    M204 with square corner velocity like in Klipper?
    • medicusdkfzundefined
      medicusdkfz
      I want to use a python script for SuperSlicer for post processing my gcode. Is there an equivalent to the M204 with square corner velocity from Klipper in RRF?
      SET_VELOCITY_LIMIT ACCEL=7000 ACCEL_TO_DECEL=7000 SQUARE_CORNER_VELOCITY=8
      This has to be transformed into settings for RRF...
      Thank you very much,
      Pierre
      PCRundefined Phaedruxundefined 2 Replies Last reply Reply Quote 1
      • PCRundefined
        PCR @medicusdkfz
        @medicusdkfz M566?
          Phaedrux Moderator @medicusdkfz
          @medicusdkfz said in M204 with square corner velocity like in Klipper?:
          Can you explain to those unfamiliar with Klipper what that command configures?
