Mesh bed leveling without M557
Gcode meta commands
    Piet
    Dear users,
    I noticed there is a possibility to create a mesh.g file and I'm wondering if i can use it to do the following. (I'm not totally sure how to use it so please enlighten me)
    I have some hysteresis in my Z-probe. This means that if I run the G29 command and automatically probe all the predefined points, the value starts to shift to a point that the mesh is unusable. Normally before probing I measure the analog value of the probe and set a new threshold by adding a value to that measured value. Is there a way I can set a new threshold to trigger before every probe move in the mesh.g. I already have this code set up for regular bed leveling but I'm assuming I can't use the G30 command to do mesh bed leveling. Is this correct?
    This is the code i already use:
    probe.g
    if !exists(param.X) || !exists(param.Y)														;if parameter X and Y are given
    	echo "Make sure parameter X and Y are given (C and S optional). Aborting probe move."	;notify user
    G1 X{param.X} Y{param.Y} Z{sensors.probes[0].diveHeight} F6000								;move to given X and Y coordinates and predefined diveheight
    M400																						;wait for moves to finish
    M291 R"Waiting for extruder." P" " S1
    M116 P0 S2																					;wait for extruder to reach temperature
    M568 P0 A0																					;turn the extruder heater off (interference changes sensor reading)
    G4 S1																						;wait 1 second
    M98 P"preprobe.g"																			;call macro to determine triggervalue and see if it is okay to proceed probing
    M292
    M291 R"Probing." P" " S1
    if global.proceedProbe = true																;if its okay to proceed probing
    	if exists(param.C)																		;if parameter C is given
    		if exists(param.S)																	;if parameter S is given
    			G30 X{param.X} Y{param.Y} P{param.C} S{param.S} Z-9999							;probe move
    		else																				;otherwise
    			G30 X{param.X} Y{param.Y} P{param.C} Z-9999										;probe move
    	elif exists(param.S)																	;if parameter S is given
    		G30 X{param.X} Y{param.Y} S{param.S} Z-9999											;probe move
    	else																					;otherwise
    		G30 X{param.X} Y{param.Y} Z-9999													;probe move
    elif (global.proceedProbe = false)															;if it isnt okay to proceed probing
    	echo "Aborting probe move"																;notify user
    M292
    M568 P0 A1																					;set the extruder heater to standby
    preprobe.g
    if !exists(global.proceedProbe)																										;if variable doesnt exist yet
    	global proceedProbe = false																										;initialize variable
    if exists(global.triggerVal)																										;if a triggervalue has been defined
    	if sensors.probes[0].value[0] <= 922 && sensors.probes[0].value[0] >= 200														;if the sensorvalue is within acceptable range
    		var measuredVal = {sensors.probes[0].value[0]}																				;measure the sensor value
    		G31 P{var.measuredVal + global.triggerVal}																					;set the triggervalue to the measured value + the triggervalue
    		;echo "Measured sensor value is", {var.measuredVal}, ". Triggervalue has been set to", {sensors.probes[0].threshold}, "."	;notify user
    		set global.proceedProbe = true																								;set variable so probing can proceed
    	else																															;otherwise
    		echo "Measured sensor voltage is out of range at ", {(var.measuredVal * 5)/1024}, "V."										;notify user
    		set global.proceedProbe = false																								;set variable so probing wont proceed
    else																																;otherwise
    	echo "The variable triggerVal has not been declared in the config.g file (default = 100)"										;notify user
    So instead of using the G30 command to probe i use M98 P"probe.g".
    undefined 1 Reply Last reply 9 Nov 2021, 08:56 Reply Quote 0
      T3P3Tony administrators @Piet
      @piet if you cant change the way your probe works to not have the analogue hysteresis then you could manually create the mesh by carrying out the "G30" probes you want to, using G30 S-1:
      G30 S-1 ; Probe the bed at the current XY position. When the probe is triggered, do not adjust the Z coordinate, just report the machine height at which the probe was triggered.
      You would need to format the outputs in the same manner as heightmap.csv, potentially you could do this with a macro that stepper through the points you want and echoed it to a file using the ">>" construct.
      undefined 1 Reply Last reply 9 Nov 2021, 08:59 Reply Quote 1
        Piet @T3P3Tony
        @t3p3tony Smart! I don't have a heightmap saved, do you by any chance have an example so i can see how it's formatted?
        undefined 1 Reply Last reply 9 Nov 2021, 09:48 Reply Quote 0
          @piet
          here is an example
          RepRapFirmware height map file v2 generated at 2021-04-28 22:58
          xmin,xmax,ymin,ymax,radius,xspacing,yspacing,xnum,ynum
          5.00,290.00,10.00,190.00,-1.00,15.00,15.00,20,13
            0.088,  0.103,  0.097,  0.082,  0.103,  0.097,  0.088,  0.060,  0.049,  0.049,  0.049,  0.082,  0.090,  0.103,  0.114,  0.123,  0.133,  0.140,  0.139,  0.135
            0.043,  0.058,  0.035,  0.037,  0.058,  0.059,  0.042,  0.021,  0.040,  0.037,  0.044,  0.051,  0.045,  0.076,  0.089,  0.100,  0.109,  0.116,  0.116,  0.110
            0.024,  0.040,  0.018,  0.019,  0.043,  0.037,  0.002,  0.001, -0.004, -0.002,  0.000,  0.026,  0.039,  0.052,  0.040,  0.075,  0.088,  0.089,  0.091,  0.087
            0.013,  0.017, -0.002,  0.027,  0.023,  0.013,  0.013, -0.017,  0.005,  0.002,  0.005,  0.014,  0.023,  0.034,  0.031,  0.057,  0.070,  0.074,  0.073,  0.067
            0.002,  0.008, -0.012,  0.017,  0.012, -0.017,  0.002,  0.001, -0.001, -0.007, -0.001,  0.003, -0.017,  0.024,  0.041,  0.047,  0.058,  0.061,  0.062,  0.055
           -0.003,  0.004,  0.005, -0.022,  0.002, -0.006, -0.010, -0.014, -0.013, -0.014, -0.012, -0.008,  0.002,  0.013,  0.030,  0.036,  0.046,  0.049,  0.048,  0.042
           -0.009, -0.003,  0.001, -0.003, -0.003, -0.013, -0.018, -0.022, -0.025, -0.024, -0.021, -0.018, -0.006,  0.003,  0.019,  0.027,  0.037,  0.039,  0.036,  0.030
           -0.006, -0.001, -0.004, -0.004, -0.008, -0.017, -0.021, -0.026, -0.030, -0.031, -0.028, -0.022, -0.013, -0.001,  0.012,  0.020,  0.029,  0.033,  0.030,  0.023
           -0.005, -0.006, -0.007, -0.004, -0.007, -0.018, -0.023, -0.027, -0.030, -0.033, -0.031, -0.025, -0.014, -0.004,  0.011,  0.020,  0.029,  0.031,  0.027,  0.022
            0.001,  0.003, -0.000,  0.000, -0.005, -0.014, -0.020, -0.026, -0.031, -0.033, -0.032, -0.024, -0.018, -0.005,  0.004,  0.020,  0.027,  0.030,  0.027,  0.022
            0.005,  0.007,  0.004,  0.004,  0.001, -0.007, -0.016, -0.021, -0.026, -0.026, -0.027, -0.021, -0.015, -0.002,  0.010,  0.020,  0.029,  0.033,  0.029,  0.026
            0.022,  0.026,  0.019,  0.018,  0.014,  0.008,  0.001, -0.006, -0.013, -0.014, -0.016, -0.008,  0.001,  0.013,  0.026,  0.033,  0.039,  0.041,  0.039,  0.035
            0.043,  0.044,  0.035,  0.035,  0.019,  0.020,  0.013,  0.007,  0.002, -0.015,  0.000,  0.003,  0.013,  0.022,  0.035,  0.042,  0.028,  0.052,  0.049,  0.046
            Piet
            For future reference, this works.
            The probe file can be adjusted to allow for different types of probing.
            M98 P"waitForHeaters.g" H01
            ;M291 R"Probing." P" " S1
            		else																				;otherwise
            	else																					;otherwise
            ;M292
            if global.bedLeveled == 0
            	G32
            M98 P"probe.g" X525 Y250
            echo >"heightmap.csv" "Height map file generated at", state.time
            echo >>"heightmap.csv" "xmin,xmax,ymin,ymax,radius,xspacing,yspacing,xnum,ynum"
            echo >>"heightmap.csv" global.xMin,",",global.xMax,",",global.yMin,",",global.yMax, ", -1 ,",global.xSpacing,",",global.ySpacing,",",global.xNum,",",global.yNum
            var y = global.yMin
            var i = 0
            G90
            while var.i < global.yNum
            	var x = global.xMin
            	var j = 0
            	while var.j < global.xNum
            		M98 P"probe.g" X{var.x} Y{var.y} S-1
            		M400
            		if var.j == 0
            			set global.meshLine = sensors.probes[0].lastStopHeight - sensors.probes[0].triggerHeight
            		else
            			set global.meshLine = global.meshLine ^ "," ^ sensors.probes[0].lastStopHeight - sensors.probes[0].triggerHeight
            		set var.x = var.x + global.xSpacing
            		set var.j = var.j + 1
            	echo >>"heightmap.csv" global.meshLine
            	set var.y = var.y + global.ySpacing
            	set var.i = var.i + 1
            • Phaedruxundefined Phaedrux moved this topic from My Duet controlled machine 15 Mar 2022, 19:35
