    Arduino PanelDue Sniffer
    • dhusoloundefined
      dhusolo
      I have 2 different printers I am trying to get this working on. 1 has RRF3.3 and the other has RRF3.4.0beta5. Both have Duet 3 with RPI 4 as SBC, Duet Tool Board v1.1, 5v PSU wired to PS_ON so I can turn the main PSU on and off with the ATX button in DWC.
      We use an Arduino Pro Mini to control 3 RGB LED NeoPixel rings to display different printer status. The Arduino polls the PanelDue port with M409 F"d99f".
      I didn't write the sketch so I'm not completely familiar with it. Even though the 24v PSU is off, the PanelDue and Arduino are still powered off the IO ports. I would like to have the Arduino turn the LEDs off when the ATX power is off.
      The sketch can be found here
      The RRR3.4.0beta5 M409 F"d99f" output
      10/22/2021, 8:07:13 PM	M409 F"d99f"
          "key": "",
          "flags": "d99f",
          "result": {
              "boards": [
                      "mcuTemp": {
                          "current": 43
                      "v12": {
                          "current": 0.2
                      "vIn": {
                          "current": 0.2
                      "mcuTemp": {
                          "current": 38.5
                      "vIn": {
                          "current": 14
              "fans": [
                      "actualValue": -1,
                      "requestedValue": 0,
                      "rpm": -1
                      "actualValue": -1,
                      "requestedValue": 1,
                      "rpm": -1
                      "actualValue": 1,
                      "rpm": -1
              "heat": {
                  "heaters": [
                          "active": 0,
                          "avgPwm": 0,
                          "current": 22.4,
                          "standby": 0,
                          "state": "off"
                          "active": 0,
                          "avgPwm": 0,
                          "current": 2000,
                          "standby": 0,
                          "state": "offline"
              "inputs": [
                      "feedRate": 250,
                      "inMacro": false,
                      "lineNumber": 0,
                      "state": "waiting"
                      "feedRate": 50,
                      "inMacro": false,
                      "lineNumber": 0,
                      "state": "idle"
                      "feedRate": 85,
                      "inMacro": false,
                      "lineNumber": 46798,
                      "state": "idle"
                      "feedRate": 50,
                      "inMacro": false,
                      "lineNumber": 0,
                      "state": "idle"
                      "feedRate": 50,
                      "inMacro": false,
                      "lineNumber": 466152,
                      "state": "idle"
                      "feedRate": 50,
                      "inMacro": false,
                      "lineNumber": 0,
                      "state": "idle"
                      "feedRate": 50,
                      "inMacro": false,
                      "lineNumber": 4,
                      "state": "idle"
                      "feedRate": 50,
                      "inMacro": false,
                      "lineNumber": 0,
                      "state": "idle"
                      "feedRate": 50,
                      "inMacro": false,
                      "lineNumber": 0,
                      "state": "idle"
                      "feedRate": 50,
                      "inMacro": false,
                      "lineNumber": 0,
                      "state": "idle"
                      "feedRate": 50,
                      "inMacro": false,
                      "lineNumber": 471962,
                      "state": "idle"
                      "feedRate": 50,
                      "inMacro": false,
                      "lineNumber": 0,
                      "state": "idle"
              "job": {
                  "filePosition": 0,
                  "timesLeft": {}
              "move": {
                  "axes": [
                          "machinePosition": -24.4,
                          "userPosition": -24.4
                          "machinePosition": 300,
                          "userPosition": 300
                          "machinePosition": 70.02,
                          "userPosition": 70.02
                  "currentMove": {
                      "acceleration": 0,
                      "deceleration": 0,
                      "requestedSpeed": 0,
                      "topSpeed": 0
                  "extruders": [
                          "position": 16371.9,
                          "rawPosition": 16342.9
                  "virtualEPos": -0.3
              "sensors": {
                  "analog": [
                          "lastReading": 22.4
                          "lastReading": 2000
                          "lastReading": 43
                  "endstops": [
                          "triggered": true
                          "triggered": false
                          "triggered": false
                  "filamentMonitors": [],
                  "gpIn": [
                      null,
                          "value": 0
                  "probes": [
                          "value": [
                              0
              "seqs": {
                  "boards": 2553,
                  "directories": 0,
                  "fans": 12,
                  "global": 0,
                  "heat": 24,
                  "inputs": 5396,
                  "job": 43,
                  "move": 163,
                  "network": 2,
                  "reply": 0,
                  "sensors": 31,
                  "spindles": 0,
                  "state": 30,
                  "tools": 15,
                  "volChanges": [
                      0
                  "volumes": 4
              "spindles": [
                      "current": 0,
                      "state": "unconfigured"
                      "current": 0,
              "state": {
                  "currentTool": -1,
                  "gpOut": [],
                  "msUpTime": 97,
                  "nextTool": 0,
                  "previousTool": -1,
                  "status": "off",
                  "time": "2021-10-22T20:07:13",
                  "upTime": 355317
              "tools": [
                      "active": [
                          0
                      "isRetracted": false,
                      "standby": [
                          0
                      "state": "off"
      The RRR3.3 M409 F"d99f" output
      10/22/2021, 8:11:17 PM	M409 F"d99f"
          "key": "",
          "flags": "d99f",
          "result": {
              "boards": [
                      "mcuTemp": {
                          "current": 33.8
                      "v12": {
                          "current": 12.1
                      "vIn": {
                          "current": 24.6
                      "mcuTemp": {
                          "current": 0
                      "v12": {
                          "current": 0
                      "vIn": {
                          "current": 0
              "fans": [
                      "actualValue": 0,
                      "rpm": -1
                      "actualValue": 0,
                      "rpm": -1
                      "actualValue": 0,
                      "rpm": -1
              "heat": {
                  "heaters": [
                          "active": 0,
                          "current": 29.1,
                          "standby": 0,
                          "state": "off"
                          "active": 0,
                          "current": 26.9,
                          "standby": 0,
                          "state": "off"
              "inputs": [
                      "feedRate": 50,
                      "lineNumber": 0,
                      "state": "waiting"
                      "feedRate": 50,
                      "lineNumber": 0,
                      "state": "idle"
                      "feedRate": 60,
                      "lineNumber": 75752,
                      "state": "idle"
                      "feedRate": 50,
                      "lineNumber": 0,
                      "state": "idle"
                      "feedRate": 50,
                      "lineNumber": 4197,
                      "state": "idle"
                      "feedRate": 50,
                      "lineNumber": 0,
                      "state": "idle"
                      "feedRate": 50,
                      "lineNumber": 2625,
                      "state": "idle"
                      "feedRate": 50,
                      "lineNumber": 0,
                      "state": "idle"
                      "feedRate": 50,
                      "lineNumber": 0,
                      "state": "idle"
                      "feedRate": 50,
                      "lineNumber": 0,
                      "state": "idle"
                      "feedRate": 50,
                      "lineNumber": 131557,
                      "state": "idle"
                      "feedRate": 50,
                      "lineNumber": 0,
                      "state": "idle"
              "job": {
                  "filePosition": 2218005,
                  "timesLeft": {}
              "move": {
                  "axes": [
                          "machinePosition": 160,
                          "userPosition": 160
                          "machinePosition": 184,
                          "userPosition": 184
                          "machinePosition": 12.602,
                          "userPosition": 12.602
                  "currentMove": {
                      "acceleration": 0,
                      "deceleration": 0,
                      "topSpeed": 0
                  "extruders": [
                          "position": 3500.7,
                          "rawPosition": 3485.1
                  "virtualEPos": 1.9305
              "sensors": {
                  "analog": [
                          "lastReading": 29.1
                          "lastReading": 26.9
                  "endstops": [
                          "triggered": false
                          "triggered": false
                          "triggered": false
                  "gpIn": [
                      null,
                          "value": 0
                  "probes": [
                          "value": [
                              0
              "seqs": {
                  "boards": 3,
                  "directories": 0,
                  "fans": 12,
                  "global": 0,
                  "heat": 24,
                  "inputs": 177,
                  "job": 63,
                  "move": 162,
                  "network": 2,
                  "reply": 0,
                  "sensors": 30,
                  "spindles": 0,
                  "state": 19,
                  "tools": 15,
                  "volChanges": [
                      0
                  "volumes": 0
              "spindles": [
                      "current": 0,
                      "current": 0,
              "state": {
                  "atxPower": true,
                  "currentTool": -1,
                  "gpOut": [
                          "pwm": 0.07
                  "msUpTime": 232,
                  "nextTool": 0,
                  "previousTool": -1,
                  "status": "idle",
                  "time": "2021-10-22T20:11:15",
                  "upTime": 7548
              "tools": [
                      "active": [
                          0
                      "standby": [
                          0
                      "state": "off"
      o_lampeundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • o_lampeundefined
        o_lampe @dhusolo
        @dhusolo I don't know if it would solve the problem, but why not port the Arduino sketch to a python script, running on the RPi4?
        dhusoloundefined 1 Reply Last reply Reply Quote 0
          dc42 administrators @dhusolo
          @dhusolo if you monitor object model field state.status this will have value "off" when the Duet has turned off power using the PS_ON output.
          • dhusoloundefined
            dhusolo @o_lampe
            @o_lampe I'm a moderator with the BLV printing community. So anything I do I have to make sure it stays close to the standard BOM. The BOM calls for a Duet 2 WiFi. Eventually we'll move it to ESP8266 but at the moment it's easier to maintain it on an Arduino.
            • pfnundefined pfn referenced this topic
