    Duet 3 6HC Accelerometer not found on specified port
    Beta Firmware
    • Ksteveundefined
      Ksteve
      Re: [Duet 3 mini 5+/6HC] Accelerometer not found on specified port
      I am using the wiring specified at this location:
      https://duet3d.dozuki.com/Wiki/Accelerometers
      Confirmed all wires are connected via multi-meter and to correct locations as specified in the table. Note I am using M955 P0 C"spi.cs2_spi.cs3" instead of the cs3 and cs4.
      Per: https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Wiring_Diagram
      My duet 3 does not have a cs4 port.
      I am connecting directly to the mainboard, no daughterboard.
      PCRundefined 1 Reply Last reply Reply Quote 0
      • PCRundefined
        PCR @Ksteve
        @ksteve it's C"pin1+pin2"
        Ksteveundefined 1 Reply Last reply Reply Quote 0
        • Ksteveundefined
          Ksteve @PCR
          @pcr With that I get "Unknown pin name 'pin1'"
          Also may be relevant, but this is the firmware currently on the board:
          RepRapFirmware for Duet 3 MB6HC 3.4.0beta6 (2021-11-06)
          Running the LIS3DH accelerometer
          Just got it to recognize the accelerometer with C"SPI.CS3+SPI.CS2". Flipped the order on cs3 and cs2.
          • dc42undefined dc42 marked this topic as a question
          • dc42undefined dc42 has marked this topic as solved
            T3P3Tony administrators @Ksteve
            @ksteve yes, what @pcr way saying is you needed a "+" not an "_" in the command.
            • Ksteveundefined
              Ksteve @T3P3Tony
              @t3p3tony Oh gotcha, yeah that was a typo in my question, had been testing with "+". Appreciate your responses!
