    Macro for testing movements
    • Falkiaundefined
      Falkia
      The progress with my Delta is slow but now the 3 steppers and the end stops are connected and the homing is working. I have made some small macros for testing but like to know if there are any longer macros for making longer test. So far there are no heaters, no temperature sensors, no extruder connected and the smart effector is not wired yet. I just want to see the machine move.
      Build volume D500mm H920mm. Moving
      Thanks
      Fredrik
      Printer: "Deltacus" Delta with 510mm bed diameter and 925mm build height. Powered by Duet 2 WiFi. Duet Smart Effector with E3D Volcano.
      • fcwiltundefined
        fcwilt @Falkia
        @falkia
        What do you mean by "longer test"?
        What firmware version are you running?
        Falkiaundefined 1 Reply Last reply Reply Quote 0
        • Falkiaundefined
          Falkia @fcwilt
          @fcwilt I think about 5 minutes will be enough. Running firmware 3.3.
          Thanks
          Fredrik
          • fcwiltundefined
            fcwilt @Falkia
            @falkia
            Have you tried using a while loop to perform the basic set of movements many times as controlled by the while loop iterations value?
            while iterations < 10
            move 1
            move 2
            move 3
            etc
            Falkiaundefined 1 Reply Last reply Reply Quote 1
            • Falkiaundefined
              Falkia @fcwilt
              @fcwilt no but that was a good idea.
              Thanks
