    Trigger file not working as expected.
    557
    • Chrissundefined
      Chriss @Chriss
      @chriss
      Hi Frederick,
      I tried what you mentioned, that made it even worth. The push button acts now exactly as a push button. So the LEDs go one if I press the button and go of when I release it button.
      The plan was to toggle between the states. So first push = on, second push = off.
      Cheers, Chriss
      • fcwiltundefined
        fcwilt @Chriss
        @chriss said in Trigger file not working as expected.:
        @chriss
        Hi Frederick,
        Cheers, Chriss
        Mechanical switches don't change cleanly from one state to another - the contacts bounce and the state can change several times from one state to the other before the bouncing stops and the final state is obtained.
        That may be what you are seeing.
        Try upping the P parameter in the G4 to 1000 and see if that makes any difference.
        I use push buttons for triggers BUT I am not trying to toggle a state, just set a state.
        Chrissundefined 1 Reply Last reply Reply Quote 0
        • Chrissundefined
          Chriss @fcwilt
          @fcwilt said in Trigger file not working as expected.:
          Nope, this is not the case. I see it clearly when I press the button and hold it. It goes on, and it goes off when I release it.
          There is a other problem. The trigger2.g is triggered in both situations in my opinion. This explains perfectly what I see when I push and release the button. the actualValue and the requestedValue change accordingly int he Object Model.
          I tried that, but this does not help. I understand what you mean, but this is not a problem with the bouncing of the switch. It is, in my opinion, the problem that the trigger get executed at the push and at the release.
          Cheers, Chriss
          fcwiltundefined cosmowaveundefined 2 Replies Last reply Reply Quote 0
          • fcwiltundefined
            fcwilt @Chriss
            Well, it is beta firmware so it could well be a bug. Or it could be a bug that has existed for some time but simply has gone unnoticed. As I mentioned it would not have effected they way I have used triggers.
            If I get a chance I will see if I can toggle a value in 3.3.
            • cosmowaveundefined
              cosmowave @Chriss
              Normally this happens when the switch is bouncing...
              Mankati FSXT+, DeltaTowerV2, E3D MS/TC
              • Chrissundefined
                Chriss @cosmowave
                @cosmowave
                Yes... I know what you mean... Anyway, I tried it now with:
                config.g
                M950 J1 C"^0.io1.in"
                M581 P1 T2 S0
                trigger2.g
                if fans[5].actualValue == 1
                   M106 P5 S0
                   G4 P1000			; Wait 1000ms
                else
                   M106 P5 S255
                The LEDs go on now for two seconds. (What a surprise. 🙂 )
                I'm very sure that the trigger2.g gets executed twice, at the push and at the release.
                Cheers, Chriss
                Chrissundefined OwenDundefined 2 Replies Last reply Reply Quote 0
                • Chrissundefined
                  Chriss @Chriss
                  @chriss OK, we can close it now....
                  It works now... do not ask me why but it works. I rebooted the printer for some other changes and it seems to work now as expected..... :?
                  Anyway, thanks for your hep @cosmowave, your direction with the S0 did it at the end.
                  Cheers, Chriss
                  • OwenDundefined
                    OwenD @Chriss
                    @chriss
                    Try this
                    EDIT
                    You need to check the pin twice to ensure it's finished bouncing
                    I should have had my coffee before posting
                    if sensors.gpIn[1].value=1
                       G4 P500
                             M106 P5 S0
                          else
                             M106 P5 S255
                    You may need to increase P500 depending on how long your button is bouncing
                    • Phaedruxundefined Phaedrux has marked this topic as solved
                    • fcwiltundefined
                      fcwilt @Chriss
                      Cheers, Chriss
                      You sure?
                      I just tried it under firmware 3.3 and the results were inconsistent, sometimes worked, sometimes didn't. More often then not it would trigger on push and release.
                      I'm pretty sure it is contact bounce which is surprising because I would have thought the firmware code for triggers would have de-bounced the inputs.
                      cosmowaveundefined Chrissundefined 2 Replies Last reply Reply Quote 0
                        cosmowave @fcwilt
                        @fcwilt No. The firmware makes no debounce.
                        My flowsensor of the watercooling switchs a relay, which has bouncing contacts.
                        I use also a G4 in my trigger2 macro for software de-bounce.
                        • Chrissundefined
                          Chriss @fcwilt
                          You sure?
                          Not 100% about the S0, but sure that it works now.
                          I guess that your "G4 250" makes the de bouncing here. And the behavior is consistent.
                          The 2nd press of the switch will not do anything when I press the switch fast enough. (Below 250ms)
                          With the finally final settings is that gone:
                             M106 P5 S0
                             G4 P25			; Wait 25ms
                          else
                             M106 P5 S255
                             G4 P25			; Wait 25ms
                          G4 P10			; Wait 10ms
                          It is not easy to press the button in 35ms after the first press.
                          I guess that something in the live configuration was mixed up and and have forgotten to reboot to verify the config.
                          Cheers, Chriss
