    100C resettable Thermal Cut-Off for 24V heated beat
    • FrcWifiDuetundefined
      FrcWifiDuet
      Hi I'm instaling a 100C auto-resettable Thermal cut-off my 24V head bed for my printer should I worry about the effect of transients on the output of the mosfet controling the PWM on my Duet?
      Maybe a should use a non re-settable one...
      Stephen6309undefined zaptaundefined 2 Replies Last reply Reply Quote 0
      • Stephen6309undefined
        Stephen6309 @FrcWifiDuet
        @frcwifiduet Thermal fuses are not fast acting like fuses. As long as you don't stay above 100C for long where it's mounted, it may not trip.
        • zaptaundefined
          zapta @FrcWifiDuet
          @frcwifiduet said in 100C resettable Thermal Cut-Off for 24V heated beat:
          In the Voron world, the recommendation is to use a one time fuse rather than resettable, but as for the PWM, I don't think it makes a difference.
          BTW, what resettable thermal cut-off do you have in mind?
          FrcWifiDuetundefined 1 Reply Last reply Reply Quote 0
            FrcWifiDuet @zapta
            @zapta said in 100C resettable Thermal Cut-Off for 24V heated beat:
            For now I mounted one exactly like those in a Kettle 100C ;-), after activation the thermo expandable medium while contract and close the circuit again...
