    Duet wifi box mounted on top triangle
    My Duet controlled machine
    • Hergonowayundefined
      Hergonoway
      Just published my new box design for Duet wifi, there are flex insert for cable pass-through and separated mounting parts to fix the box inside the triangle of a delta, and a 120mm on the top 🙂
      https://www.thingiverse.com/thing:2523430
      Hope someone will find what he search for 🙂
      Delta goes BrrrRRRRrrrrrRRRRrrr
      • number40fanundefined
        number40fan
        In my best Italian voice, "Now that's a fan."
          T3P3Tony administrators
          Yeah that looks good, although you will have more board cooling than you need! 😉
            Hergonoway
            @T3P3Tony:
            Yeah the point here is to put a silent fan at low rpm to keep good CFM, and because it's cool and easy to find 🙂
            Since there space in the box I'm currently designing a stack up piece in order to add buck converter in the box.
