    BLTouch doesn't work
    • Inno 3Dundefined
      Inno 3D
      I have a Problem with my BLTouch. It will not deploy!
      I have checked the wiring. It is definitely connected right.
      I have not a config-override.g file inside the system. I have also updatet the firmware to the latest release 3.3.
      At the start the BLTouch does it's self test.
      With the M401 Code, the BLTouch will not deploy.
      Same with the M280 P0 S10 Code.
      M280 P0 S10 = 5,75V
      M280 P0 S90 = 5,55V
      Could that be correct?
      Do you have any Idea, why the BLTouch will not deploy?
      Thanks for your help!
      Config.g
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.5 on Fri Oct 29 2021 19:26:34 GMT+0200 (Mitteleuropäische Sommerzeit)
      M575 P1 S1 B57600                                  ; enable support for PanelDue
      G90                                                ; send absolute coordinates...
      M83                                                ; ...but relative extruder moves
      M550 P"Printer"                                    ; set printer name
      M551 P"*****"                                      ; set password
      M552 S1                                            ; enable network
      M586 P0 S1                                         ; enable HTTP
      M586 P1 S0                                         ; disable FTP
      M586 P2 S0                                         ; disable Telnet
      M569 P7 R0 S0 T3.33:3.33:5:0                       ; physical drive 0 goes forwards
      M569 P8 R0 S0 T3.33:3.33:5:0                       ; physical drive 1 goes forwards
      M569 P2 S0                                         ; physical drive 2 goes forwards
      M569 P3 S1                                         ; physical drive 3 goes forwards
      M584 X8 Y7 Z2 E3                                   ; set drive mapping
      M350 X16 Y16 Z64 I0                                ; configure microstepping without interpolation
      M350 E16 I1                                        ; configure microstepping with interpolation
      M92 X100.00 Y200.00 Z1280.00 E418.50               ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00            ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00                ; set accelerations (mm/s^2)
      M906 X1400 Y1400 Z1400 E800 I30                    ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                            ; Set idle timeout
      M208 X0 Y0 Z0 S1                                   ; set axis minima
      M208 X610 Y610 Z600 S0                             ; set axis maxima
      M574 X1 S1 P"!xstop"                                ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y2 S1 P"!ystop"                                ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
      M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
      M950 S0 C"exp.heater6"                             ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F120 T6000                ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y0 Z2.5                                ; set Z probe trigger value, offset and trigger height
      M557 X15:595 Y15:595 S20                           ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                              ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B1 S1.00                                   ; enable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                            ; map heated bed to heater 0
      M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                               ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                       ; set temperature limit for heater 1 to 280C
      M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
      M563 P0 D0 H1 F0                                   ; define tool 0
      G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
      G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
      M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
      M115
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.3 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2021-06-15 21:45:03
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
      Board ID: 0JD0M-9P6M2-NW4SN-6J9DG-3SJ6N-TAU7K
      Used output buffers: 3 of 24 (11 max)
      Static ram: 23876
      Dynamic ram: 74972 of which 0 recycled
      Never used RAM 15568, free system stack 184 words
      Tasks: NETWORK(ready,10.5%,252) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,364) MAIN(running,85.4%,443) IDLE(ready,4.1%,29), total 100.0%
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:00:24 ago, cause: power up
      Last software reset at 2021-10-30 15:37, reason: User, GCodes spinning, available RAM 15568, slot 2
      Error status: 0x00
      Aux0 errors 0,0,0
      Step timer max interval 0
      MCU temperature: min 30.9, current 32.6, max 32.8
      Supply voltage: min 24.1, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 0, standstill, SG min/max not available
      Driver 1: position 0, standstill, SG min/max not available
      Driver 2: position 0, standstill, SG min/max not available
      Driver 3: position 0, standstill, SG min/max not available
      Driver 4: position 0, standstill, SG min/max not available
      Driver 5: position 0
      Driver 6: position 0
      Driver 7: position 0
      Driver 8: position 0
      Driver 9: position 0
      Driver 10: position 0
      Driver 11: position 0
      Date/time: 2021-10-30 15:58:50
      Cache data hit count 897316776
      Slowest loop: 6.52ms; fastest: 0.16ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 4.1ms, write time 0.0ms, max retries 0
      === MainDDARing ===
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 16.07ms; fastest: 0.00ms
      Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is active
      WiFi firmware version 1.23
      WiFi MAC address e0:98:06:a4:5f:af
      WiFi Vcc 3.34, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 24368
      WiFi IP address 192.168.178.116
      WiFi signal strength -50dBm, mode none, reconnections 0, sleep mode modem
      Clock register ffffffff
      deployprobe.g
      ; deployprobe.g
      ; called to deploy a physical Z probe
      M280 P0 S10 ; deploy BLTouch
      retractprobe.g
      ; retractprobe.g
      ; called to retract a physical Z probe
      M280 P0 S90 ; retract BLTouch
      Gixxerfastundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
      • Gixxerfastundefined
        Gixxerfast @Inno 3D
        @inno-3d
        I should probably leave this to the pros as I don't use RRF with a BLTouch (yet). But as an observation:
        From: https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
        If you have a Expansion Breakout Board, it's !exp.heater6 or !exp.heater7 ('!' inverts the output, and is needed).
        M950 S0 C"!exp.heater6" ; Duet 2 WiFi/Ethernet + BoB
        Could that be something to consider?
        Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
        Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
        Ender 3 Pro with BTT SKR-2 + RRF
          T3P3Tony administrators @Inno 3D
          @inno-3d please try @Gixxerfast 's change.
          Thanks @Gixxerfast I missed that in @Inno-3D 's original thread here:
          https://forum.duet3d.com/topic/25769/bltouch-will-not-deploy-with-m401/17
          Locking this thread now as its a duplicate of the original thread.
