    Structured Configuration Language
    Future Direction
    439
    • zaptaundefined
      zapta @fcwilt
      As a side note, having a structured configuration language would eliminate most of the confusion with the archaic gcode base configuration. E.g.
      probe {
        dive_height = 20
      • fcwiltundefined
        fcwilt @zapta
        @zapta said in Nothing but trouble with Nozzle as Probe and Mesh Bed Comp:
        probe {
          dive_height = 20
        Trading clarity for compactness.
        You sound like some kind of rebel. 😉
        • zaptaundefined
          zapta @fcwilt
          @fcwilt said in Nothing but trouble with Nozzle as Probe and Mesh Bed Comp:
          Yes, it's a radical idea. We are only 20 years into the 21st century.
          • fcwiltundefined
            fcwilt @zapta
            Would you consider using simplified XML?
            That's what I ended up using for Windows application programming when I wanted to be able to import/export data, including config data.
            • zaptaundefined
              zapta @fcwilt
              XML used to be a hot format, but I think that these days formats such as jASON are more popular because of their simplicity.
              Here is one example 😉
              https://duet3d.dozuki.com/Wiki/Object_Model_of_RepRapFirmware
              T3P3Tonyundefined fcwiltundefined 2 Replies Last reply Reply Quote 1
                T3P3Tony administrators @zapta
                @zapta @fcwilt moved your conversation here to keep the original user's request for help on topic.
                • fcwiltundefined
                  fcwilt @T3P3Tony
                  @t3p3tony
                  Thank you.
                  • fcwiltundefined
                    fcwilt @zapta
                    @zapta said in Structured Configuration Language:
                    It uses curly braces!
                    Makes me wonder about the mental state of those that devised it. 😉
