Bl touch dont work after print
1.1k
    Amagatth @T3P3Tony
    @t3p3tony
    that is the end of the Gcode file
    "G1 F3300 X290.57 Y169.897 E0.07422
    G1 X290.64 Y169.827
    G0 F9000 X290.726 Y169.129
    ;TIME_ELAPSED:13948.855035
    G1 F4800 E-0.5
    M140 S0
    M82 ;absolute extrusion mode
    M107 P1
    M98 P"end.g"
    M83 ;relative extrusion mode
    M104 S0
    ;End of Gcode"
    the begin
    ";FLAVOR:RepRap
    ;TIME:13948
    ;Filament used: 31.0262m
    ;Layer height: 0.3
    ;MINX:67.427
    ;MINY:146.116
    ;MINZ:0.2
    ;MAXX:332.574
    ;MAXY:253.879
    ;MAXZ:7.3
    ;LINEARADVANCEPROCESSED
    ;Generated with Cura_SteamEngine 4.11.0
    T0
    M190 S50
    M104 S230
    M109 S230
    M98 p"begin.g"
    M83
    G1 F4800 E-0.5
    ;LAYER_COUNT:24
    M572 S0.000000 D0 ;added by LinearAdvanceSettingPlugin
    ;LAYER:0
    M106 S255 P1
    G1 F1800 Z0.4
    G0 F3600 X100.8 Y160.246 Z0.4
    ;TYPE:SKIRT
    G1 F1800 Z0.2
    G1 F1920 E0.5
    G1 F3000 X101.517 Y159.802 E0.02721
    G1 X102.116 Y159.454 E0.02235"
    the begin . g file
    M98 P"bed.g"
    G29 S1
    G92 E0 ;Reset Extruder
    G1 Z10.0 F4000 ;Move Z Axis up
    G1 X30.1 Y20 F8000.0
    G1 X30.1 Y20 Z0.28 F5000.0 ;Move to start position
    G1 X30.1 Y200.0 Z0.19 F2500.0 E15 ;Draw the first line
    G1 X30.4 Y200.0 Z0.19 F5000.0 ;Move to side a little
    G1 X30.4 Y20 Z0.19 F2500.0 E30 ;Draw the second line
    G1 Z5.0 F3000 ;Move Z Axis up
    M83 "
    the bed.g
    "; bed.g
    ; generated by RepRapFirmware Configuration Tool v3.3.2 on Thu Sep 02 2021 15:45:03 GMT+0200 (heure d’été d’Europe centrale)
    m280 p0 s160
    M400
    M280 P0 S90
    M280 P8 S10
    M400
    M98 P"0:/sys/homeall.g"
    G1 Z20
    G30 P0 X10 Y200 Z-9999
    G30 P1 X375 Y200 Z-9999 S2
    M402
    G1 X200 Y200 F10000"
    the end.g files
    "G91 ;Relative positioning
    G1 E-5 F2700 ;Retract a bit
    G1 E-5 Z0.2 F2400 ;Retract and raise Z
    G1 X5 Y5 F3000 ;Wipe out
    G1 Z10 ;Raise Z more
    G90 ;Absolute positionning
    G1 X0 Y0 ;Present print
    M106 S0 ;Turn-off fan
    M104 S0 ;Turn-off hotend
    M140 S0 ;Turn-off bed
    M98 P"homex.g"
    M98 P"homey.g"
    M280 p0 s160
    M280 P0 S90
    M280 P0 S10
    M400
    M280 P0 S160
    M400"
    undefined 1 Reply Last reply 19 Oct 2021, 11:23 Reply Quote 0
      T3P3Tony administrators @Amagatth
      @amagatth please do the tests as I suggested. For example you are calling homing files. maybe they are influencing this depending on what's in them
      undefined 2 Replies Last reply 19 Oct 2021, 12:28 Reply Quote 0
        Amagatth @T3P3Tony
        @t3p3tony ok i try that
          Amagatth @T3P3Tony
          @t3p3tony I tony the bl stop work when i send
          When the extrudeur work the bl stop to work
          undefined 1 Reply Last reply 22 Oct 2021, 08:39 Reply Quote 0
            @amagatth ok so that is progress. Please post your config.g (using the </> tag to make it easy to view) along with images of how the BL touch is connected to the Duet and how it is mounted, showing the extruder as well.
            undefined 1 Reply Last reply 22 Oct 2021, 10:42 Reply Quote 0
              Amagatth @T3P3Tony
              ; Configuration file for Duet 3 (firmware version 3.3)
              M550 P"Maker" ; set printer name
              M669 K1 ; switch to CoreXY mode; configure microstepping with interpolation
              M569 P0.0 S1 D2 ; physical drive 0.1 goes forwards
              M569 P0.1 S1 D2 ; physical drive 0.2 goes forwards
              M569 P0.3 S0 D0 ; physical drive 0.3 goes forwards
              M569 P0.4 S0 D0 ; physical drive 0.4 goes forwards
              M569 P0.5 S1 D0 ; physical drive 0.5 goes forwards
              M584 X0.0 Y0.1 Z0.3:0.4 E0.5 ; set drive mapping
              M92 X80,62315 Y80,62315 Z804,020 E409.00 ; set steps per mm
              M566 X500.00 Y500.00 Z100.00 E1500 ; set maximum instantaneous speed changes (mm/min)
              M203 X50000.00 Y50000.00 Z1000.00 E1500.00 ; set maximum speeds (mm/min)
              M201 X5000.00 Y5000.00 Z50.00 E1200 ; set accelerations (mm/s^2)
              M906 X2900 Y2900 Z1500 E1300 ; set motor currents (mA)
              M84 S0 ; Disable motor idle current reduction
              M671 X-85:485 Y200:200 S25.5 ; Position des deux vis
              M208 X400 Y400 Z410 S0 ; set axis maxima
              M574 X1 S3 ; configure active-high endstop for high end on X via pin io0.in
              M574 Y2 S3 ; configure active-high endstop for low end on Y via pin io1.in
              M574 Z1 S2 ; configure active-high endstop for high end on Z via pin io0.in
              ; Reglage sensorless
              M915 X Y R0 F0 S3
              M950 S0 C"^io7.out" ; Creation Pin servo Bltouch
              M558 P9 C"^io7.in" H10 F200 T25000 A1 S0.03 R1 ; Définition Z probe pour bltouch et la hauteur/ vitesse de probe
              G31 P100 X-25.1 Y6 Z3.05 ; Définition Z probe Offset
              M557 X20:375 Y20:375 S50 ; Définition Grille de palpage
              M308 S0 P"temp1" Y"pt1000" R2200 ; configure sensor 0 as PT1000 on pin temp1
              M950 H0 C"out2" T0 ; create bed heater output on out2 and map it to sensor 0
              M307 H0 B0 R0.818 C302.2 D15.38 S1.00 V24.3 ; disable bang-bang mode for the bed heater and set PWM limit
              M143 H0 S110 ; set temperature limit for heater 0 to 110C
              M308 S1 P"temp0" Y"pt1000" R2200 ; configure sensor 1 as PT1000 on pin temp0
              M307 H1 B0 R2.211 C190.0 D8.87 S1.00 V24.2 ; disable bang-bang mode for heater and set PWM limit
              M143 H1 S350 ; set temperature limit for heater 1 to 350C
              M950 F0 C"out7" Q500 ; create fan 0 on pin out4 and set its frequency
              M106 P0 C"F0" S0 H1 T45 ; set fan 0 name and value. Thermostatic control is turned on
              M950 F1 C"out8" Q500 ; create fan 1 on pin out5 and set its frequency
              M106 P1 C"F1" S0 H-1 ; set fan 1 name and value. Thermostatic control is turned off
              M563 P0 S"Tete" D0 H1 F0:1 ; define tool 0
              M280 p0 s160
              M280 P0 S10
              M280 P0 S90
              T0 ; select first tool
              all its mount with igus professional cable my extruder its an hemeraundefinedIMG_20211022_123851.jpg IMG_20211022_123836.jpg
              undefined 1 Reply Last reply 22 Oct 2021, 11:23 Reply Quote 0
                Amagatth @Amagatth
                @amagatth IMG_20211022_132117.jpg and the bl is connected to the duet at io7
                undefined 1 Reply Last reply 22 Oct 2021, 15:07 Reply Quote 0
                  @Amagatth
                  I edited the port to use </> formatting for posting the config.g so it can be read without downloading.
                  Because the BL touch deploys and retracts properly before you start the print I am assuming that the wiring into IO7 is correct.
                  From you configuration the input and output pins should not have a pullup resistor enabled:
                  M950 S0 C"io7.out" ; Creation Pin servo Bltouch
                  M558 P9 C"io7.in" H10 F200 T25000 A1 S0.03 R1
                  The BL touch should still work initially (test this please). It will hopefully now work after doing an extrusion as well. My guess is that the pullups + the extrusion noise put it into a weird state.
                  undefined 2 Replies Last reply 22 Oct 2021, 19:30 Reply Quote 0
                    Amagatth @T3P3Tony
                    @t3p3tony I add the pull-up to try to solve the problem, I try Monday if it's better without that! 🙂
                    undefined 1 Reply Last reply 24 Oct 2021, 18:02 Reply Quote 0
                      Dogma2k @Amagatth
                      @amagatth
                      I had the same problem, but only when I changed the filament and extruded it.
                      I solved the problem by simply entering M84 E0 in start.g. Since then no more problems
                        Amagatth @T3P3Tony
                        @t3p3tony
                        I try to delet pullup and bl work before print but not after extrusion
                        undefined 1 Reply Last reply 25 Oct 2021, 08:33 Reply Quote 0
                          @amagatth the next thing to try then is to route the cable separately. The BL touch cable might be picking up noise from the stepper cable and that is causing it to get into an errored state.
                          undefined 1 Reply Last reply 28 Oct 2021, 11:27 Reply Quote 0
                            Amagatth @T3P3Tony
                            @t3p3tony ok i try it 🙂 thx !
                            18 out of 21
