Ender 3 pro quality issues
    Messiahman
    Hi all, as the title suggests I am having trouble with my ender 3 pro print quality, which i cannot determine if it is due to hardware or calibration. I am running a duet 2 wifi with a bantamount dual 5015 mount, stock extruder, bltouch, metal extruder, capricorn bowden tube, glass build plate and steel core timing belt for the x axis (which will soon be replaced with the stock once i get it from e3d). Below is my config file and a couple photos of my most recent benchy. I also plan on extending the build volume to 400x400x500 and wish to eventually print at high speeds and quality, though I first need to reach quality here.
    ; generated by RepRapFirmware Configuration Tool v3.3.3 on Wed Oct 06 2021 12:37:23 GMT-0400 (Eastern Daylight Time)
    M550 P"The Print-inator" ; set printer name
    M918 P1 E4 F2000000 ; configure direct-connect display
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P0 S0 ; physical drive 0 goes backwards
    M569 P2 S0 ; physical drive 2 goes backwards
    M92 X80.00 Y80.00 Z400.00 E136.79 ; set steps per mm
    M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
    M201 X2600.00 Y2600.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
    M906 X800 Y800 Z800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X235 Y235 Z260 S0 ; set axis maxima
    M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
    M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
    M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
    M558 P9 C"^zprobe.in" H3 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
    G31 P500 X40.00 Y5.0 Z0.333 ; set Z probe trigger value, offset and trigger height
    M557 X40:220 Y25:220 S41 ; define mesh grid
    M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
    M143 H0 S150 ; set temperature limit for heater 0 to 150C
    M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
    M143 H1 S275 ; set temperature limit for heater 1 to 275C
    M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
    M106 P2 S1 H1:0 T45 ; set fan 2 value. Thermostatic control is turned on
    FD494F1B-8426-4EF3-87E3-F2A7A0ABA582.jpeg 03B15971-89A8-4DE1-9AB6-73369DC7D58E.jpeg A6019A97-53F1-4962-B333-564C1159B107.jpeg 68C8E40E-6D64-4719-A544-AF9DA9F0A002.jpeg 076ED211-3144-421E-93D7-84658C67FAFB.jpeg C1FB0CBC-1D50-4ECB-AC1C-9ACD02D30EE9.jpeg03B15971-89A8-4DE1-9AB6-73369DC7D58E.jpeg
    undefined undefined 2 Replies Last reply 3 Nov 2021, 15:05 Reply Quote 0
      Messiahman @Messiahman
      @messiahman I would like to add that I would prefer to keep the settings in the printer rather than in any slicer so I do not have to worry about switching between computers
        T3P3Tony administrators @Messiahman
        @messiahman I would break the troubleshooting down into steps. prints like the benchy may be interesting to compare overall print times and some quality but for tuning you want individual models that test just 1 thing so you can tune those in 1 step at a time with fast prints that allow you to iterate over lots of different versions of one setting quickly.
        If you look on prusaprinters or other 3d file sharing sites you should see various tests for retractions, temperature towers, bridging etc etc.
        Generally I start with:
        1. Confirming that the extruder steps/mm is correct and that the other axis steps/mm speeds etc are appropriate. ensure your PID is tuned for the extruder.
        2. Checking for the best print temperatures for the filament (temp tower) and fan settings.
        3. iterate through jerk and acceleration values to get acceptable quality
        4. tune more advanced features like PA and Input shaping if appropriate.
        Thats a very rough outline. there are guides online on how to do this in detail. In addition the settings the printer shipped with should be a good start point for tuning.
        undefined 2 Replies Last reply 3 Nov 2021, 15:11 Reply Quote 0
          Messiahman @T3P3Tony
          @t3p3tony This is after tuning it, which is why I wasn't sure if it was hardware or not
            @t3p3tony I also don't know the gcode for some of those for reprap, so I was hoping I could have a little bit of a walkthrough with someone who knows what they're talking about lol
            undefined 1 Reply Last reply 3 Nov 2021, 15:44 Reply Quote 0
              @messiahman so probably best to step through the issues you are seeing (using some test prints that target just one issue) and then if you can't find the setting you need to modify then we can of course point you in the right direction.
              here are some links to help you get started:
              M92: Allows programming of steps per mm for motor drives.
              M566: Sets the maximum allowable speed change (sometimes called 'jerk speed') of each motor when changing direction.
              M201: Sets the acceleration that axes can do in mm/second^2 for print moves.
              M203: Sets the maximum feedrates that axes can do in mm/min.
              https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
              https://duet3d.dozuki.com/Wiki/Setting_motor_currents
              and for later on:
              https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
              https://duet3d.dozuki.com/Wiki/Pressure_advance
              This guide mentions a Maestro and its based on slightly older RRF but the tuning steps will be basically the same
              https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40
              3 out of 6
