    SD card physically broken
    Config Tool
    • rogerz79undefined
      rogerz79
      I ended up breaking my SD card in to two pieces. I did not make a back up of the sd card. I have a Duet 2 wifi board that I always controlled and updated through the web interface. Is there any way to recover the config file or anything? I have a custom setup and have made so many changes and tweeks to it that it really is heart breaking to have to start over from scratch again. Any help would be appreciated. Thank you
      T3P3Tonyundefined zaptaundefined 2 Replies Last reply Reply Quote 0
        T3P3Tony administrators @rogerz79
        @rogerz79 unfortunately not. I suggest starting with the config tool to get the basics setup and then go from there.
        rogerz79undefined 1 Reply Last reply Reply Quote 0
        • rogerz79undefined
          rogerz79 @T3P3Tony
          @t3p3tony nothing stored in a cookie or a cache of some sort on the website
            @rogerz79 no unfortunately not.
              How did it break in two?!
              • zaptaundefined
                zapta @rogerz79
                @rogerz79, for future backups, you may want to look at the Duet's rfm utility. It syncs your configuration to a computer. Also works well with versions control systems such as github.
                Also, I am not sure, but DWC may be able to create backup zip files (?).
