Cannot get hot end heater to work after change to RR3
Hi. I have just changed my Duet board (I had a fault on the heated bed which caused the last one to get very melty) and , while I have most things working now, I cannot get the hot end to work at all. I have check continuity from the board to the heater and that all looks fine but as soon as I try to turn it on I get a "Not heating up fast enough" error. In fact it's not heating up at all and even the E0Heater or E1 Heater LEDs on the board aren't lighting up. This is my first brush against RR3 and I've probably got something wrong in the configuration but I have now run out of knowledge and cannot see the error. What have I got wrong?
TIA.
; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.4 on Tue Oct 12 2021 19:20:39 GMT+0100 (British Summer Time); General preferences
M550 P"Rostock Max V2" ; set printer name
M665 R140 L340.5 B130 H260 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; X physical drive 0 goes backwards
M569 P1 S1 ; Y physical drive 1 goes forwards
M569 P2 S0 ; Z physical drive 2 goes backwards
M92 X80.00 Y80.00 Z80.00 E663.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; set minimum Z; Endstops
M574 X2 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
M574 Y2 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
M574 Z2 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstop; Z-Probe
M558 P8 R0.4 C"zprobe.in+zprobe.mod" H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
G31 P100 X0 Y0 Z-0.1 ; set Z probe trigger value, offset and trigger height
M557 R85 S20 ; define mesh grid; Heaters
M307 H0 B1 S1.00 R0.5 ; enable bang-bang mode for the bed heater and set PWM limit
M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as PT100 on pin spi.cs1
M950 H1 C"e0temp" T1 ; create nozzle heater output on e0temp and map it to sensor 1
M143 H1 S325 ; set temperature limit for heater 1 to 325C; Fans
M106 P0 S0 H-1 T45 ; set fan 0 value. Thermostatic control is turned off
M563 P0 S"Hot End" D0 H1 F0 ; define tool 0
M501 ; load saved parameters from non-volatile memoryG28 ; home all
@poorskeleton try tuning your hotend.
Assuming its tool 0M303 T0 H240
@jay_s_uk - HI Jay. I tried that but it's not responding at all. Just FYI It was working fine just before the board switch and, TBH there's not much to go wrong from a hardware POV. So it must be something I have in the config.
@poorskeleton
should be
M950 H1 C"e0heat" T1
@jay_s_uk said in Cannot get hot end heater to work after change to RR3:
You bloody star - excellent. That worked.
Thank you.
