    Minor fix for low res screens
    Duet Web Control wishlist
    • DADIYundefined
      DADIY
      When running version 1.19 at 1280 x 800 screen resolution the temperatures are cut off, can something be done to give a little bit more space to the drop down? There does seem to be some unused white space to the left of the drop down picker thats overlaying the text.
      Here's an example:
      Thanks
      D
        T3P3Tony administrators
        1280x800 being "low res" is so 2017 😄
        I hope Christian will be able to change this in the next release so the boxes minimum size works with the temperature text.
        In the mean time you can zoom out slightly on the page in your browser - say to 90%
        • fmaundefined
          fma
          I noticed the same with a 1920x1080 screen.
          DADIY, you can click on Heaters, which hides some infos, and the temps dropboxes will be larger.
          Frédéric
          • DADIYundefined
            DADIY
            @fma:
            True, but I was reporting it so that we could just get in on the wish list to be fixed in the future.
