    Automatic builds
    Firmware wishlist
    590
    • gregsaunundefined
      gregsaun @oliof
      @oliof Ah yes that would be great too. This can probably be handled as two separate tasks but I agree it would make sense. Moving to cmake is probably a lot of work.
      github.com/gregsaun - Papa Bear
      • oliofundefined
        oliof @gregsaun
        @gregsaun there is an incomplete PR by @mfs12 that only targets Duet2the mini 3, covering all the other target devices would be "just work", but of course it's up to @dc42 to make that call (-;
        • mfs12undefined
          mfs12
          Hey @gregsaun, @oliof,
          Paneldue is already ported to cmake. Check the github repo https://github.com/Duet3D/PanelDueFirmware
          It runs perfectly within Arch Linux so integration with automated build based on docker or similar should be feasible.
          I also started this work for RepRapFirmware. It brings basic support for the mini5+. It needs most of the configuration for other boards to be ported. Otherwise i think it's a good basis to start off.
          Check https://github.com/mfs12/RepRapFirmware/tree/integrate-cmake-build-system
          Visit me on github at https://github.com/mfs12/
          gregsaunundefined 1 Reply Last reply Reply Quote 2
          • gregsaunundefined
            gregsaun @mfs12
            @mfs12 That is awesome to head, thanks for that work. So yes for PanelDue we can use GitHub actions, it is using docker and you can specify the OS as well if you like.
            mfs12undefined 1 Reply Last reply Reply Quote 0
            • mfs12undefined
              mfs12 @gregsaun
              @gregsaun can you share the github action files. So far i am not familiar with github actions but would like to have this integrated as well.
              gregsaunundefined 1 Reply Last reply Reply Quote 0
              • gregsaunundefined
                gregsaun @mfs12
                @mfs12 It is not published yet but here is the create release GitHub action script I am currently using to create the release:
                create_release.yml.txt
                I have an external script to create the zip files and for now the splash screen creation isn't done yet. You need to rename the file as .yml
                • mfs12undefined
                  mfs12
                  @gregsaun, thanks i will have a look into it.
                  • mfs12undefined
                    mfs12
                    BTW to build Paneldue any Linux should be fine no need to use specifically Arch Linux.
                    gregsaunundefined 1 Reply Last reply Reply Quote 1
                    • gregsaunundefined
                      gregsaun @mfs12
                      @mfs12 Don't hesitate if you need help 🙂
                      • gregsaunundefined
                        gregsaun
                        For info, this is how my draft release looks like on GitHub after the automatic creation
