    Large Format Dowell to Duet conversion
    362
    35.3k
      T3P3Tony administrators @T3P3Tony
      @Charles-Fraser please do me a favour, after you have made those changes and tested them post your full config.g here again - Is getting harder to quickly find it higher up the thread.
      Charles Fraserundefined 4 Replies Last reply Reply Quote 0
      • Charles Fraserundefined
        Charles Fraser @T3P3Tony
        @t3p3tony
        They are all moving up and down in the same direction yes
        Configuration file for Duet 3 (firmware version 3.3)
        ; generated by RepRapFirmware Configuration Tool v3.3.3 on Fri Oct 01 2021 16:59:54 GMT+0100 (British Summer Time)
        G90                                                             ; send absolute coordinates...
        M83                                                             ; ...but relative extruder moves
        ; Wait a moment for the CAN expansion boards to start
        G4 S2
        M569 P0.0 S1                                                    ; physical drive 0.0 goes forwards
        M569 P0.1 S1                                                    ; physical drive 0.1 goes forwards
        M569 P0.2 S0                                                    ; physical drive 0.2 goes forwards
        M569 P0.3 S0                                                    ; physical drive 0.3 goes forwards
        M569 P0.4 S0                                                    ; physical drive 0.4 goes forwards
        M569 P0.5 S0                                                    ; physical drive 0.5 goes forwards
        M569 P1.0 S1                                                    ; physical drive 1.0 goes forwards
        M584 X0.0 Y0.1 Z0.2:0.4:0.5:0.3 E1.0
        M350 X16 Y128 Z16 E16  I1                                ; configure microstepping with interpolation
        M92 X80.00 Y1280.00 Z2000.00 E420.00          ; set steps per mm
        M566 X900.00 Y900.00 Z60.00 E120.00        ; set maximum instantaneous speed changes (mm/min)
        M201 X500.00 Y500.00 Z20.00 E250.00        ; set accelerations (mm/s^2)
        M906 X2800 Y2800 Z1200 E1200 I30                      ; set motor currents (mA) and motor idle factor in per cent
        M84 S30                                                         ; Set idle timeout
        M208 X0 Y0 Z0 S1                                                ; set axis minima
        M208 X1200 Y2000 Z1600 S0                                       ; set axis maxima
        M574 X1 S1 P"io1.in"                                            ; configure active-high endstop for low end on X via pin io1.in
        M574 Y1 S1 P"io2.in"                                            ; configure active-high endstop for low end on Y via pin io2.in
        M574 Z1 S1 P"io0.in"                                                       ; configure Z-probe endstop for low end on Z
        M558 P9 C"^1.io1.in" H100 F120 T6000                            ; set Z probe type to switch and the dive height + speeds
        G31 P500 X0 Y0 Z2.5                                             ; set Z probe trigger value, offset and trigger height
        M556 S50 X0 Y0 Z0                                               ; set orthogonal axis compensation parameters
        M557 X15:215 Y15:195 S20                                        ; define mesh grid
        M308 S0 P"1.temp0" Y"PT1000"
        M950 H0 C"1.out0" T0
        M307 H0 B1 R0.138 C790.6 D13.87 S1.00 V24.0                   ; enable bang-bang mode for the bed heater and set PWM limit
        M140 H0                                                         ; map heated bed to heater 0
        M143 H0 S80                                                    ; set temperature limit for heater 0 to 80C
        M308 S1 P"1.temp1" Y"PT1000"                                    ; configure sensor 1 as thermistor on pin temp0
        M950 H1 C"1.out1" T1                                              ; create nozzle heater output on out1 and map it to sensor 1
        M307 H1 B0 S1.00                                                ; disable bang-bang mode for heater  and set PWM limit
        M143 H1 S300                                                    ; set temperature limit for heater 1 to 300C
        M950 F0 C"out8" Q0                                            ; create fan 0 on pin out8 and set its frequency
        M106 P0 S0 H T45                                                ; set fan 0 value. Thermostatic control is turned on
        M950 F1 C"out9" Q500                                            ; create fan 1 on pin out9 and set its frequency
        M106 P1 S1 H-1                                                  ; set fan 1 value. Thermostatic control is turned off
        M563 P0 S"lily" D0 H1 F0:1                                      ; define tool 0
        G10 P0 X100 Y100 Z0                                             ; set tool 0 axis offsets
        G10 P0 R0 S0                                                    ; set initial tool 0 active and standby temperatures to 0C
          @t3p3tony
          I am trying to work out how to calculate the steps per mm if 2000 s/mm is giving me 52mm translation when I send 50. I can't seem to work out how to work it out embarrassingly
            @t3p3tony
            M92 X80.00 Y1280.00 Z1926.78 E420.00          ; set steps per mm
            okay this seems to be near enough
            If I divide 100,000 steps by 52mm I get
            1926.78 s/mm if
            When I use value z1926.00 I get the following on a 50mm command
            If I divide 51.9 mm by 100,000 steps I get 1926.78
            That translates to
            They are both .1 of a mm out. Is that okay if I am printing big things. No not really it needs to be less.
            So I go between those two z1926.39
              @t3p3tony iwhen I hit home all the z axis goes the wrong way
              In fact, when I hit any of the home buttons, all it does is send the z axis the wrong way
                T3P3Tony administrators @Charles Fraser
                @charles-fraser for Z when you jog it using DWC by a few mm does it move in the expected direction?
                For the steps/mm this is really not something you measure for XYZ it something to calculate.
                So
                lead = 5mm
                motor microsteps/rev = 3200 (with 16 microstepping and 1.8 degree motors it would be 3200)
                the unknown to me is the ratio between the pully teeth on the motor and the larger pully on the Z rods. how many teeth are on each?
                Once you know that we work out the steps/mm for Z.
                For the homing files, the first command is raise Z by 100mm (you can read the comments in the homing files).
                So looking at home X.
                ; homex.g
                ; called to home the X axis
                ; generated by RepRapFirmware Configuration Tool v3.3.3 on Fri Oct 01 2021 16:59:55 GMT+0100 (British Summer Time)
                G91                ; relative positioning
                G1 H2 Z100 F6000   ; lift Z relative to current position
                G1 H1 X-1205 F1800 ; move quickly to X axis endstop and stop there (first pass)
                G1 H2 X5 F6000     ; go back a few mm
                G1 H1 X-1205 F360  ; move slowly to X axis endstop once more (second pass)
                G1 H2 Z-100 F6000  ; lower Z again
                G90                ; absolute positioning
                if you don't need to increase Z gap by 100 mm before homing then you can modify that line to a more appropriate amount. (but be sure to change the value on line 10 to match!)
                Then the file moves X in a negative direction (which is correct assuming the end stop is at X minimum)
                once its triggered it backs off and then tests again slower
                then it decreases the Z gap (again this should match the amount in line 6).
                Similar with the Home Y
                Home all just puts it together into a fewer steps and then homes Z however as it stands that home all wont work correctly as its setup for a Z probe.
                You mentioned you added a Z switch, where is it located (Z min or Z max?)
                Charles Fraserundefined 1 Reply Last reply Reply Quote 0
                  @t3p3tony
                  Thanks Tony, I think I worked out the steps for Z
                  The Z switch is triggered when the bed comes too close to the nozzle and pushes up against a switch. I’m not sure if that is min or Max?
                  Charles Fraserundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                    Charles Fraser @Charles Fraser
                    @charles-fraser
                    ya so I swapped the z probe for a z switch for now but think we can reattach the 3d touch to the other extruder block and set that up now too if you are game? Is there a way to speed up the fast z movement please? It's now much slower than it was before. Now all the switches are open for all axis.
                      @charles-fraser said in Large Format Dowell to Duet conversion:
                      what did you come up with?
                      That is a t Z min (Z gap = 0)
                      I believe that caused issues before, or did you get a new 3d touch?
                      The overall Z speed limit is set in config.g with the following line in mm/min
                      so you are currently set to a max speed of 3mm/s or 180mm/min. For testing you can increase this to , e.g. 30mm/s M203 X6000.00 Y6000.00 Z1800.00 E1200.00 ; set maximum speeds (mm/min). this may be higher than the max speeds that the Z axis can achieve so don't just jog the bed/home the bed to test this.
                      The next step is to set the bed be "homed" at roughly the right height for testing (e.g. if its at ~Z0 then send G92 Z0 to tell the printer where it is).
                      The send commands like this:
                      G1 Z20 F180
                      (to get the bed at least 20mm away from the nozzle)
                      G1 Z40 F180
                      G1 Z20 F180
                      Thats a base line moving only 20mm, at at the same slow speed.
                      Then you can increase the speed (and distance) while checking that all 4 motors are moving smoothly and not binding. Given the weight of the bed you will probably find the speed for raising will max out at a lower speed than for dropping it.
                      G1 Z60 F360
                      G1 Z20 F360
                      G1 Z60 F480
                      G1 Z20 F480
                      If you get all the way to F1800 and the bed is still moving smoothly then you can go and adjust the M203 value to even higher. Given the size of the bed. its also worth considering the weight of the print on the bed. Now given that you would generally be moving the bed down as the mass of the print increased this may not be a big issue, but its worth testing whatever speed you arrive at that is working well by trying moving the bed with a similar weight on to a large print you are likely to do.
                        @t3p3tony said in Large Format Dowell to Duet conversion:
                        I used 128 microsteps and 160 x 4 steps per mm I think. I’m now away for meetings for the next few days so cant share the code.
                        Thanks!
                        I can’t afford the £40 for a new BL touch for now so started re-wiring the 3D touch to the second extruder block. All my income is outgoings as soon as it comes in until about the 10th so I have to make do for now.
                        So I doubled the Z speed and it looks like it’s at the speed that it was at with the last board with the Chinese Mobo.
                        Will this change the Z home position forever? So whenever I press home it will home to Znnn ?
                        G1 Z20 F180
                        G1 Z40 F180
                        G1 Z20 F180
                        G1 Z60 F360
                        G1 Z20 F360
                        G1 Z60 F480
                        G1 Z20 F480
                        Very thorough answer thank you! I think it’s fine at 360. Thank you so much!
                          nope - it was just to run the following test.
                            dc42 administrators @Charles Fraser
                            NB I still cant find a 3x15mm pt1000 thermistor anywhere!
                            https://e3d-online.com/products/pt1000-temperature-sensor
                              Charles Fraser @dc42
                              @dc42 @T3P3Tony thanks!
                              I’ve got that PT1000 now and will spend the next few days getting this all calibrated again.
                              I will fit the PT1000 into the heating block but the block is now separated from the screw and needs to be heated up whilst on the screw in order for the hardened plastic to become soft enough to allow it to be pushed all the way up against and bolted to the mounting block.
                              I can do that by just setting ‘active’ to 190C right? After that what’s the command for the PID autotune for the nozzle again please?
                              The homing seems to be working on the x and y and I set a z min endstop up in the same way as the x and y as a fallback option to the 3D touch.
                              I’ll rewire the 3D touch to the second extruder mounting block that seems to be free of shorts. I’ll follow the earlier instructions on how to do that. Is that possible to have a 3D touch and second z endstop? I replaced the probe code with the z min endstop switch code so wonder if you could point me in the right direction for the 3D touch code please?
                              Many thanks
                              Charles
                                Yes once you are happy the thermistor is reading properly and the heater wiring is not shocking anything!
                                See the description here:
                                https://duet3d.dozuki.com/Wiki/M303
                                At its simplest its:
                                M303 T0 S200
                                Yes one as a Z probe and one as an endstop. I would have the endstop at Z max because it will allow you to home Z onto the endstop even with a print on the bed (e.g. a power fail part way through a print).
                                Its here:
                                https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_RepRapFirmware_Num_3
                                You will need to modify it based on which inputs you put the probe. The probe should be on the same board as your Z motors.
                                Charles Fraserundefined 2 Replies Last reply Reply Quote 0
                                  @t3p3tony
                                  Thank you Tony, I stupidly seem to have forgotten the thermistor. If I use the thermistor that came with the extruder it's a NTC 100k. Is that easily copatible if I just change the code please? Many thanks
                                    @charles-fraser oops sorry i meant the PT1000 that you have bought to replace the thermistor! I thought we had determined that the extruder thermistor was faulty way earlier in this thread?
                                      @t3p3tony
                                      No we didnt establish that thermistor was faulty,I just didn't know what kind it was. It's type 13 in marlin, that's the type listed above. Can we edit the config.g file to use this one please?
                                        type 13 in marlin
                                        13 : 100kΩ Hisens up to 300°C - for "Simple ONE" & "All In ONE" hotend - beta 3950, 1%
                                        https://github.com/MarlinFirmware/Marlin/blob/2.0.x/Marlin/Configuration.h
                                        So
                                        M308 S1 P"1.temp1" Y"thermistor" T100000 B3950
                                        this is plugging it into port temp1 on the 3HC (which you currently have setup for the PT1000 on the hotend.
                                        Charles Fraserundefined 3 Replies Last reply Reply Quote 0
                                          @t3p3tony
                                          Thanks, regarding PID autotune: when the extruder is extruding pellets at full flow rate through a 3mm nozzle the heating characteristics are very different then when just sat idle. Is there a way to autotune while the extruder is extruding please?
                                          Regarding endstops: is this okay? The z switch is so that if the bed comes so close to the nozzle and starts to push against it the switch is closed and the z motion should stop
                                          For the z probe I have.
                                          if I want to change it to io3 on the 6HC should I change it to
                                          M558 P9 C"^0.io3.in" H100 F120 T6000
                                            @t3p3tony
                                            Great that is working well and PID tuning now.
