    Auto power resume not working
    Using Duet Controllers
    • Ex3DPundefined
      Ex3DP
      Dear @dc42 ,
      Greetings from Ex3DP.
      We are using Duet2 Wi-Fi. We want to activate auto power resume option on the same. We have tried all the possibilities mentioned on
      https://duet3d.dozuki.com/Wiki/Setting_up_to_resume_a_print_after_a_power_failure and also tried executing suggestions provided on Duet forum under auto power resume discussion, but there is no success till today.
      We have attached images / screenshots of our work for your ready reference. Kindly provide your valuable inputs on the same.
      Regards,
      Ex3DP
      gloomyandyundefined 1 Reply Last reply Reply Quote 0
      • gloomyandyundefined
        gloomyandy @Ex3DP
        @ex3dp Can you check the name of your "resurrect-prologue.g" file it looks to me as if there may be a space on each side of the "-", so it is actually "resurrect - prologue.g", it is hard to be sure though.
        Ex3DPundefined 2 Replies Last reply Reply Quote 2
        • Ex3DPundefined
          Ex3DP @gloomyandy
          @gloomyandy Thank you so much for the suggestion. We will definitely check and modify if needed. But is there any technical issue in the code besides what you suggested to incorporate ?
          • Ex3DPundefined
            Ex3DP @gloomyandy
            @gloomyandy Hello. Your suggestion / solution helped us to resolve the issue. Thank you so much.. Appreciated.
            • T3P3Tonyundefined T3P3Tony marked this topic as a question
            • T3P3Tonyundefined T3P3Tony has marked this topic as solved
