    Part cooling and extruder fans won't turn on
    531
      T3P3Tony administrators @Messiahman
      @messiahman just thought, on the Duet 2 there is a fuse just for the fans, it could be that. please check it.
      Messiahmanundefined 1 Reply Last reply Reply Quote 0
      • Messiahmanundefined
        Messiahman @T3P3Tony
        @t3p3tony which would it be?
            Messiahman
            @t3p3tony I had to open mine up to take a look at the inside because it was all black, so I probably do now need a new one, but this one doesn't appear to have had any wiring on the inside, so I'll go with there's a possibility it was the fuse being that it doesnt appear to have insides
              @t3p3tony Which isstrange because it was basically brand new, nothing got damaged this time around
                @messiahman that is very weird. where did you get the board?
                  @t3p3tony Filastruder
                    @messiahman do you happen to have a spare 1A or 2A mini blade fuse to try in that slot?
                    Messiahmanundefined 2 Replies Last reply Reply Quote 0
                      @t3p3tony I do not, unfortunately. I did just order a pack of 1A fuses online, but that says it will ship on the 20th. I can ask around and see if any of my friends have though
                        @t3p3tony One of my friends had a 2A and after plugging it in the fans work perfectly fine, thank you so much!
                          @messiahman ok great news.
