Solved Duet delta prints mirror image
ok this will be obvious I am sure but I have just realised that the prints from my delta are a mirror image of the model that I slice.
I didnt notice as the parts I have printed were not handed but printing a fan shroud its obvious as the blower fan mounts the opposite way. on my delta shroud I have 3 diferent faces that on the model run clockwise 123 but when printed they are 321 if that makes sense.
whats wrong??
Sounds like you have your coordinate system flipped.
I would suggest going back to basics and running through the delta setup and calibration guides.
https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter
https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printerMake sure your towers are where they should be.
@phaedrux yup thats sounding right I had the same with Z and thought I had it figured out.
Time to try again
Swapped the x and y motors and endstops and think thats fixed it. Thanks again for the pointer.
I think I went clockwise not anticlockwise when I first added the Duet.
