    No Movement with RRF3.1+
    1.1k
      @curlypaul, you've posted your new config,g file, but please can you post the working RRF2.02 config.g file too so that I can work out your machine configuration.
      Vetiundefined curlypaulundefined 2 Replies Last reply Reply Quote 0
      • Vetiundefined
        Veti @dc42
        @dc42 but what would make all motors stop moving in rrf3 if he has a bad driver on the duex5?
        • curlypaulundefined
          curlypaul @dc42
          @dc42 config.g from 2.02 below..
          The one thing that you may notice is that I have to use M669 K5 to get correct behavior, Not K8
          ; Configuration file for Duet WiFi (firmware version 2.02)
          ; generated by RepRapFirmware Configuration Tool v2.1.3 on Sun Dec 08 2019 16:18:30 GMT+0000 (Greenwich Mean Time)
          G90                                     ; send absolute coordinates...
          M83                                     ; ...but relative extruder moves
          M550 P"IDEX"                    		; set printer name
          M669 K5                                ; select CoreXY mode
          M551 P"curly"                           ; set password
          M552 S1                                 ; enable network
          M586 P0 S1                              ; enable HTTP
          M586 P1 S0                              ; disable FTP
          M586 P2 S0                              ; disable Telnet
          M569 P0 S1               		                ; physical drive 0 goes forwards
          M569 P1 S0	             		                ; physical drive 1 goes forwards
          M569 P2 S0                 	 	          	    ; physical drive 2 goes forwards
          M569 P3 S1  									; physical drive 3 goes forwards
          M569 P4 S0  									; physical drive 4 goes forwards
          M569 P5 R-1  									; physical drive 5 disabled
          M569 P6 S1  									; physical drive 3 goes forwards
          M569 P7 S1	                        			; physical drive 3 goes forwards
          M584 X0 Y1 Z2 U4 V3 E6:7 P4                   			; set drive mapping
          M350 X16 Y16 U16 V16 Z16 E16:16 I1		     			        ; Configure microstepping with interpolation
          M92 X160 Y160 U160 V160 Z1280 E396:396		 			; Set steps per mm
          M566 X600 Y600 U600 V600 Z50 E3000:3000              	                ; Set maximum instantaneous speed changes (mm/min)
          M203 X20000 Y20000 U20000 V20000 Z600 E9000:9000      	; Set maximum speeds (mm/min)
          M201 X1000 Y1000 U1000 V1000 Z600 E3000:3000              	; Set accelerations (mm/s^2)
          ;M204 P1500 T1800										; Set printing and travel accerations
          M906 X1400 Y1400 U1400 V1400 Z1800 E1200:1200 I30     	; Set motor currents (mA) and motor idle factor in per cent
          M84 S60                                 				; Set idle timeout
          M208 X-3 Y-92 U100 Z0 S1                      	        ; set axis min
          M208 X380 Y320 U425 Z325 S0                 	; set axis max
          M574 X1 Y1 U2 S1                          		; set endstops controlled by ENDSTOPS
          M574 Z1 S2                              		        ; set endstops controlled by probe
          M307 H3 A-1 C-1 D-1                    			; disable heater on PWM channel for BLTouch
          M558 P9 H5 F200 T9000                  			; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X12.5 Y75. Z0.75             			; set Z probe trigger value, offset and trigger height
          M557 X15:350 Y10:278 S67              			; define mesh grid
          M305 P0 T100000 R4700 B4725 C7.060000e-8
          M307 H0 A73.2 C151.3 D12.9 S1.00 V24.3 B0     	; set thermistor + ADC parameters for heater 0
          M143 H0 S90                       	      		                        ; set temperature limit for heater 0 to 120C
          M305 P1 T100000 R4700 B4725 C7.060000e-8        ; set thermistor + ADC parameters for heater 1
          M143 H1 S270                           			                  ; set temperature limit for heater 1 to 280C
          M307 H1 A460.4 C235.5 D4.5 S1.00 V24.3 B0
          M305 P2 T100000 R4700 B4725 C7.060000e-8     	; set thermistor + ADC parameters for heater 1
          M143 H2 S270                           			                ; set temperature limit for heater 1 to 280C
          M307 H2 A600.0 C221.8 D4.6 S1.00 V24.2 B0
          M106 P0 S0 I0 F50 H-1                  			; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M106 P1 S1 I0 F50 H2 T45              	 		; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
          M106 P7 S1 I0 F50 H1 T45               			; set fan 7 value, PWM signal inversion and frequency. Thermostatic control is turned on
          M106 P8 S0 I0 F10 H-1                  			; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M563 P0 S"X-AXIS" D0 H1 F8                      ; define tool 0
          G10 P0 X0 Y0 U0 Z0                         		; set tool 0 axis offsets
          G10 P0 R0 S0                            		; set initial tool 0 active and standby temperatures to 0C
          M563 P1 S"U-AXIS" D1 H2 X3 F0					; Define tool 1
          G10 P1 X0.1 Y-0.3 U0 Z0 						; Set tool 1 axis offsets
          G10 P1 R0 S0 									; Set initial tool 1 active and standby temperatures to 0C
          M563 P2 S"T2 COPY" D0:1 H1:2 X0:3 F0:1			; Define tool 2 Ditto Printing
          G10 P2 X75 Y0 U-75 Z 							; Set tool 2 axis Ditto Printing offsets
          G10 P2 R0 S0 									; Set initial tool 2 active and standby temperatures to 0C
          M567 P2 E1:1 									; Set mix rtio 100% on both extruders
          M501
          • fulgundefined
            fulg
            One thing I noticed yesterday (running 3.2beta3) is that setting a negative tool offset for Z seems to permanently disable movement for that axis. You can move the axis in the Dashboard panel, the current position changes, but no actual movement occurs.
            For example if I do G10 P0 X0 Y0 Z-0.06 then any Z axis movement is disabled and the board behaves as if the drivers were busted. Maybe a similar problem occurs for U.
            It took me a while to realize this was caused by the negative G10 P0 Z-0.06 bit, I was convinced I had somehow managed to kill all four Z drivers on my Duex.
            VORON V2 CoreXY + Duet3 Mini5+ Ethernet v1.0 with Mini2+ expansion, VORON V0 CoreXY + Duet2 Maestro
              Phaedrux Moderator @curlypaul
              @curlypaul said in No Movement with RRF3.1+:
              How did CoreXYU work before? What happened to V?
              curlypaulundefined 1 Reply Last reply Reply Quote 0
                curlypaul @Phaedrux
                @Phaedrux it's a bit hard to explain/remember properly without being with the printer, but the main issue is U will move towards the homed X when homing Y.
                also X,Y,U positions are lost/reset when homing other axis
                Seemingly random but repeatable moves after and during homing.
                Certainly with 2.03,2.04 and 2.05, the UV motors won't move at all if a movement in XY is commanded, resulting in what at the time I called 'angry noises'
                Where as 2.02 set at K5, seems to have the printer work exactly as I'd expect
                It might be best to video the difference and let that explain
                  I wonder if this is a similar issue as here
                  https://forum.duet3d.com/topic/20164/g30-g32-issues-on-duet-wifi-corexyu-with-inductive-probe?_=1606925875835
                  curlypaulundefined 1 Reply Last reply Reply Quote 1
                    curlypaul @Phaedrux
                    @Phaedrux I will give this a try at the weekend
                    Thank you for posting this
                      dc42 administrators @curlypaul
                      @curlypaul I think I know what is going on. The newer version of the TMC2660 driver includes code to reset the microstep position to zero before it enables the driver. That isn't going to work if the driver has been removed. I will disable that feature for drivers that have been disabled using M569 R-1.
                        curlypaul @dc42
                        @dc42 - That's awesome - Thank you (and Tony) for looking into this for me 🙂
