    Thermocouple Error : "String too long" with RRF 3.3 stable
    Firmware installation
    441
    • Philippe71undefined
      Philippe71
      Using a Duet 6HC motherboard + Duet 3HC daughter-board, 2 thermocouples connected to the thermocouple board V1.1 on the 3HC
      Firmware Version: 3.3 stable June 16
      Configuration of Thermocouples :
      M308 S1 P"1.spi.cs1" Y"thermocouple-max31856" K"k" ; configure sensor 1 as thermocouple on pin sp1.cs1  expansion board 1
      M950 H1 C"1.out0" T1                               ; create nozzle heater output on 1.out0 and map it to sensor 1
      M143 H1 S498                                       ; set temperature limit for heater 1 to 498C
      M307 H1 B0 S1.00                                   ; disable bang-bang mode for the nozzle heater and set PWM limit
      M308 S2 P"1.spi.cs0" Y"thermocouple-max31856" K"K" ; configure sensor 0 as thermocouple on pin sp1.cs0  expansion board 1
      M950 H2 C"1.out1" T2                               ; create nozzle heater output on 1.out1 and map it to sensor 2
      M143 H2 S498                                       ; set temperature limit for heater 2 to 498C
      M307 H2 B0 S1.00                                   ; disable bang-bang mode for the nozzle heater and set PWM limit
      It worked fine with RRF3.2.2
      I switch to RRF 3.3, I get the error message :
      Error: M308: string too long
      The heaters switch to error status
      Tried with RFF 3.4.0 Beta 4, same error.
      Switch back to RRF3.2.2, everything is OK...
      What am I doing wrong?
        T3P3Tony administrators @Philippe71
        @philippe71 thanks, this bug should be fixed in 3.4b5 in the mean time can you try removing the "-" , e.g:
        M308 S2 P"1.spi.cs0" Y"thermocouplemax31856" K"K"
        This may work.
          Philippe71
          Thank you Tony.
          It works with RRF3.4.0 B5 with the "-" removed...
            @philippe71 said in Thermocouple Error : "String too long" with RRF 3.3 stable:
            Thank you Tony.
            Does it work with the - remaining in b5
              Philippe71
              With RRF3.4.0 B5
              thermocouplemax31856 > Works
              thermocouple-max31856 > does not work
                dc42 administrators @Philippe71
                @philippe71 please check which firmware version you have on the EXP3HC board, by sending M115 B1. That is where the bug was.
                  Philippe71
                  M115 B1
                  Duet EXP3HC firmware version 3.4.0beta5 (2021-10-12 13:58:36)
                    @philippe71 thanks, I marked this to be re-visited for the next 3.4 beta or RC.
                    EDIT: I found and fixed the other bug that was causing this.
