    [3.4beta6] Toolboard missing extrusion and M122 error
    Beta Firmware
    1.4k
      T3P3Tony administrators @Pakue
      @pakue can you send the results of the M122 for the mainboard after you have seen this issue as well please.
      • Pakueundefined
        Pakue
        @t3p3tony
        That's during printing. I can try to get an M122 right after a line is skipped.
        m122
        RepRapFirmware for Duet 3 MB6HC version 3.4.0beta6 (2021-11-06 11:38:57) running on Duet 3 MB6HC v1.01 or later (SBC mode)
        Board ID: 08DJM-956BA-NA3TJ-6J9F6-3SD6M-TB96T
        Used output buffers: 1 of 40 (12 max)
        Static ram: 151136
        Dynamic ram: 65936 of which 580 recycled
        Never used RAM 132060, free system stack 140 words
        Tasks: SBC(ready,0.6%,498) HEAT(notifyWait,0.0%,320) Move(notifyWait,0.6%,250) CanReceiv(notifyWait,0.0%,771) CanSender(notifyWait,0.0%,365) CanClock(delaying,0.0%,340) TMC(notifyWait,8.1%,58) MAIN(running,90.4%,921) IDLE(ready,0.2%,30), total 100.0%
        Owned mutexes: HTTP(MAIN)
        Last reset 00:53:55 ago, cause: software
        Last software reset at 2021-11-28 23:28, reason: User, none spinning, available RAM 143092, slot 1
        Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
        Error status: 0x00
        Step timer max interval 139
        MCU temperature: min 41.9, current 45.5, max 46.0
        Supply voltage: min 23.6, current 23.9, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
        12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
        Driver 0: pos 28052, standstill, SG min 0, mspos 8, reads 16451, writes 11 timeouts 0
        Driver 1: pos -716, ok, SG min 0, mspos 815, reads 16426, writes 36 timeouts 0
        Driver 2: pos 7376, ok, SG min 0, mspos 616, reads 16426, writes 36 timeouts 0
        Driver 3: pos 0, ok, SG min 0, mspos 977, reads 16441, writes 21 timeouts 0
        Driver 4: pos 0, ok, SG min 0, mspos 977, reads 16441, writes 21 timeouts 0
        Driver 5: pos 0, ok, SG min 0, mspos 977, reads 16442, writes 21 timeouts 0
        Date/time: 2021-11-29 00:36:24
        Slowest loop: 1021.09ms; fastest: 0.04ms
        === Storage ===
        Free file entries: 10
        DMs created 125, segments created 40, maxWait 462853ms, bed compensation in use: mesh, comp offset 0.000
        === MainDDARing ===
        Scheduled moves 9065, completed 9005, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state 3
        === AuxDDARing ===
        Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
        Heater 0 is on, I-accum = 0.7
        Heater 1 is on, I-accum = 0.0
        Segments left: 1
        Movement lock held by null
        Telnet is idle in state(s) 0
        File* is doing "G1 X154.501007 Y179.203003 E93.792648" in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Queue* is idle in state(s) 0
        LCD is idle in state(s) 0
        SBC is idle in state(s) 0
        Daemon is idle in state(s) 0
        Aux2 is idle in state(s) 0
        Code queue is empty
        === CAN ===
        Messages queued 37362, received 52073, lost 0, longest wait 5ms for reply type 6024, peak Tx sync delay 3539, free buffers 49 (min 46), ts 16179/16118/0
        Tx timeouts 0,0,0,0,0,0
        === SBC interface ===
        Transfer state: 4, failed transfers: 0, checksum errors: 0
        RX/TX seq numbers: 58087/58087
        SPI underruns 0, overruns 0
        State: 5, disconnects: 1, timeouts: 1, IAP RAM available 0x2b68c
        Buffer RX/TX: 3968/1368-4064
        === Duet Control Server ===
        Duet Control Server v3.4-b6
        File /opt/dsf/sd/gcodes/Tray.gcode is selected, processing
        File:
        Buffered code: G1 X154.076 Y179.628 E93.81991
        Buffered code: G1 X153.529 Y179.628 E93.84469
        Buffered code: G1 X153.954 Y179.203 E93.87195
        Buffered code: G1 X153.407 Y179.203 E93.89673
        Buffered code: G1 X152.982 Y179.628 E93.92399
        Buffered code: G1 X152.435 Y179.628 E93.94877
        Buffered code: G1 X152.861 Y179.203 E93.97603
        Buffered code: G1 X152.314 Y179.203 E94.00081
        Buffered code: G1 X151.889 Y179.628 E94.02807
        Buffered code: G1 X151.342 Y179.628 E94.05285
        Buffered code: G1 X151.767 Y179.203 E94.08011
        Buffered code: G1 X151.220 Y179.203 E94.10489
        Buffered code: G1 X150.795 Y179.628 E94.13215
        Buffered code: G1 X150.248 Y179.628 E94.15693
        Buffered code: G1 X150.673 Y179.203 E94.18418
        Buffered code: G1 X150.127 Y179.203 E94.20896
        Buffered code: G1 X149.701 Y179.628 E94.23622
        Buffered code: G1 X149.155 Y179.628 E94.26100
        Buffered code: G1 X149.580 Y179.203 E94.28826
        Buffered code: G1 X149.033 Y179.203 E94.31304
        Buffered code: G1 X148.608 Y179.628 E94.34030
        Buffered code: G1 X148.061 Y179.628 E94.36508
        Buffered code: G1 X148.486 Y179.203 E94.39234
        Buffered code: G1 X147.940 Y179.203 E94.41712
        Buffered code: G1 X147.514 Y179.628 E94.44438
        Buffered code: G1 X146.967 Y179.628 E94.46916
        Buffered code: G1 X147.393 Y179.203 E94.49642
        Buffered code: G1 X146.846 Y179.203 E94.52120
        Buffered code: G1 X146.421 Y179.628 E94.54846
        Buffered code: G1 X145.874 Y179.628 E94.57324
        Buffered code: G1 X146.299 Y179.203 E94.60049
        ==> 1488 bytes
        Pending code: G1 X145.752 Y179.203 E94.62527
        Code buffer space: 2600
        Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
        Full transfers per second: 39.63, max wait times: 80.8ms/11.0ms
        Codes per second: 4.35
        Maximum length of RX/TX data transfers: 3212/1196
          @pakue said in [3.4beta6] Toolboard missing extrusion and M122 error:
          === CAN ===
          Thanks - the CAN communications look good
          Yes send M122 M122 B20 to dump both the mainboard and the toolboard please.
          Pakueundefined 1 Reply Last reply Reply Quote 0
          • Pakueundefined
            Pakue @T3P3Tony
            @t3p3tony
            This is now right after a line was skipped:
            M122 M122 B20
            Static ram: 151136
            Never used RAM 131988, free system stack 128 words
            Tasks: SBC(ready,0.6%,498) HEAT(notifyWait,0.0%,320) Move(notifyWait,0.2%,239) CanReceiv(notifyWait,0.0%,771) CanSender(notifyWait,0.0%,365) CanClock(delaying,0.0%,340) TMC(notifyWait,8.3%,58) MAIN(running,89.0%,921) IDLE(ready,1.8%,30), total 100.0%
            Last reset 02:14:27 ago, cause: software
            Error status: 0x00
            Step timer max interval 132
            MCU temperature: min 45.8, current 46.6, max 46.7
            Supply voltage: min 23.7, current 23.8, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
            12V rail voltage: min 12.1, current 12.1, max 12.1, under voltage events: 0
            Driver 0: pos 21605, standstill, SG min n/a, mspos 8, reads 21585, writes 0 timeouts 0
            Driver 1: pos 5882, standstill, SG min 0, mspos 824, reads 21580, writes 6 timeouts 0
            Driver 2: pos 427, ok, SG min 0, mspos 442, reads 21580, writes 6 timeouts 0
            Driver 3: pos 0, ok, SG min 0, mspos 580, reads 21583, writes 2 timeouts 0
            Driver 4: pos 0, ok, SG min 0, mspos 580, reads 21583, writes 2 timeouts 0
            Driver 5: pos 0, ok, SG min 0, mspos 580, reads 21583, writes 2 timeouts 0
            Date/time: 2021-11-29 01:56:56
            Slowest loop: 1002.25ms; fastest: 0.04ms
            === Storage ===
            DMs created 125, segments created 43, maxWait 349053ms, bed compensation in use: mesh, comp offset 0.000
            === MainDDARing ===
            Scheduled moves 286, completed 281, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
            === AuxDDARing ===
            Heater 0 is on, I-accum = 1.0
            Segments left: 1
            File* is doing "G1 X171.792999 Y100.209000 E36.715832" in state(s) 0
            Code queue is empty
            === CAN ===
            Messages queued 2903, received 4697, lost 0, longest wait 2ms for reply type 6024, peak Tx sync delay 109, free buffers 49 (min 47), ts 1390/1387/0
            RX/TX seq numbers: 53035/53035
            Buffer RX/TX: 1584/3096-0
            File:
            Buffered code: G1 X171.793 Y100.209 E36.71583
            Buffered code: G1 X171.793 Y100.855 E36.73919
            Buffered code: G1 X139.986 Y69.048 E38.36396
            Buffered code: G1 X139.339 Y69.048 E38.38732
            Buffered code: G1 X171.793 Y101.502 E40.04512
            Buffered code: G1 X171.793 Y102.149 E40.06848
            Buffered code: G1 X138.693 Y69.048 E41.75931
            Buffered code: G1 X138.046 Y69.048 E41.78267
            Buffered code: G1 X171.793 Y102.795 E43.50654
            Buffered code: G1 X171.793 Y103.442 E43.52990
            Buffered code: G1 X137.399 Y69.048 E45.28680
            Buffered code: G1 X136.753 Y69.048 E45.31016
            Buffered code: G1 X171.793 Y104.089 E47.10009
            Buffered code: G1 X171.793 Y104.735 E47.12345
            Buffered code: G1 X136.106 Y69.048 E48.94642
            Buffered code: G1 X135.459 Y69.048 E48.96977
            Buffered code: G1 X171.793 Y105.382 E50.82577
            Buffered code: G1 X171.793 Y106.028 E50.84913
            Buffered code: G1 X135.007 Y69.242 E52.72823
            Buffered code: G1 X135.007 Y69.889 E52.75159
            Buffered code: G1 X171.793 Y106.675 E54.63069
            Buffered code: G1 X171.793 Y107.322 E54.65405
            Buffered code: G1 X135.007 Y70.536 E56.53315
            Buffered code: G1 X135.007 Y71.182 E56.55651
            Buffered code: G1 X171.793 Y107.968 E58.43561
            Buffered code: G1 X171.793 Y108.615 E58.45897
            Buffered code: G1 X135.007 Y71.829 E60.33807
            Buffered code: G1 X135.007 Y72.476 E60.36143
            Buffered code: G1 X171.793 Y109.262 E62.24053
            Buffered code: G1 X171.793 Y109.908 E62.26389
            Buffered code: G1 X135.007 Y73.122 E64.14299
            Buffered code: G1 X135.007 Y73.769 E64.16635
            ==> 1536 bytes
            Code buffer space: 1464
            Full transfers per second: 40.10, max wait times: 54.1ms/1.9ms
            Codes per second: 14.88
            Maximum length of RX/TX data transfers: 3212/1664
            Error: Diagnostics for board 20:
            Duet TOOL1LC rev 1.1 or later firmware version 3.4.0beta6 (2021-11-06 11:56:11)
            Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
            M122: Response timeout: CAN addr 20, req type 6024, RID=439
              jay_s_uk @Pakue
              @pakue send M122 B20 as well by itself
              • Pakueundefined
                Pakue @jay_s_uk
                @jay_s_uk unfortunately a similar result.
                M122 b20
                M122: Response timeout: CAN addr 20, req type 6024, RID=189
                after M122
                M122
                Static ram: 151136
                Never used RAM 129156, free system stack 127 words
                Tasks: SBC(ready,0.6%,476) HEAT(notifyWait,0.0%,320) Move(notifyWait,0.1%,252) CanReceiv(notifyWait,0.0%,771) CanSender(notifyWait,0.0%,365) CanClock(delaying,0.0%,340) TMC(notifyWait,7.5%,58) MAIN(running,91.6%,921) IDLE(ready,0.2%,30), total 100.0%
                Last reset 00:45:38 ago, cause: power up
                Error status: 0x00
                Step timer max interval 133
                MCU temperature: min 22.5, current 44.4, max 44.9
                Supply voltage: min 23.4, current 23.9, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/72/0, gc cycles 0
                Driver 0: pos 20093, standstill, SG min 0, mspos 8, reads 29477, writes 11 timeouts 0
                Driver 1: pos -3588, ok, SG min 0, mspos 394, reads 29464, writes 24 timeouts 0
                Driver 2: pos 845, standstill, SG min 0, mspos 888, reads 29464, writes 24 timeouts 0
                Driver 3: pos 0, ok, SG min 0, mspos 339, reads 29471, writes 17 timeouts 0
                Driver 4: pos 0, ok, SG min 0, mspos 339, reads 29472, writes 17 timeouts 0
                Driver 5: pos 0, ok, SG min 0, mspos 339, reads 29472, writes 17 timeouts 0
                Date/time: 2021-11-29 16:52:26
                Slowest loop: 1002.34ms; fastest: 0.04ms
                === Storage ===
                DMs created 125, segments created 42, maxWait 2340188ms, bed compensation in use: mesh, comp offset 0.000
                === MainDDARing ===
                Scheduled moves 2057, completed 2052, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
                === AuxDDARing ===
                Segments left: 1
                File* is doing "G1 X105.864998 Y148.003998 E156.572769" in state(s) 0
                Code queue is empty
                === CAN ===
                Messages queued 26681, received 43884, lost 0, longest wait 2ms for reply type 6049, peak Tx sync delay 1113, free buffers 49 (min 43), ts 13692/13667/0
                RX/TX seq numbers: 42985/42985
                State: 5, disconnects: 0, timeouts: 0, IAP RAM available 0x2b6b8
                Buffer RX/TX: 1536/3080-0
                File /opt/dsf/sd/gcodes/Standard_Box v23.gcode is selected, processing
                File:
                Buffered code: G1 X105.865 Y148.004 E156.57277
                Buffered code: G1 X106.767 Y148.004 E156.64097
                Buffered code: G1 X143.747 Y111.023 E160.59435
                Buffered code: G1 X143.747 Y111.925 E160.66254
                Buffered code: G1 X107.669 Y148.004 E164.51948
                Buffered code: G1 X108.571 Y148.004 E164.58768
                Buffered code: G1 X143.748 Y112.828 E168.34819
                Buffered code: G1 X143.748 Y113.730 E168.41638
                Buffered code: G1 X109.473 Y148.004 E172.08047
                Buffered code: G1 X110.376 Y148.004 E172.14866
                Buffered code: G1 X143.748 Y114.632 E175.71632
                Buffered code: G1 X143.748 Y115.534 E175.78451
                Buffered code: G1 X111.278 Y148.004 E179.25572
                Buffered code: G1 X112.180 Y148.004 E179.32392
                Buffered code: G1 X143.748 Y116.436 E182.69871
                Buffered code: G1 X143.748 Y117.338 E182.76690
                Buffered code: G1 X113.082 Y148.004 E186.04526
                Buffered code: G1 X113.984 Y148.004 E186.11346
                Buffered code: G1 X143.749 Y118.240 E189.29538
                Buffered code: G1 X143.749 Y119.142 E189.36357
                Buffered code: G1 X114.887 Y148.004 E192.44907
                Buffered code: G1 X115.789 Y148.004 E192.51726
                Buffered code: G1 X143.749 Y120.044 E195.50633
                Buffered code: G1 X143.749 Y120.946 E195.57452
                Buffered code: G1 X116.691 Y148.004 E198.46715
                Buffered code: G1 X117.593 Y148.004 E198.53535
                Buffered code: G1 X143.749 Y121.848 E201.33155
                Buffered code: G1 X143.749 Y122.750 E201.39974
                Buffered code: G1 X118.495 Y148.004 E204.09950
                Buffered code: G1 X119.397 Y148.004 E204.16770
                Buffered code: G1 X143.749 Y123.652 E206.77104
                Buffered code: G1 X143.750 Y124.555 E206.83923
                ==> 1536 bytes
                Code buffer space: 1416
                Full transfers per second: 2.77, max wait times: 36.6ms/10.0ms
                Codes per second: 0.15
                Maximum length of RX/TX data transfers: 3040/1508
                  jay_s_uk @Pakue
                  @pakue looks like you have an issue with your CAN wiring between the 6HC and the toolboard
                  • Pakueundefined
                    Pakue @jay_s_uk
                    @jay_s_uk It's printing fine except for the missed extrusions. Wouldn't signalling errors be caught by the CAN "lost" counter?
                      jay_s_uk @Pakue
                      @pakue on the toolboard yes.
                      but you can't get any info from it, hence the
                      • Pakueundefined
                        Pakue @jay_s_uk
                        @jay_s_uk I can try to shorten the CAN cable and add some shielding. Let's see if that helps.
                          dc42 administrators @Pakue
                          @pakue the length of the CAN cable is not critical, neither does not normally need to be shielded.
                          The only time I have seen issues with CAN communication caused by other devices is when I had long wires between the PSU and a Duet 3 main board that was driving a powerful 24V bed heater, and there were separate wires from the PSU to the other CAN devices. In this case the differential ground noise caused by the bed heater turning on/off and the long wires to the PSU introduced a lot of ground noise.
                          The M122 B20 result is strange, because the board is responding to the first request for M122 data, but failing to respond to some of the subsequent requests. Does M122 B20 always run reliably when the machine is not printing?
                          Pakueundefined 2 Replies Last reply Reply Quote 0
                          • Pakueundefined
                            Pakue @dc42
                            @dc42 I do indeed have a ~300W 24V heated bed, but the wires are >2mm^2, 30cm in length and split at the PSU between heated bed and the rest of the electronics. I can measure the GND offset/noise at the toolboard when everything is heating up to double check.
                            The M122 seems to be unreliable during printing, but works (at least sends some data) when the printer just started. About after a print; I'd have to check that.
                            With RFF 3.3 the M122 doesn't show errors.
                            dc42undefined 2 Replies Last reply Reply Quote 0
                              @pakue please make the GCode file you are printing available. I will then test it on the bench, including running M122 while a print is running.
                              • Pakueundefined
                                Pakue @dc42
                                @dc42 that one is running 0.9mm extrusion width on a 0.4 nozzle, but I can slice it with standard settings if preferred. The issue is reproducible on other settings too.
                                Standard_Box v19.gcode
                                • Pakueundefined
                                  Pakue @dc42
                                  @dc42 DC offsets between toolboard GND and Duet3 GND input are
                                  • 17mV default
                                  • 33mV with bed heater on
                                  • 430mV with hotend on
                                  For noise measurements I'd have to pull out the scope.
                                  After a print once everything is turned off (fans, heater, etc.) the M122 still throws errors, so I'm guessing noise is not the root cause?
                                  m122 b20
                                  M122: Response timeout: CAN addr 20, req type 6024, RID=234
                                    @pakue i agree it looks less likely that noise is the issue. Can you try reinstalling the firmware (M997 B20) on the toolboard. ensure you have the 3.4b6 toolboards firmware binary in the /firmware directory on the SD card.
                                    • Pakueundefined
                                      Pakue @T3P3Tony
                                      @t3p3tony Updating via CAN it gets stuck on "Please wait while updates are being installed..." and the toolboard only shows up again after downgrading the MB6HC to 3.3.
                                      Even resetting the toolboard (both buttons pressed while powering up) doesn't reset it to the original address (121).
                                      V3.3 on the MB6HC returns the full M122 as far as I can tell
                                      M122 B20
                                      Never used RAM 2752, free system stack 2788 words
                                      Tasks: Move(notifyWait,0.0%,153) HEAT(notifyWait,0.2%,115) CanAsync(notifyWait,0.0%,64) CanRecv(notifyWait,0.0%,77) CanClock(notifyWait,0.0%,64) ACCEL(notifyWait,0.0%,61) TMC(delaying,3.0%,57) MAIN(running,91.8%,340) IDLE(ready,0.0%,27) AIN(delaying,4.9%,142), total 100.0%
                                      Last reset 00:03:20 ago, cause: software
                                      Last software reset data not available
                                      Driver 0: pos 0, 655.0 steps/mm,standstill, SG min 0, read errors 0, write errors 1, ifcnt 23, reads 34732, writes 13, timeouts 0, DMA errors 0, steps req 0 done 0
                                      Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                                      Peak sync jitter 2/6, peak Rx sync delay 212, resyncs 0/0, no step interrupt scheduled
                                      VIN voltage: min 23.8, current 24.0, max 24.1
                                      MCU temperature: min 37.2C, current 37.7C, max 37.8C
                                      Last sensors broadcast 0x00000002 found 1 100 ticks ago, 0 ordering errs, loop time 0
                                      CAN messages queued 4005, send timeouts 0, received 1804, lost 0, free buffers 37, min 37, error reg 0
                                      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
                                      Accelerometer detected: yes, status: 00
                                      I2C bus errors 0, naks 3, other errors 0
                                      M122
                                      M122
                                      RepRapFirmware for Duet 3 MB6HC version 3.3 (2021-06-15 21:45:47) running on Duet 3 MB6HC v1.01 or later (SBC mode)
                                      Used output buffers: 1 of 40 (10 max)
                                      Static ram: 150904
                                      Dynamic ram: 61580 of which 640 recycled
                                      Never used RAM 141068, free system stack 200 words
                                      Tasks: SBC(ready,17.9%,346) HEAT(delaying,0.0%,325) Move(notifyWait,0.0%,302) CanReceiv(notifyWait,0.0%,774) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,7.3%,93) MAIN(running,74.7%,922) IDLE(ready,0.0%,29), total 100.0%
                                      Last reset 00:05:21 ago, cause: software
                                      Last software reset at 2021-11-29 23:23, reason: User, none spinning, available RAM 141068, slot 0
                                      Error status: 0x00
                                      Step timer max interval 148
                                      MCU temperature: min 43.8, current 44.4, max 44.7
                                      Supply voltage: min 23.6, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                                      Driver 0: position 0, standstill, reads 28365, writes 11 timeouts 0, SG min/max 0/0
                                      Driver 1: position 0, standstill, reads 28360, writes 16 timeouts 0, SG min/max 0/0
                                      Driver 2: position 0, standstill, reads 28360, writes 16 timeouts 0, SG min/max 0/0
                                      Driver 3: position 0, standstill, reads 28362, writes 14 timeouts 0, SG min/max 0/0
                                      Driver 4: position 0, standstill, reads 28362, writes 14 timeouts 0, SG min/max 0/0
                                      Driver 5: position 0, standstill, reads 28363, writes 14 timeouts 0, SG min/max 0/0
                                      Date/time: 2021-11-29 23:28:40
                                      Slowest loop: 26.00ms; fastest: 0.05ms
                                      === Storage ===
                                      DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                                      === MainDDARing ===
                                      === AuxDDARing ===
                                      Segments left: 0
                                      File is idle in state(s) 0
                                      Queue is idle in state(s) 0
                                      Code queue is empty.
                                      === CAN ===
                                      Messages queued 2896, received 6434, lost 0, longest wait 4ms for reply type 6024, peak Tx sync delay 464, free buffers 49 (min 48), ts 1610/1609/0
                                      State: 4, failed transfers: 0, checksum errors: 0
                                      Last transfer: 2ms ago
                                      RX/TX seq numbers: 51414/51414
                                      Disconnects: 0, timeouts: 0, IAP RAM available 0x2c83c
                                      Buffer RX/TX: 0/0-0
                                      Code buffer space: 4096
                                      Full transfers per second: 3846.85, max wait times: 18.1ms/20.2ms
                                      Codes per second: 0.20
                                      Maximum length of RX/TX data transfers: 2940/800
                                        @pakue thanks that's an interesting result! now you have it working and returning the full result can you try the following:
                                        1. try the firmware upgrade again
                                        2. then try upgrading the mainboard to 3.4b6
                                        • Pakueundefined
                                          Pakue @T3P3Tony
                                          @t3p3tony Upgrading the toolboard to the beta6 works, but after upgrading the MB6HC the M122 issue persists:
                                          m122 b20
                                          Tasks: Move(notifyWait,0.0%,153) HEAT(notifyWait,0.1%,101) CanAsync(notifyWait,0.0%,64) CanRecv(notifyWait,0.0%,77) CanClock(notifyWait,0.0%,64) ACCEL(notifyWait,0.0%,61) TMC(delaying,3.0%,67) MAIN(running,92.0%,350) IDLE(ready,0.0%,27) AIN(delaying,4.9%,148), total 100.0%
                                          Last reset 00:00:20 ago, cause: software
                                          Driver 0: pos 0, 655.0 steps/mm,standstill, SG min 0, read errors 0, write errors 1, ifcnt 92, reads 10344, writes 11, timeouts 0, DMA errors 0, steps req 0 done 0
                                          Peak sync jitter 3/6, peak Rx sync delay 186, resyncs 0/0, no step interrupt scheduled
                                          MCU temperature: min 37.9C, current 38.1C, max 38.2C
                                          M122: Last sensors broadcast 0x00000002 found 1 246 ticks ago, 0 ordering errs, loop time 0
                                          CAN messages queued 264, send time
                                          Response timeout: CAN addr 20, req type 6024, RID=17
                                            @pakue thanks. I will need some input from @dc42 on this one!
