    MakerGear M2 Marline to RepRap Z offset help
    Firmware installation
    853
    • fcwiltundefined
      fcwilt @airscapes
      @airscapes said in MakerGear M2 Marline to RepRap Z offset help:
      I would need to edit config.g and reboot the machine, reconnect, reload the model, reheat the bed ot 110C
      Why do you think that would be the case?
      airscapesundefined 1 Reply Last reply Reply Quote 0
        Phaedrux Moderator @airscapes
        M574 Z1 S1 P"!zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin !zstop
        If your endstop is at the high end of travel you need M574 Z2, not Z1.
        What's happening now, is that you're telling it to move to the max end of travel and then trigger the endstop which is defined for low end, so once you home it there it thinks it's at the low end. Forcing the Z position with G92 was overriding that.
        Changing to M574 Z2 should make things behave correctly and you'll be able to use M208 to tweak the Z0 position.
        If you want to measure the exact distance between Z0 and Zmax, try this.
        Move the nozzle to just touch the bed, ideally when both bed and nozzle are at printing temps for a while. When they are touching send G92 Z0. Now send G1 H3 Z400 F600 which will move to the z max endstop and when it triggers it will set M208 Z max to whatever the actual distance from Z0 is. You can send M208 by itself to see what that value is. Then you can use it in the M208 command in your config.g to make it permanent.
        • airscapesundefined
          airscapes @fcwilt
          @fcwilt I think I have 2 problems. Zhome without the G92 disables the use of Z.
          But since this is about Z offset it may just be my lack of RepRap knowledge.
          Let me explain the process to set Z offset that I have been using in Marlin 1.x
          X has hotend top of gantry, X end stop at 0 (right side if sitting in the drivers seat)
          Y end stop at 255 (back
          Z end stop at bottom 215
          Front right X0 Y0 build plate up all the way Z0
          Not sure above data matters.
          When I change a hotend (have a hot end for every nozzle size)
          install hotend and push all the way up and snug
          Set Z0 with M206 Z12.60 (known location same every time)
          ;M500; G28
          send bed up to 0 centered
          G1 F1000 X100 Y125 Z0
          Slide a .003mm feeler under the clean nozzle
          Loosen screw and let the nozzle drop on feeler and snug
          I have a spread sheet of offset I have set after calibration prints for different layer height and bed temp to get really close
          So set that, for instance M206 Z12.45
          M500
          Print the test square with 3mm walls, measure and make changes to Z if walls not 3.00 +- .02 For instance if the wall measures 3.05mm I would enter
          M206 Z12.50 (larger the offset the closer to the nozzle)
          M500
          Print again
          That will remain until I change it again.
          So how would I go about this with Reprap 3.3 if M206 does not work as it does in Marlin
          So basically M206 is moving 0 to -12.xx from max if I understand what is going on. If I put a thicker bed on, I change it to 9.xx to give it more room
          Again there seems to be something else that is not correct, should I start a new thread for the homing and control issue?
          Thanks and sorry for the long winded post but apparently this type of printer design is not all that popular.
          fcwiltundefined dc42undefined Phaedruxundefined 3 Replies Last reply Reply Quote 0
          • fcwiltundefined
            fcwilt @airscapes
            @airscapes
            Since you have a Z endstop sensor this would allow you to establish a repeatable Z=0 position.
            Having that why can you not simply adjust the nozzle for the desired gap when at Z=0?
              dc42 administrators @airscapes
              @airscapes see this response from @Phaedrux:
              That explains why Z would not move down without the G92.
                Once again, the position you describe has the endstops at the high end of travel. Right for X and rear for Y.
                M574 Y1 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin !ystop
                That would mean you should be using M574 X2 and Y2.
                In your case, since both X and Y are flipped, the parts would just come out rotated 180 degrees from your slicer preview. No big deal. If you had only 1 axis flipped, you'd get mirrored parts.
                  airscapes @Phaedrux
                  @phaedrux Ah, I get it.. I did not understand the high and low part, got it..
                  So this should be correct now.
                  M574 X1 S1 P"!xstop"                           ; configure switch-type (e.g. microswitch) endstop for low end on X via pin !xstop
                  M574 Y2 S1 P"!ystop"                           ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin !ystop
                  M574 Z2 S1 P"!zstop"                           ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin !zstop
                  Edit.. something still not right
                  I apologize for my lack of understanding.. should have spent a few weeks studying before jumping in.
                    Yes motor direction will likely need to change as well.
                    Start with the fact that the 0,0 position is in the front left corner. -X moves to the left, +X moves to the right. -Y moves to the front, +Y moves to the back.
                    If the endstop is at the high end of travel (right side for x, or back side for Y) then the M574 will be X2 Y2.
                    Homing move directions would be in the positive direction in the homing macros and the direction of motor rotation will need to match as well so that + moves go right or back, and - moves go left or to the front.
                    I hope that helps.
                      airscapes @Phaedrux
                      @phaedrux said in MakerGear M2 Marline to RepRap Z offset help:
                      I hope that helps.
                      When speaking or front left, is that my left when looking at the machine or the machines left looking at me.. still in the auto repair mindset.. left& right from drivers seat . 0,0,0, is right front with bed up ..
                      I keep thinking I have this correct and then read something that confuses me.
                      Looking at the Marlin config it says this about end stops which makes sense I think because I was wrong about Y.. when the build plate move towards the Y end stop, it is actually moving to position 0. kind of confusing since it is the bed that is moving once homed the nozzle is at Y0, same as X, so would that not make them both Y1 and Z which is farthest from the nozzle 0 when homed be Y2??? Then set motor direction to achieve the proper moves?
                      Here is a pic of all 3 end stops you can see Z between the bed and frame on the left.. Finger is at XY 0
                      // ENDSTOP SETTINGS:
                      // Sets direction of endstops when homing; 1=MAX, -1=MIN
                      #define X_HOME_DIR -1
                      #define Y_HOME_DIR -1
                      #define Z_HOME_DIR 1
                        Yes, your left when looking at the machine. This matches the way that CAD and slicer software orients the part view.
                        Now there is no hard rule that says this is the way things must be. There are many printers that have the endstops on the opposite side and still home to the low end with all endstops. As I said, if you do both X and Y it just has the effect or rotating the part 180 degrees compared to the slicer preview.
                        In the olden days the endstop and the 0 point were synonymous, but now days the origin and the endstop locations are not necessarily the same.
                        I would ignore the marlin setup entirely and focus on the printer itself and how it's oriented and how reprapfirmware is configured to reflect that.
                        Here are some photos that might help clarify.
                          airscapes @Phaedrux
                          @phaedrux I think I have the motion and end stops all figured out.
                          Homing works correctly and all the jog buttons move the axis in the proper direction .
                          I have even figured out the M206 thing .. sort of. Was going to print a cal square but got a heater fault on the bed as it was just starting to heat up and has always been slow. So new thread on that issue, as searching did not help much at all.
                          Will update this once I can print something... assuming it prints.. 🙂
                            I don't think M206 would be needed at all. It's far easier to just adjust position of the reachable area with the M208 min and max values.
                            If the nozzle is off the edge of the printable bed when the endstop is hit, you can treat the corner of the bed as 0,0 and then use a negative value for M208 min to place the endstops as far as they need to be away from the bed.
                            In the case of a setup using max endstops such as this, if the endstop is off the edge of the reachable bed you can just limit the print area in the slicer.
                              airscapes @Phaedrux
                              @phaedrux I have made good progress and to your point the, M206 does not work the same in RepRap as it does in marlin. In marlin it is added to max_pos . So I did as you said and used the M208 to alter the gap between the build plate and the nozzle. I would normally do this within octoprint using m206 but since I will now have to edit the config I will have to use both interfaces as I do prefer octoprint over the web interface of the Duet. Still have to do some more testing and probably tweaking of Accelerations and such.
                              Thanks for your patients with me, I am sure I will be back with more questions I can't find answers for. 🙂
                              • Phaedruxundefined Phaedrux has marked this topic as solved
                              • andykundefined
                                andyk
                                @airscapes Heya, did you ever finish your M2 conversion? I'm considering taking the plunge too. Would you be willing to share your config files and any build gotchas either here or in the makergear forums?
                                  airscapes @andyk
                                  @andyk Sure but I am not sure I would do it again since I am adding nothing to the M2. Not sure it is really an upgrade other than noise reduction. I am finding issues with using Octoprint where the duet 2 Gui crashes and the manual extrude/retract buttons of octoprint don't work. I could give up octoprint.. but old habits die hard.
                                    Octoprint
                                    Octoprint isn't really recommended with the Duet. It kind of defeats half the features of the Duet.
                                      airscapes @Phaedrux
                                      @phaedrux
                                      I am going to give the Web Gui a run and see if I like it. Have a job running now without Octoprint connected, waiting to see if the Gui Still crashes.. Started the last job with the Gui, octoprint was connected, and the gui died so had to power off the machine to stop the job...second time without octoprint connected .. so far so good
