041, peak Tx sync delay 5, free buffers 49 (min 48), ts 507/506/0
              Tx timeouts 0,0,0,0,0,0
              === Network ===
              Slowest loop: 7.37ms; fastest: 0.02ms
              HTTP sessions: 1 of 8
              - Ethernet -
              State: active
              Error counts: 0 0 1 0 0
              Reply from arp on the laptop connected to the Duet 3
              PS C:\WINDOWS\system32> arp -a 192.168.1.12
              Interface: 192.168.1.2 --- 0x5
                Internet Address      Physical Address      Type
                192.168.1.12          be-62-3b-3a-53-32     dynamic
              Then changing the MAC using M540
              M540
              MAC: be:62:3b:3a:53:34
              M540 Pbe:62:3b:3a:53:34
              The mac address is reported as changed
              M122
              Used output buffers: 3 of 40 (27 max)
              Static ram: 151104
              Tasks: NETWORK(ready,26.4%,249) ETHERNET(notifyWait,0.1%,173) HEAT(notifyWait,0.0%,273) Move(notifyWait,0.0%,351) CanReceiv(notifyWait,0.0%,797) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,8.8%,92) MAIN(running,64.6%,943) IDLE(ready,0.0%,30), total 100.0%
              Owned mutexes:
              Last reset 00:04:26 ago, cause: software
              Error status: 0x00
              Step timer max interval 129
              MCU temperature: min 36.3, current 36.5, max 36.7
              Driver 0: pos 0, standstill, SG min/max n/a, reads 60751, writes 0 timeouts 0
              Driver 1: pos 0, standstill, SG min/max n/a, reads 60752, writes 0 timeouts 0
              Driver 2: pos 0, standstill, SG min/max n/a, reads 60752, writes 0 timeouts 0
              Driver 3: pos 0, standstill, SG min/max n/a, reads 60752, writes 0 timeouts 0
              Driver 4: pos 0, standstill, SG min/max n/a, reads 60752, writes 0 timeouts 0
              Driver 5: pos 0, standstill, SG min/max n/a, reads 60751, writes 0 timeouts 0
              Date/time: 2021-10-06 11:01:49
              Slowest loop: 4.51ms; fastest: 0.05ms
              === Storage ===
              === MainDDARing ===
              === AuxDDARing ===
              Segments left: 0
              Code queue is empty
              === CAN ===
              Messages queued 1484, received 2640, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 6, free buffers 49 (min 49), ts 825/825/0
              === Network ===
              Slowest loop: 2.55ms; fastest: 0.02ms
              - Ethernet -
              State: active
              However its not reported as changed using arp (I tested deleting the entry first incase it was a refresh issue)
              PS C:\WINDOWS\system32> arp -d 192.168.1.12
              • sergioundefined
                sergio @dc42
                @t3p3tony can confirm on his test base, I guess it could be a firmware issue?
                I will try to go down to 3.2 for the machine that is in conflict, since it is not very happy in the network.
                M122
                RepRapFirmware for Duet 3 MB6HC version 3.4.0beta4 (2021-09-27 11:31:18) running on Duet 3 MB6HC v1.01 or later (standalone mode)
                Board ID: 08DJM-956L2-G43S8-6J9D0-3SJ6L-9A0GG
                Used output buffers: 1 of 40 (33 max)
                Static ram: 151080
                Dynamic ram: 93860 of which 0 recycled
                Never used RAM 105732, free system stack 206 words
                Tasks: NETWORK(ready,29.8%,225) ETHERNET(notifyWait,0.1%,170) HEAT(notifyWait,0.0%,321) Move(notifyWait,0.0%,351) CanReceiv(notifyWait,0.0%,906) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,8.2%,92) MAIN(running,61.9%,1113) IDLE(ready,0.0%,30), total 100.0%
                Owned mutexes:
                Last reset 00:59:19 ago, cause: software
                Last software reset at 2021-10-06 11:29, reason: User, GCodes spinning, available RAM 105732, slot 2
                Error status: 0x00
                Step timer max interval 133
                MCU temperature: min 32.8, current 34.1, max 34.2
                Supply voltage: min 27.6, current 27.9, max 28.1, under voltage events: 0, over voltage events: 0, power good: yes
                12V rail voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0
                Driver 0: pos 0, standstill, SG min/max 0/0, reads 54487, writes 17 timeouts 0
                Driver 1: pos 0, standstill, SG min/max 0/0, reads 54487, writes 17 timeouts 0
                Driver 2: pos 0, standstill, SG min/max 0/0, reads 54487, writes 17 timeouts 0
                Driver 3: pos 0, standstill, SG min/max 0/0, reads 54487, writes 17 timeouts 0
                Driver 4: pos 0, standstill, SG min/max 0/0, reads 54494, writes 11 timeouts 0
                Driver 5: pos 0, standstill, SG min/max 0/0, reads 54488, writes 17 timeouts 0
                Date/time: 2021-10-06 12:28:42
                Slowest loop: 6.31ms; fastest: 0.05ms
                === Storage ===
                SD card longest read time 2.6ms, write time 0.0ms, max retries 0
                DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: mesh, comp offset 0.000
                === MainDDARing ===
                === AuxDDARing ===
                Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 2 -1 -1 -1
                Segments left: 0
                Code queue is empty
                === CAN ===
                Messages queued 32045, received 13, lost 0, longest wait 1ms for reply type 6018, peak Tx sync delay 6, free buffers 49 (min 48), ts 17796/17795/0
                === Network ===
                Slowest loop: 10.23ms; fastest: 0.02ms
                HTTP sessions: 4 of 8
                - Ethernet -
                State: active
                Socket states: 5 5 2 2 2 2 0 0
                T3P3Tonyundefined dc42undefined 2 Replies Last reply Reply Quote 0
                  @sergio if 3.2 resolves the issue that would be helpful to know.
                    @sergio what I need is the M122 reports from both duets that are being given the same MAC address.
                    sergioundefined 2 Replies Last reply Reply Quote 0
                    • sergioundefined
                      sergio @dc42
                      Sorry, I was asking someone to turn off that machine in that factory. I cannot access both remotely through the VPN so I needed remote hands to help me.
                      m122
                      RepRapFirmware for Duet 3 MB6HC version 3.3RC1 (2021-05-01 09:12:50) running on Duet 3 MB6HC v1.01 or later (standalone mode)
                      Board ID: 08DJM-956L2-G43S8-6J9D0-3SJ6Q-9A0YG
                      Used output buffers: 3 of 40 (15 max)
                      Static ram: 150680
                      Dynamic ram: 90564 of which 516 recycled
                      Never used RAM 109576, free system stack 154 words
                      Tasks: NETWORK(ready,31.5%,226) ETHERNET(notifyWait,1.7%,112) HEAT(delaying,0.2%,295) Move(notifyWait,0.4%,268) CanReceiv(notifyWait,0.0%,945) CanSender(notifyWait,0.0%,359) CanClock(delaying,0.1%,335) TMC(notifyWait,96.6%,93) MAIN(running,93.5%,1114) IDLE(ready,0.0%,29), total 224.0%
                      Owned mutexes:
                      Last reset 17:11:23 ago, cause: software
                      Last software reset time unknown, reason: User, GCodes spinning, available RAM 109576, slot 2
                      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
                      Error status: 0x00
                      Aux0 errors 0,0,0
                      Aux1 errors 0,0,0
                      Step timer max interval 224
                      MCU temperature: min 39.2, current 41.6, max 44.2
                      Supply voltage: min 23.9, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                      Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/8/0, gc cycles 0
                      Driver 0: position 46840, standstill, reads 18330, writes 19 timeouts 0, SG min/max 0/194
                      Driver 1: position 46831, standstill, reads 18330, writes 19 timeouts 0, SG min/max 0/174
                      Driver 2: position 46839, standstill, reads 18330, writes 19 timeouts 0, SG min/max 0/190
                      Driver 3: position 0, standstill, reads 18336, writes 14 timeouts 0, SG min/max 0/0
                      Driver 4: position 0, standstill, reads 18336, writes 14 timeouts 0, SG min/max 0/0
                      Driver 5: position 0, standstill, reads 18339, writes 11 timeouts 0, SG min/max 0/0
                      Date/time: 2021-10-06 11:47:54
                      Slowest loop: 6.42ms; fastest: 0.05ms
                      === Storage ===
                      DMs created 125, maxWait 146ms, bed compensation in use: none, comp offset 0.000
                      === MainDDARing ===
                      Scheduled moves 5, completed moves 5, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                      === AuxDDARing ===
                      Heater 1 is on, I-accum = 0.0
                      Segments left: 0
                      Code queue is empty.
                      === CAN ===
                      Messages queued 556955, send timeouts 556952, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 49 (min 49)
                      Last cancelled message type 30 dest 127
                      === Network ===
                      Slowest loop: 6.08ms; fastest: 0.02ms
                      HTTP sessions: 2 of 8
                      - Ethernet -
                      State: active
                      • sergioundefined
                        sergio @dc42
                        None of my Duet3 change MAC address.
                        Here is another example:
                        ; CONFIGURACION GENERAL
                        G90                            ; Establecer coordenadas absolutas
                        M83                            ; Establecer movimientos del motor relativos
                        M550 P"AM_204"             ; Nombre de la máquina (Afecta a la interfaz, no se si también a su identidad en la red)
                        ;Configuración de RED
                        ; M540 P0xB1:0xEF:0xD0:0xAD:0xDD:0xFD ; This format doesn't work anymore
                        M540 PB1:EF:D0:AD:DD:FD
                        M552 P192.168.102.104            ; Activar comunicación por red, con IP local 1.130
                        M554 P192.168.0.1            ; Puerta de enlac
                        M553 P255.255.0.0              ; Mascara de red
                        M586 P0 S1                     ; Activa protocolo HTTP
                        M586 P1 S1                     ; Desactiva protocolo FTP
                        M586 P2 S0                     ; Desactiva TELNET
                        M552 S1
                        Reported by the duet:
                        M540
                        MAC: b1:ef:d0:ad:dd:fd
                        Arping returns [BE:62:39:3B:53:31]
                        $ arping -c 1000 192.168.102.104 -I ens3
                        ARPING 192.168.102.104 from 192.168.102.1 ens3
                        Unicast reply from 192.168.102.104 [BE:62:39:3B:53:31]  0.802ms
                        M122
                        RepRapFirmware for Duet 3 MB6HC version 3.3beta2 running on Duet 3 MB6HC v1.01 or later (standalone mode)
                        Board ID: 08DJM-956L2-G43S8-6J1D2-3S86S-1A32D
                        Used output buffers: 1 of 40 (13 max)
                        Static ram: 148476
                        Dynamic ram: 90516 of which 548 recycled
                        Never used RAM 114652, free system stack 154 words
                        Tasks: NETWORK(ready,234) ETHERNET(notifyWait,120) HEAT(delaying,278) CanReceiv(notifyWait,945) CanSender(notifyWait,360) CanClock(delaying,335) TMC(notifyWait,58) MAIN(running,1113) IDLE(ready,19)
                        Owned mutexes:
                        Last reset 16:21:16 ago, cause: software
                        Last software reset time unknown, reason: User, GCodes spinning, available RAM 114652, slot 2
                        Error status: 0x00
                        Aux0 errors 0,0,0
                        Aux1 errors 0,0,0
                        MCU temperature: min 48.8, current 51.0, max 54.5
                        Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                        Driver 0: position 47314, standstill, reads 41408, writes 19 timeouts 0, SG min/max 0/172
                        Driver 1: position 47293, standstill, reads 41409, writes 19 timeouts 0, SG min/max 0/171
                        Driver 2: position 47328, standstill, reads 41409, writes 19 timeouts 0, SG min/max 0/160
                        Driver 3: position 0, standstill, reads 41414, writes 14 timeouts 0, SG min/max 0/0
                        Driver 4: position 0, standstill, reads 41414, writes 14 timeouts 0, SG min/max 0/0
                        Driver 5: position 0, standstill, reads 41417, writes 11 timeouts 0, SG min/max 0/0
                        Date/time: 2021-10-06 11:51:00
                        Slowest loop: 12.65ms; fastest: 0.06ms
                        === Storage ===
                        SD card longest read time 4.4ms, write time 0.0ms, max retries 0
                        DMs created 125, maxWait 51ms, bed compensation in use: none, comp offset 0.000
                        === MainDDARing ===
                        === AuxDDARing ===
                        Segments left: 0
                        === CAN ===
                        Messages queued 529894, send timeouts 529891, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 49 (min 49)
                        === Network ===
                        Slowest loop: 12.65ms; fastest: 0.02ms
                        - Ethernet -
                        State: active
                        Socket states: 5 2 2 2 2 2 0 0
                        Best.
                        Sergio
                        • sergioundefined
                          sergio @T3P3Tony
                          @t3p3tony
                          3.2 doesn't resolve the issue.
                            @sergio I confirm that there are two bugs:
                            1. M540 does not set the MAC address in the Ethernet driver;
                            2. When constructing a default MAC address, the last byte of the processor unique ID is not used. This means that multiple Duet 3 boards from the same manufacturing batch may have the same default MAC address.
                            #2 is quick to fix so the fix will be in 3.4.0beta5, which we hope to release later today. #1 may take a little longer.
                            • sergioundefined
                              sergio @dc42
                              @dc42 Thanks a lot.
                              • sergioundefined
                                sergio @dc42
                                If you are looking into that code. The hex format also doesn't seem to work anymore, not sure if you are removing backwards compatibility, but if that is the case a note would be good on the M540 description.
                                Thanks a lot for the fast response.
                                Sergio
                                  @sergio yes that hex format has been removed. The M540 example doesn't use it, see https://duet3d.dozuki.com/Wiki/M540.
                                    @sergio the default MAC address clash problem should be fixed in 3.4b5:
                                    https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-Beta-&-RC#reprapfirmware-340beta5
                                    https://github.com/Duet3D/RepRapFirmware/releases/tag/3.4.0beta5
                                    • sergioundefined
                                      sergio @T3P3Tony
                                      @t3p3tony Just updated the firmware and I can confirm that the MAC is correct. Thanks
                                      • jay_s_ukundefined jay_s_uk referenced this topic
