    Configurator seems to not generate the stated files.
    Config Tool
    703
    • FrankVundefined
      FrankV @kcress
      @kcress If you open the zip with winrar you see other files as with the windows explorer. It looks like different engines come to different results. I am going to use winrar en put all files on the sd card manually. I think this is a good workaround till they fix it.
      • kcressundefined
        kcress @FrankV
        @frankv Hmmm sounds like I'm not seeing the encoded files in the json but they're there. That would explain them spooling by on the DWC during uploads.
        Sounds like your webgui may not be correctly decoding the json. However your upload issue may be identical to mine.
        kcressundefined 1 Reply Last reply Reply Quote 0
        • kcressundefined
          kcress @kcress
          @kcress If I extract I see ONLY:
          config.json
          tpost0.g
          In the sys directory.
          The www and
          firmware seem okay.
          • chrishammundefined
            chrishamm administrators @kcress
            @kcress @FrankV I am looking into it. It appears Windows is having problems with the generated ZIP files. Use WinRAR or 7zip to extract the files if necessary, it appears to be working with these tools.
            Duet software engineer
            • kcressundefined
              kcress @chrishamm
              @chrishamm !!!!!!!! Yay! If I use 7zip I absolutely see the promised *.g files!
              So the problem is with the DWC or the board.
              FrankVundefined 1 Reply Last reply Reply Quote 0
              • FrankVundefined
                FrankV @kcress
                @kcress @chrishamm you need to rename them in Winrar because when they unarchive you get extention .g_ instead of .g
                • kcressundefined
                  kcress @FrankV
                  @frankv Yikes! Thanks for that tip. 7zip generates the .g_ too.
                    @kcress @FrankV Now fixed in v3.3.7, please reload the configtool using Ctrl+Shift+R and it will produce correct archives again.
                    kcressundefined FrankVundefined 2 Replies Last reply Reply Quote 0
                    • kcressundefined
                      kcress @chrishamm
                      @chrishamm Indeed that works correctly with windoz AND 7zip. The .g files are there without "_".
                      Thanks. Do you think this was related to the file upload problem? I'm thinking it is. I'll go out to the shop and try it. 3:50am. LOL
                      • FrankVundefined
                        FrankV @chrishamm
                        @chrishamm still got issues did refresh.
                          @kcress Yes, I think so. I changed my dev setup from Linux to Windows the other day so the filenames in v3.3.6 had an extra line break character (CR) at the end, which wasn't there before and barely visible (doh!).
                            chrishamm administrators @FrankV
                            @frankv Please share your config.json file again.
                            • FrankVundefined
                              FrankV @chrishamm
                              This post is deleted!
                                @frankv If you reload the configtool on the last page, it loses all the entered value. So go back to the start, click on the last radio item, and then reload your config.json before you generate the ZIP bundle. I'll have a look at this issue anyway.
                                • FrankVundefined
                                  FrankV @chrishamm
                                  @chrishamm reuploaded it. I exposed my wifi credentials. It's my first config so there could be stuff in what is not good. Maybe the fact i offset the probe to minus 22mm.
                                  config.json
                                  • kcressundefined
                                    kcress @chrishamm
                                    @chrishamm It worked! Mostly.
                                    "File list missing" in red showed up, then it seemed to proceed normally.
                                    All the new *.g files appeared in DWC and immediately fans came on for the first time ever. Yay!
                                    Then it stated "Please wait while updates are being installed".
                                    It's been over 10 minutes. I'm a bit afraid to RESET for fear of maybe bricking the board if it REALLY is updating it's firmware.
                                    Thoughts?
                                    • kcressundefined
                                      kcress @kcress
                                      @kcress After 25 minutes I rebooted the HC's.
                                      Then it left me muddling about since it changed IP addresses. Had to comb the router tables to find Waldo. But it was there and now I get motion too. A little screwed up X,Y move reversed directions but I should have that sorted after some sleep.
                                      Thanks all for the help.
                                      chrishamm; A big thanks for jumping on that configurator issue so fast. Big kudos man!
                                      • Phaedruxundefined Phaedrux has marked this topic as solved
