    Heater Fault
    2.6k
    • Dave Parryundefined
      Dave Parry @jay_s_uk
      @jay_s_uk Its one of E3D's
      Thermistor Cartridge - E-SEMITEC-50-MOLEX-INC-CABLE
      It has lessened a bit now for some reason
        jay_s_uk @Dave Parry
        @dave-parry you shouldn't be noise like that on those thermistors which would indicate an issue with either the connections or the cabling
        Dave Parryundefined 1 Reply Last reply Reply Quote 1
          @jay_s_uk
          Just to let you know tony I did the heater tuning as you suggested and its now completely flat. (the blip at the end was where the print finished and switched off and I reset the temp for the next print.)
          Thank you for your patience.
          jay_s_ukundefined 1 Reply Last reply Reply Quote 1
            @dave-parry thats much better. I would still check the cabling as those severe spikes aren't normal. at least its working though
              Dave Parry
              Well I have the problem back again. When I start a print it drives down to wipe and start the print I get a heater fault error. It sometimes happens during a print too.
              Have upgraded to release 3.4.0 beta 6 and that seems to have installed correctly, but still get the error.
              I did do a heater tune but that was before the firmware update.
              Dave Parryundefined 1 Reply Last reply Reply Quote 0
                Dave Parry @Dave Parry
                @dave-parry It seems I have the latest version of Duet2_SDiap32_WiFiEth.bin (19-10-2021) so dont know what else to try.
                Also if I reset the heater (but dont restart the print) it throws up the error again before it reaches the set temp.
                I have also noticed that before the error comes up the temp reading goes all over the place far quicker than it can possibly do. But its not a bad connection.
                  @dave-parry I would be ordering a new thermistor or replacing the cable as one of them must be dodgy
                    @jay_s_uk tried that before and it made no difference, but will try again to see.
                      @dave-parry Nope just the same problem.
                        @dave-parry what did you change?
                          @jay_s_uk Changed the sensor.
                          It was the same initially, but its behaving it self now.
                          When the print finishes will change the wiring connector. It's a 12 way molex. I have spares, so I will cut the wires and re-crimp them. see if that makes any difference. But moving the wires about didnt show any problems, but will change anyhow.
